POV-Ray : Newsgroups : povray.advanced-users : Strange media artefact Server Time
10 Oct 2025 00:28:02 EDT (-0400)
  Strange media artefact (Message 1 to 7 of 7)
Subject: Strange media artefact
Date: 8 Feb 2021 14:40:08
Message: <web.6021933a6b2775471f9dae300@news.povray.org>
While working out some media stuff for Mike, I ran a a quick media test to just
make sure I had the standard part working, and I got some odd results.
Perhaps someone could render this and tell me why the center gives me a nice x
gradient, but off to the sides I get those weird fans / lines.
(Alain, fyi:  the syntax is simply "method 3", not "sampling_method 3")
#version 3.8;
global_settings {assumed_gamma 1.0 }
 location <0, 8, -10>
 //location <0, 10, 3>
 up y
 look_at <0, 0, 0>
light_source {<0, 50, -1> rgb 1}
sky_sphere {pigment {rgb <1, 1, 1>}}
box {<-10, -1, -5>, <10, 1, 5>
 pigment {rgbt 1}
 hollow
 interior {
  media {
   absorption <1, 1, 1>
   //emission <1, 0.2, -0.6>*0.9
   //scattering{ 1, <1,1,1>
   //extinction  2.0
   method 3
   intervals 1 //DO NOT increase !
   samples 10, 50
   density {
    gradient x
    color_map {
     [0.0 rgb 0.0]//border
     //[0.5 rgb 0.1]
     [1.0 rgb 1.0]//center
    } // end color_map
   } // end density
  } // end media
 } // end interior
} // end box
Subject: Re: Strange media artefact
Date: 9 Feb 2021 07:56:31
Message: <6022867f$1@news.povray.org>
Been now some years since I was digging around in that code, but if I'm
remembering my "things-look-fishy-there" list correctly, the short
answer is you need to increase the sampling. Try:
  samples 33
or perhaps more (with stronger AA tend to need less). The second value
is not used with method 3. The aa_level (recursion limit) and
aa_threshold stop method 3.
---- Details... Suspicions... on my look at it more later list.
- Why did I jump to the odd number of samples? With method three you get
+2 samples per sampling segment for odd sample specification and +1 for
even. Where the decent and the adaptive mode is working, I think the
code is slightly more symmetric with odd values - and 'probably' creates
better results.
- I think the adptive sampling mechanism of method 3 is not working for
absorbtion/emissive only media!! At least not working in the same way as
scattering. Blah, blah,.... lots more details. Comes to needing to force
a higher level of sampling - which, you're right, won't always be adaptive.
Aside: You can sort of see this by looking at the number in parens after
the number of media samples. You can twiddle all you want with the
samples values and that number will always be +1 or +2 of the initial
samples setting because it is the number or samples per segment. If you
have scattering media it comes to be +1 or +2 the initial samples, plus
some 0-1 float adder. Further, the aa_level and aa_threshold values do
something if you have scattering media.
- The aa_threshold value I suspect, should have been adjusted on the
changes to assumed_gamma 1.0 as was done eventually in v3.8 for the
ambient default (there zero makes more sense, but to match ambient of
earlier scenes it should not be the previous 0.1, but something much
smaller like 0.004).
- Though absorption works alone I wonder if it wasn't originally
supposed to always be paired with scattering.
- When emission was added, a second absorption value spec should have
been added specifically for it's contribution. Having one value for both
scattering and emission sometimes just won't work out - and it's harder
to use even when you can make it work.
Aside: You can get interesting patterns with densities and medias like
yours by setting the samples low. As low as 2 even.
- Even where the adaptive is working you sometimes need to increase the
initial samples count quite a bit. As with other gradient sensitive
adaptive algorithms (isosurfaces, AA method 3(a)) you sometimes have to
set the initial sample higher to pick up enough change to 'trip' the
adaptive algorithm. You have to sample rapidly enough to see
smaller/rapid changes.
(a) - AA method 3, is currently missing this capability except by
increasing the size of your initial render - which is sort of a back
door method of increasing the initial number of samples. This something
Christoph recognized. There are comments in the code.
- Something I do not think made clear in the documentation is that when
the density is constant method 3 is not used but rather a part of method
1 or 2 (I don't recall) which is very fast. What this means in practice:
For constant medias you can get away with settings that are quite
aggressive. The instant that media is not constant things will either
not render correctly with the aggressive (cheap) settings or suddenly
slow significantly if the settings are correct for non-constant media.
