POV-Ray : Newsgroups : povray.advanced-users : passing variable to macro for use in #for statement Server Time
29 Apr 2024 05:11:33 EDT (-0400)
  passing variable to macro for use in #for statement (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: passing variable to macro for use in #for statement
Date: 20 Sep 2018 10:10:01
Message: <web.5ba3aa31b6c56d12c437ac910@news.povray.org>
> If however you just pass the variable itself (rather than its name),
> then the following should work fine:
>     #macro Loop (Var, Begin, End, Step)
>       #for (Var, Begin, End, Step)
>       #end
>     #end
>     #local Fnord = 42;
>     Loop(Fnord,0,10,2)
>     #debug concat("Fnord is now ", str(Fnord,0,0), "\n")
Hmmm.   yes, that will work just fine.... in most cases...
Though I'm trying to only /initiate/ a loop with the macro - so the #end of the
for loop is what I need to avoid at the present.
I have not yet figured out if there's a syntax trick that's possible.
like so:
Loop(Fnord,0,10,2)
     [loop contents NOT in macro]
> Also reasonably clean would be the following construct:
>     #macro FormatKeyword(Format)
>       #if (Format = "png")
>         png
>       #elif (Format = "jpeg")
>         jpeg
>       #end
>     #end
>     #declare Format = "png";
>     image_map { FormatKeyword(Format) "foo.png" }
Right - o.  That'll be great.   Especially since I can just use a string
function to look at the extension of the filename and avoid the declare
altogether.   :)
Date: 20 Sep 2018 11:00:09
Message: <5ba3b5f9$1@news.povray.org>
Am 20.09.2018 um 16:09 schrieb Bald Eagle:
Can't do such a thing. The `#end` directives in a macro must always be
balanced - otherwise, how would the parser be able to figure out where
the macro ends.
> altogether.   :)
If the file type can already be inferred from the extension, Why not let
POV-Ray do that job? Just leave out the file format keyword, like so:
    image_map { "foo.png" }
and Bob's your uncle.
Date: 20 Sep 2018 15:00:00
Message: <web.5ba3ed57b6c56d12a47873e10@news.povray.org>
> Am 19.09.2018 um 17:58 schrieb Bald Eagle:
> > Along the same lines, is it possible to assign an image_map file type
> > to a variable-- like png, jpeg, etc. ?
> ...reasonably clean would be the following construct:
>         png
>         jpeg
>       #end
>     #end
Hey, that's GREAT! I struggled with this idea years ago, and had to use some
ugly kludges to get this result. Using a macro didn't occur to me (I probably
thought it wouldn't work.) Thanks, it's a really nice construct.
This would be the (longer) way that I would write such a macro (just for
visual/mental clarity):
png
#else
     #if(Format = "jpeg")
     jpeg
     #else
          #if(Format = "bmp")
          bmp
          #else
#end // of macro
box{0,1
pigment{
image_map{FormatKeyword(Format) "crater demo as PNG.png" interpolate 2}
.... which works very nicely.
A couple of questions/observations, though: The docs say two things at
"3.3.2.6.1 The if...else...end Directives" (in v3.7.1 beta 9's help file--
although I haven't yet checked the online wiki):
"...an optional #elseif clause is now supported."
and
"NOTE: Nesting directives in the following manner has been known to cause
problems during the parse phase.
#if( #if(yes) yes #end ) #end
The even shorter keyword  #elif  (for #elseif) is not mentioned there (even
though it works); and, its keyword 'color' in scsne code looks like a
'non'-keyword. Should both of those little errors be fixed?
More importantly, I've never had a problem using nested #if's (when including
all of the #else keywords, anyway.) I *think* my macro is a good demonstration
of what the docs mean by nested #ifs as explained there(?) So are the new
keywords #elseif and #elif designed to eliminate any *possible* nested-#ifs
problems (along with being 'shorthand' versions of such constructs)? Just
curious.
Date: 20 Sep 2018 15:50:00
Message: <web.5ba3f86fb6c56d12a47873e10@news.povray.org>
Hmm, I see now that my macro's nested #if's and the docs' example are different
animals.
