POV-Ray : Newsgroups : povray.animations : Animating Water Server Time
28 Jul 2024 22:21:12 EDT (-0400)
  Animating Water (Message 1 to 6 of 6)
Subject: Animating Water
Date: 23 Sep 1998 01:49:17
Message: <36087E38.5A2285C5@uiuc.edu>
Could anyone out there give me an idea as to how to animate water?
	 I was also wondering if anyone knew how to simulate the ripples or
disturbances in an animation in which a drop of water falls into a
puddle.
	Thanks. Any help would be much appreciated.
	-Todd Burch
Todd Burch
tbu### [at] uiucedu
www.uiuc.edu/~tburch
University of Illinois at Urbana-Champaign
"He who forgets will be destined to remember"
	-Edward Vedder, Pearl Jam
Subject: Re: Animating Water
Date: 23 Sep 1998 04:18:51
Message: <3608A0DA.41C6@ica.uni-stuttgart.de>
Hi!
There's a small tutorial on Gil Babin's homepage, where he also has
three animated gifs.
The disturbances in a pool by an drop of water should follow the
equations for a wave but don't ask me how to put this one into povray
... maybe you can use the polynomial surfaces.
I hope I could help you
Marc
Marc Schimmler
Institut fuer Computeranwendungen
Universitaet Stuttgart
Pfaffenwaldring 27
70569 Stuttgart
Date: 23 Sep 1998 06:04:47
Message: <3608B9AE.2781@ica.uni-stuttgart.de>
I forgot to give the address:
http://www.cstech.fr/~babin/babin/povray/FramePov.html
Marc
Marc Schimmler
Pfaffenwaldring 27
70569 Stuttgart
Date: 28 Sep 1998 10:25:26
Message: <360f8e46.0@news.povray.org>
Animated ripples in a puddle of water is easy if all you need is a simulation.
Example:
plane {y,0
 texture {pigment {rgbf<.9,.9,.9,.9>}
  normal {onion normal_map {
    [0 ripples 1 phase -1*clock scale 0.1 ] //adjust frequency and scale
    [.5 ripples 0 ] //adjust .5 up or down for area, leave zero there
   } scale 5 } //adjust this scale for size
  finish {diffuse .1 specular 1 roughness .25 reflection .2}
Tune the scale of this as needed, it repeats like all textures so frame it in
properly and should be okay.
Most important is to put number_of_waves=1 into global_settings or the ripples
will be turbulent (mixed ripples).
For more realism (rain drops) use Chris Colefax's spray.inc:
http://www.geocities.com/SiliconValley/Lakes/1434/
Though you may have to learn it first if you haven't used it before.
Message <36087E38.5A2285C5@uiuc.edu>, Todd Burch  typed...
>puddle.
>        -Todd Burch
>Todd Burch
>tbu### [at] uiucedu
  http://members.aol.com/inversez/POVring.html
=Bob
Date: 17 Jan 1999 23:06:19
Message: <36A2B3D1.A6DBCEAF@worldnet.att.net>
> puddle.
>         -Todd Burch
I have attempted to animate water with reasonable results, but it involves an
extra rendering for each frame.  I used a flat plane with a rippling texture
using a plain black-to-white color map. I translated the texture a little bit
for each frame in the direction I wanted the water to flow, and a little in the
+z to randomize it a bit and make it 'move'.  After rendering each pattern, I
shelled out to DOS and ran a little batch file to change the image file name to
that of a height field used in the actual scene, then render the scene.  The
result is a new height field for each frame, each a little different the the
last, to simulate fluid in motion.  I have also used a similar process for
animating a motion picture TV screen, only using an image map for the screen
instead of a height field.
Date: 22 Jan 1999 14:13:15
Message: <36a8cdcb.0@news.povray.org>
an
texture
bit
the
I
name to
The
the
screen
This is almost precisely what I did for the water.gif image I posted over on
binaries.animations
Grim
vos### [at] arkansasnet
