POV-Ray : Newsgroups : povray.advanced-users : Parametrics and isosurfaces Server Time
25 Mar 2026 03:38:19 EDT (-0400)
  Parametrics and isosurfaces (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Parametrics and isosurfaces
Date: 6 Aug 2016 16:25:00
Message: <web.57a6475b5c93b6e65e7df57c0@news.povray.org>
If I try to use:
  function { (5+2*RESULT[int(u/Delta)][4]/Order) * sin(u) * cos(v) }, // x-axis
I get "Float expected but vector or color expression found"
Are u and v not scalar values?
(apparently not, since using u.gray gets me through the parsing...)
(all I get is a sphere)
If anyone uses MatLab, perhaps they can illuminate me on what I'm missing.
Date: 6 Aug 2016 17:05:00
Message: <web.57a650c25c93b6e65e7df57c0@news.povray.org>
....aaaaand embedding
#debug concat( " u = ", vstr(2, u, ", ", 0, 3), " v = ", vstr(2, v, ", ", 0, 3),
"\n")
into the parametric definition yields
u = 1.000, 0.000 v = 0.000, 1.000
and that's the one and only line of output I get.
So, this leads me to ask, "sin and cos can work on 2-element vectors?"
I'm curious to learn more about the internal workings of the parametric - and
how I can bend it to my will....  :D
Date: 6 Aug 2016 19:40:42
Message: <57a6757a$1@news.povray.org>
Am 06.08.2016 um 22:23 schrieb Bald Eagle:
> If I try to use:
The problem here is that the function evaluation engine cannot access
any scene-level variables whatsoever. Therefore, whenever you specify
such a variable in a function, POV-Ray immediately evaluates it while
parsing the function, expecting to get a float, which it will insert
into the function as a constant.
This attempt at immediate evaluation also includes access to array
elements. However, the parsing of the array indices is done by the
parser for generic SDL code, /not/ the parser for user-defined
functions. Thus, in the sub-expression
the `u` is /not/ interpreted as the function's first parameter, but as
the vector constant `<1,0>`; this ultimately leads to a parse error,
since the int() function expects a float but encounters a vector.
Date: 6 Aug 2016 19:57:24
Message: <57a67964$1@news.povray.org>
Am 06.08.2016 um 21:35 schrieb Bald Eagle:
> I'm trying to calculate a rho or an r value that smoothly varies with u.
> As you can see below, I figured that defining a spline based on the polynomial
> evaluations was a logical way to do this, but the parser complained when I tried
> to use RhoSpline(u) in my functions, and still complains when I try to use a
> user-defined function that returns a spline value.
> "expected 'operand', but spline identifier found instead"
There are a few things that you can do in POV-Ray's regular SDL, but
which don't work in functions.
I'm a bit surprised about this myself, but using splines in place of
functions seems to be one of those things.
You'll therefore have to find a different approach to implement your
spherical harmonics -- pre-computing sample points of the polynomials
and approximating the whole thing with splines won't work.
Date: 6 Aug 2016 20:20:01
Message: <web.57a67e165c93b6e65e7df57c0@news.povray.org>
Thanks - I do understand and appreciate that there are a lot of things that are
intertwined and virtually inextricably embedded in POV-Ray, and would take a
major rewrite to fix, or add.
I'll keep plugging away at it. :)
Can you explain what the following excerpt from the docs _means_ ?
"Also, function splines take the vector size into account. That is, a function
containing a spline with five components will also return a five component
vector (aka a color), a function containing a spline with two components will
only return a two component vector and so on. "
What's an example of a working "function spline"?
Date: 6 Aug 2016 20:23:50
Message: <57a67f96$1@news.povray.org>
Am 07.08.2016 um 01:57 schrieb clipka:
BTW, I suspect that evaluating the sample-based splines wouldn't even be
much more performant than evaluating the base polynomials on the fly.
However, I presume that a naive implementation of the final function
would cause unnecessary double-evaluation of the base polynomials.
Consider the following (simplified) example:
  #declare fn1 = function(x) { ... }
  #declare fn2 = function(x) { ... }
  #declare fn3 = function(x) { ... }
  #declare fnA = function(x) { fn1(x) + fn2(x) }
  #declare fnB = function(x) { fn2(x) + fn3(x) }
  #declare fnC = function(x) { fn3(x) + fn1(x) }
  #declare fn = function(x)
    { A*fnA(x) + B*fnB(x) + C*fnC(x) }
Note how in this case each call to `fn` will evaluate all of the basic
functions twice.