The docs'
clause is trying to construct a boolean "yes" within its inner #if (for use
within the outer #if?), which is rather odd-- and different from my macro's
straightforward use of nested #if's.
Date: 20 Sep 2018 15:58:03
Message: <5ba3fbcb@news.povray.org>
Am 20.09.2018 um 20:56 schrieb Kenneth:
>>         png
>>         jpeg
>>       #end
>>     #end
Whoops, my bad: It's `#elseif`. The construct isn't too uncommon in
programming languages, but the languages can't agree on whether it
should be `elseif`, `elsif` or `elif` (or a variation thereof as the
programming language's meta-structure permits, such as POV-Ray's `#elseif`).
Examples of Elseif-Languages:
- Ada
- POV-Ray SDL
- Visual Basic
Examples of Elsif-Languages:
- Perl
- Ruby
Examples of Elif-Languages:
- C/C++ Preprocessor
- Python
- Unix shell scripts
Actually, no, it doesn't work: That's a mirage. If you examine it more
carefully, you'll find that the construct only behaves as expected if
both the `#if` condition and `#elif` conditionoid happen to be false;
because in that case the bogus `#elif` statement will simply be skipped.
If the `#if` condition happens to be true, the parser will parse the
`#if` branch and then crash right into the `#elif` like a brick wall,
and if the `#elif` conditionoid happens to be true, the parser will
still skip over it and enter the `#else` branch.
> curious.
Properly nested `#if` statements are not a problem. The problem
described in the docs specifically relates to nesting an `#if` in the
/condition/ of an enclosing `#if`.
Date: 20 Sep 2018 16:45:01
Message: <web.5ba40654b6c56d12a47873e10@news.povray.org>
> > though it works)...
> carefully, you'll find that the construct only behaves as expected if...
Oh, sorry. I didn't thoroughly test the  #elif  keyword; I used your macro
construct as-is (basically), and it just *happened* to work in my case, or
appeared to.
Caveats noted!!
Date: 20 Sep 2018 17:25:36
Message: <5ba41050$1@news.povray.org>
Am 20.09.2018 um 22:43 schrieb Kenneth:
>>> though it works)...
> appeared to.
Yeah, been there, done that. When you mentioned that both `#elseif` and
`#elif` seemed to work, I was like "huh? I'm not sure which of the two I
implemented, but I'm pretty darn sure I didn't implement both" - did a
short test myself, and lo and behold - `#elif` didn't produce an error.
So yeah, `#elif` must be what I had implemented, and I must have screwed
up the docs, accidently communicating it as `#elseif`...
Just for funsies and because I always love to double-check even if I
/know/ the results [hah!], let's just replace `#elif` with `#elseif` to
prove my point...
... huh? That didn't produce an error either; did I /really/ implement
both alternatives? Wow, clever me...
... um, wait, WTF?! Didn't that scene behave differently with `#elif`?!
Now I'm officially puzz...
... D'OH! - yeah, THAT is what's happening...
I love the smell of truth dawning on me.
Date: 21 Sep 2018 00:51:03
Message: <5ba478b7$1@news.povray.org>
> png
> #else
>      jpeg
>      #else
>           #if(Format = "bmp")
>           bmp
>           #else
>           #end
>      #end
> #end
> #end // of macro
I would write:
    #if (Format = "png") png #end
    #if (Format = "jpeg") jpeg #end
    #if (Format = "bmp") bmp #end
dik
Rendered 1024 of 921600 pixels (0%)
Date: 21 Sep 2018 03:30:03
Message: <5ba49dfb$1@news.povray.org>
>> png
>> #else
>>       jpeg
>>       #else
>>            #if(Format = "bmp")
>>            bmp
>>            #else
>>            #end
>>       #end
>> #end
>> #end // of macro
> I would write:
> #end
You could use SWITCH and CASE as well.
Mike
Date: 21 Sep 2018 07:25:36
Message: <5ba4d530$1@news.povray.org>
Am 21.09.2018 um 09:30 schrieb Mike Horvath:
`#switch`/`#case` is cumbersome to use with strings.
