POV-Ray : Newsgroups : povray.advanced-users : command capability / syntax Server Time
10 Oct 2025 12:56:24 EDT (-0400)
  command capability / syntax (Message 1 to 8 of 8)
Subject: command capability / syntax
Date: 25 May 2017 08:05:00
Message: <web.5926c74bb4e709cdc437ac910@news.povray.org>
I was wondering if:
vectors can be used in Boolean conditional statements
#if (Q = <1, 1, 1>)
If the number of arguments a macro takes is a value that is user accessible,
much like dimensions and dimension_size?
Can the size of a vector be determined by a command?
<1, 2> vs <1, 2, 3> vs <1, 2, 3, 4, 5>
Is there a way to determine if an identifier is a scalar or a vector?
Subject: Re: command capability / syntax
Date: 25 May 2017 08:28:58
Message: <5926ce0a$1@news.povray.org>
Am 25.05.2017 um 14:00 schrieb Bald Eagle:
> I was wondering if:
> #if (Q = <1, 1, 1>)
Nononono.
Date: 26 May 2017 04:33:18
Message: <5927e84e$1@news.povray.org>
Am 2017-05-25 08:00, also sprach Bald Eagle:
> I was wondering if:
> #if (Q = <1, 1, 1>)
#if (VEq(Q,<1,1,1>)
dik
Date: 26 May 2017 05:02:49
Message: <5927ef39@news.povray.org>
>> I was wondering if:
>> #if (Q = <1, 1, 1>)
#include "math.inc"
> #if (VEq(Q,<1,1,1>)
for 5D: VEq5D
Date: 26 May 2017 08:00:00
Message: <web.5928184518337dfc437ac910@news.povray.org>
> #include "math.inc"
> > #if (VEq(Q,<1,1,1>)
> for 5D: VEq5D
Most excellent.
Thanks to both of you gentlemen.  I had not thought to look in the vector
functions for a simple Boolean comparison.
I'm thinking that a macro that does something like a progressive #ifdef(Q.x),
#ifdef (Q.y), #ifdef(Q.z) ..... would be able to count vector elements and
return the size of the vector, and if there's only 1 element, then it's a
scalar.
Date: 26 May 2017 11:00:06
Message: <592842f6$1@news.povray.org>
> scalar.
You forget one thing, which lose the whole idea: automatic expansion of
scalar and vector.
#declare Scalar = 1;
Yet, Scalar.x, Scalar.y and so on are valid and defined as 1.
#declare Vector = <1,2>;
Yet, Vector.z is valid and defined as 0.
The Wise-Man said No, listen to him.
Date: 26 May 2017 13:35:05
Message: <web.5928665618337df883fb31c0@news.povray.org>
> > I was wondering if:
> > #if (Q = <1, 1, 1>)
> #if (VEq(Q,<1,1,1>)
That's interesting; didn't know it could be done. But other comments here imply
that <1,1,1> is actually <1,1,1,0,0>. In which case, #if(VEq...) would still
return 0 or "false"(?). Unless VEq5D is used; but the vector would still need
<1,1,1,1,1>, not <1,1,1>, for even VEq5D to return "true."
Am I understanding this correctly?
Date: 26 May 2017 14:00:11
Message: <59286d2b$1@news.povray.org>
Am 26.05.2017 um 19:31 schrieb Kenneth:
>>> I was wondering if:
>>> #if (Q = <1, 1, 1>)
>> #if (VEq(Q,<1,1,1>)
No.
<1,1,1> is /not/ <1,1,1,0,0>.
But if you use <1,1,1> in any context where a 5-dimensional vector is
expected, it will automatically be /expanded/ to <1,1,1,0,0>.
VEq(A,B) compares the first three components of A and B. If the vectors
have more components, those are simply ignored.