The big slow down happens where the adaptive algorithm gets tripped. In
other words, the fast path is no longer used - and the method 3 settings
actually matter.
- It's true with method 3, intervals should be kept at 1. :-) Here it
happens you can actually set it to 3, 4 or more maybe and get much
better results. The issue with it, that I saw, is when intervals are >1
the math gluing together all the intervals is buggy. You get media
results which are less accurate - sometimes to the point of obvious
artifacts. Aside. That old Persistence, submarine scene actually used
the artifacts for effect - but if you look carefully, you can see them.
...There is more, and somewhere I have notes. But! I'm going to worry
about it all some other day and go grab more coffee. :-)
Disclaimer. I've listed some of my initial media 'suspects'. If I get
back to working on the media code, I'm sure I'll find myself to be
right, wrong and partly right/wrong about the different details.
Bill P.
Date: 9 Feb 2021 13:40:01
Message: <web.6022d691ca7b7f1f1f9dae300@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> Try:
>   samples 33
That seemed to be sufficient to rectify the issue.  Can't say that sample 65
looks significantly better...
Even at this "late" stage, I do not have an adequate grasp of antialiasing
settings, so maybe that will be a future area of concentration for me to
investigate, or someone else to post some explanation with illustrative code.
Well Gooooooollllllly!
Look at all that there stuff under the hood of POV-Ray that you just emptied out
of your head...   :O
Good catch, and that is probably something that needs to be ironed out, or at
least in the short term provided with a little formulaic workaround to tweak the
values accordingly.  Something like the gradient formula for isosurfaces or some
of the lighting formulas in the docs, if that's at all possible.
aye,  I should probably take more notes.  Though I already get razzed about the
number of piles of paper with cryptic scribblings...   ;)
Thanks for the info as always   :)
Date: 10 Feb 2021 02:39:39
Message: <60238dbb@news.povray.org>
Op 09/02/2021 om 13:56 schreef William F Pokorny:
>> test to just
>> a nice x
>   samples 33
[snip]
Wow! Some nice piece of info there!
I was late testing this media and found also that samples were the
culprits.
I have one question about them: can samples still be used with two
parameters with method 3? The Wiki is confusing about this, and I
wondered if it was a legacy from method 1 or 2, but not necessary anymore.
Date: 10 Feb 2021 05:58:11
Message: <6023bc43$1@news.povray.org>
> [snip]
Keep the disclaimer(a) in my post in mind. I believe most of the
information is good, but should I get back to digging around again in
that code, some of it will need revision.
(a) - I'm talking too about the current v3.8. Christoph made changes
relative to v3.7.
> culprits.
Yes. You can have the max value, it doesn't hurt anything(b). It looks
to be used in the statistical sampling methods.
(b) Your question reminded me of another media issue. We can have
multiple medias. When we do there were situations I cannot quite recall
- with ordering... Mixing media 1&2 with 3 - 'maybe.'
In some of those cases, depending on ordering, certain settings matter
which would not if a particular media in the collection were run alone.
It's been too long - I'm not remembering the details, but there were
issues with multiple medias and option settings.
Hmm, another ringing bell; Was there also something with one media in
multiples being constant and others not...?
I might have created test cases for some of the issue/questions. I have
many media test cases, though, most were for work on the solvers. Media
in containers make good solver test cases because you have to get all
the roots right...
Anyway, I'm focused elsewhere at the moment.
Bill P.
Date: 11 Feb 2021 10:59:04
Message: <60255448$1@news.povray.org>
> #version 3.8;
> camera {
>   up y
>   look_at <0, 0, 0>
>   pigment {rgbt 1}
>   hollow
>   interior {
>    media {
>     //extinction  2.0
>     method 3
>     samples 10, 50
>     density {
>      gradient x
>      color_map {
>       //[0.5 rgb 0.1]
>      } // end color_map
>     } // end density
>    } // end media
>   } // end interior
> } // end box
It's a case of not enough samples. In my test, I needed to increase all
the way to samples 50 to completely get rid of those lines.
In this case, you don't need the color_map as it exactly match what the
gradient pattern already give you.
Instead of using a sky_sphere with a solid pigment, you should use
background{ rgb 1}. A sky_sphere is for when you want a pattern as your
background.
With the current background and media type, you don't need any light.
Date: 11 Feb 2021 11:03:35
Message: <60255557$1@news.povray.org>
You can use two parameters for samples with method 3, but the second
will just get silently ignored.
Yes, it's a legacy from method 1 and 2.
