POV-Ray : Newsgroups : povray.advanced-users : Implementation of dynamically resized array Server Time
4 Jan 2025 18:09:44 EST (-0500)
  Implementation of dynamically resized array (Message 1 to 8 of 8)
Subject: Implementation of dynamically resized array
Date: 2 Nov 2018 18:45:01
Message: <web.5bdcd2b755af31a9765e06870@news.povray.org>
Hi all,
I was restructuring some code, and wanted to take advantage of using the new
array features.
#local ToothPrismArray = array [1];
#local ToothPrismArray [0] = <_RC, _RC>;
#local ToothPrismArray [1] = RotatePoint (<_RC, 0>, -_HT);
#local ToothPrismArray [2] = RotatePoint (<_RB, 0>, -_HT);
When I get to the second line of element definitions, I get the old "Array
subscript out of range" error.
Is there a trick to this?
Am I a (few) version(s) behind?
(Windows)
version 3.8.0-alpha.9606898.blahblahblah
Thanks
Subject: Re: Implementation of dynamically resized array
Date: 2 Nov 2018 19:10:00
Message: <web.5bdcd8293ab1e8e96427f7f90@news.povray.org>
hi,
> array features.
should work if you get rid of the initial dimension, ie
#local ToothPrismArray = array;
regards, jr.
Date: 2 Nov 2018 19:30:01
Message: <web.5bdcdd0f3ab1e8e9765e06870@news.povray.org>
I commented that out, and now
gives me "Expected '=', [ found instead.
Is there a simple, easy link to download just the latest 64-bit executable file?
Date: 2 Nov 2018 20:00:01
Message: <web.5bdce4ac3ab1e8e9765e06870@news.povray.org>
Just went to:
https://github.com/POV-Ray/povray/releases
Downloaded
Development build v3.8.0-alpha.9893777+av622
un7-zipped the file, renamed the old exe, copied over the new, ran it, checked
the version number in "about", and still have the same problem(s)trying to
render the scene.
So, It's not the version - I'm doing something wrong.
I even tried
#ifndef (ToothPrismArray [1]) #end
right before that, and got an error even trying to check if that array element
was defined.   :(
Date: 2 Nov 2018 20:20:00
Message: <web.5bdce8a03ab1e8e9765e06870@news.povray.org>
http://news.povray.org/povray.general/message/%3C5b540d5e%241%40news.povray.org%3E/#%3C5b540d5e%241%40news.povray.org%3
E
#declare Foo = array;
This will create a resizable array with an initial size of zero, and
then grow the array...
So, it seems that ANY array is not resizable, only specially created arrays.
Date: 3 Nov 2018 09:17:38
Message: <5bdd9ff2$1@news.povray.org>
Am 02.11.2018 um 23:41 schrieb Bald Eagle:
> Hi all,
> array features.
Yes. The normal arrays are still fixed; you need to declare the array
differently:
     #local ToothProsmArray = array;
Note the absence of any dimensions. This declares a one-dimensional
variable-sized array.
Before anyone asks, multi-dimensional variable-sized arrays are not
supported.
Date: 3 Nov 2018 09:30:59
Message: <5bdda313$1@news.povray.org>
Am 03.11.2018 um 00:26 schrieb Bald Eagle:
Make sure you have NOT un-commented the semicolon.
Without the semicolon, POV-Ray will continue scanning for an opening
square bracket. The next `#local` is /not/ sufficient for POV-Ray to
recognize that you're done declaring the array; instead, POV-Ray will
just postpone parsing the array declaration, expecting it to be
continued after the second `#local`. So you'll end up with an attempt to
assign an array element before the array even exists, and POV-Ray gets
all confused.
Date: 3 Nov 2018 09:32:16
Message: <5bdda360$1@news.povray.org>
Am 03.11.2018 um 14:31 schrieb clipka:
I meant to write "NOT commented out" of course.