One way to avoid this multiple evaluation of the basic functions is to
re-write the intermediate-level functions as taking not x as parameter,
but the results of the basic functions, like so:
  #declare fnA_ = function(fn1,fn2) { fn1 + fn2 }
  #declare fnB_ = function(fn2,fn3) { fn2 + fn3 }
  #declare fnC_ = function(fn3,fn1) { fn3 + fn1 }
  #declare fn_ = function(fn1,fn2,fn3)
    { A*fnA_(fn1,fn2) + B*fnB_(fn2,fn3) + C*fnC(fn3,fn1) }
  #declare fn = function(x) { fn_(fn1(x),fn2(x),fn3(x)) }
Not sure if this approach is applicable to your problem though, since I
only had a cursory glace at what the formulae in your code are actually
doing.
Date: 6 Aug 2016 20:40:59
Message: <57a6839b@news.povray.org>
Am 07.08.2016 um 02:17 schrieb Bald Eagle:
Ah -- that explains why I was surprised that splines didn't work in
functions.
Having read the relevant portions of the docs again, it turns out you
can do the following:
  // Declare a normal spline.
  #declare MySpline = spline {
  // Declare a spline function.
  // (Note that this returns a vector, not a float.)
  #declare MySplineFn = function { spline { MySpline } }
  // Use the spline function in a regular function.
  // (Note the `.x` to access the spline function result's
  // first coordinate; don't confuse it with the `x` denoting
  // the function's first parameter.)
  #declare MyFn = function(x) { ... MySplineFn(x).x ... }
(You can also place the actual definition of the spline into the spline
function itself.)
Date: 3 Sep 2016 13:58:06
Message: <57cb0f2e$1@news.povray.org>
Op 2016-08-06 om 21:35 schreef Bald Eagle:
> So, here's an example I'm currently grappling with.
> I'd like to use a parametric to make a spherical harmonic following the MatLab
> code here:
> http://148.204.81.206/matlab/examples/spherical-surface-harmonic.html
You can do that using the Meshmaker.inc, the win-POV insert menu has
some examples Insert > SpecialShapes > Meshes by meshmaker.inc
Ingo (sorry for the accidental e-mail)
Date: 14 Sep 2016 12:50:01
Message: <web.57d97f705c93b6e6b488d9aa0@news.povray.org>
Hello Ingo,
I've known OF you for quite some time by reputation, but haven't had the
pleasure of corresponding with you directly.  It's good to see that you still
make it by here from time to time.
I've noticed the meshmaker in the past, but never had time to investigate it.
Thanks for the tip - I'll look into it along with everything else I'm juggling
(no worries about the email)
Date: 14 Sep 2016 13:05:00
Message: <web.57d9832b5c93b6e6b488d9aa0@news.povray.org>
In an unrelated search I came across Mike William's code that he posted here:
http://203.29.75.35/povray.general/thread/%3Cweb.4864e13d83231c9ec59235590@news.povray.org%3E/?ttop=333125&toff=400
(answering part of my original question)
Two things struck me as I played with the code last night (don't worry - I was
not injured  ;) )
1)  Using the original #version 3.5, I got a very dim image.   I wondered why he
was using "rgb 4" in the colour_map.  When I edited that to #version 3.7, it got
MUCH brighter / whiter
2)  I would have probably tried to achieve something like this with a vertical
color map applied as a y-gradient pigment.
Surprisingly, Mike's method of implementing the contour lines seems to be
completely orthogonal to that, and instead uses the x&z components of the
function to generate vertical "cylinders" which are visible at the "y-surface"
of the isosurface.   Ingenious and unexpected.
I had some fun converting this to a noise-perturbed sphere, and then getting the
contour / isobar / isometric lines to be spherical shells as well.
But that process also highlighted the fact that I often have a hard time getting
a clear understanding of how certain functions work, and how their values play
out in 3D space.
While the isosurface documentation is clear and easy to _follow_, I think I
require a bit more instruction and learning to be able to create certain
constructs from scratch.
I'm currently having a devil of a time getting this converted to 3.7 syntax:
http://news.povray.org/povray.general/message/%3ChKu%24tCAgdR04EwN%24%40econym.demon.co.uk%3E/#%3ChKu%24tCAgdR04EwN%24%
