POV-Ray : Newsgroups : povray.advanced-users : How to address last 2 components of 5-component vectors? Server Time
15 Mar 2026 09:54:31 EDT (-0400)
  How to address last 2 components of 5-component vectors? (Message 41 to 46 of 46)
Subject: Re: How to address last 2 components of 5-component vectors?
Date: 10 Jul 2016 17:15:00
Message: <5782bad4$1@news.povray.org>
Am 10.07.2016 um 20:32 schrieb William F Pokorny:
> I think I generally understand the promotion and demotion going on when
> colors are expected and we have various floats or vectors as the
> starting point/right-hand-argument.
> When I originally questioned the line:
> [ rgbft ] <5_Term_Vector> |
> it was because our saying rgbft was optional per the brackets in just
> the five term vector case did not make sense to me for a syntax
> specification.
> That "...the missing terms are automatically created from existing input
> when needed" is the point.
> The rgb string is also optional for a float and multiple vector
> specifications. Why is it we are not showing the user it is optional
> with brackets as in [rgb], but doing it for rgbft and the 5 term vector
> case?
Because this allows to put a bit of semantic information between the
lines: If none of the colour keywords is specified at all, behaviour is
as if `rgbft` was used.
The only sensible alternatives (and the ones most closely matching the
actual internal processing) would be to specify either
COLOR_VECTOR:
     rgb <3_Term_Vector>    |
     rgbf <4_Term_Vector>   |
     rgbt <4_Term_Vector>   |
     rgbft <5_Term_Vector>  |
     srgb <3_Term_Vector>   |
     srgbf <4_Term_Vector>  |
     srgbt <4_Term_Vector>  |
     srgbft <5_Term_Vector> |
     <5_Term_Vector>
which loses that between-the-lines information about the semantics, or
COLOR_VECTOR:
     [ rgb | rgbf | rgbt | rgbft | srgb | srgbf | srgbt |
     srgbft ] VECTOR
which discards even more information about the semantics.
Date: 11 Jul 2016 08:13:48
Message: <57838d7c$1@news.povray.org>
>> case?
> COLOR_VECTOR:
>       <5_Term_Vector>
> COLOR_VECTOR:
>       srgbft ] VECTOR
Alright. Thanks everyone for the time spent due my question.
Bill P.
Date: 16 Jul 2016 08:50:01
Message: <web.578a2ce4ff0686005e7df57c0@news.povray.org>
> No error for that page, as it is a page about function{}. Just you cannot use .hf
outside of function{}.
Sorry to keep this thing going for this long, but perhaps someone can post some
working code to clarify HOW to use .hf "IN" (a) function.
I tried to implement the (partial) example code on the referenced documentation
page by issuing the directive:
#debug concat( "fn_Pigm(1, 2, 3).hf  = ", str(fn_Pigm(1, 2, 3).hf, 3, 0),
"\n\n")
[ At first I used it literally, as:
#debug concat( "fn_Pigm().hf  = ", str(fn_Pigm().hf, 3, 0), "\n\n")
even though I expected, and got, an error:
....VectorComponents.pov" line 44: Parse Error: Expected 'numeric expression', )
found instead
so the docs should clarify the need for a vector argument]
and got:
.... VectorComponents.pov" line 41: Parse Error: Expected 'x, y, z or color
component', undeclared identifier 'hf' found instead
doing:
#declare Pigment =
  agate
  color_map {
   [0 color rgb 0]
   [1 color rgb 1]
  } // end color map
 } // end pigment
#declare fn_Pigm =
function {
pigment {Pigment}
} // end function
I cannot do:
#declare fn_Pigm =
function {
pigment {Pigment}.hf
} // end function
.... VectorComponents.pov" line 41: Parse Error: No matching } in '{', . (period)
found instead
or:
#declare fn_Pigm =
function {
pigment {Pigment.hf}
} // end function
.... VectorComponents.pov" line 41: Parse Error: No matching } in 'pigment', .
(period) found instead
Since so much has been covered and clarified, I just wanted to address this one
last (?) loose thread.
Date: 16 Jul 2016 09:08:16
Message: <578a31c0$1@news.povray.org>
Am 16.07.2016 um 14:47 schrieb Bald Eagle:
> "\n\n")
> .....VectorComponents.pov" line 44: Parse Error: Expected 'numeric expression', )
> found instead
Uh... there is nothing missing in the docs there. fn_Pigm() is a
function, and therefore requires parameters when invoked. Simple as that.
> and got:
> ..... VectorComponents.pov" line 41: Parse Error: Expected 'x, y, z or color
That is to be expected; as mentioned before, '.hf' is only available in
functions.
> I cannot do:
> #declare fn_Pigm =
> function {
> } // end function
You need to do:
#declare fn_Pigm = function { pigment { Pigment } }
#declare fn_Hf = function { fn_Pigm(x,y,z).hf }
The first line declares a pigment function, which returns a colour
(well, actually I think it's a vector; but since I haven't examined the
code closely, I'm not exactly sure).
The second line invokes the function, computes the .hf value from the
resulting colour, and returns it as a scalar.
Date: 17 Jul 2016 03:24:05
Message: <578b3295$1@news.povray.org>
I have an example right at hand. Two steps:
//step 1:
#declare F_HF_00 =
function {
     image_map {
       tga "MyOwn.tga" gamma 1.0
       map_type 0
       interpolate 2
     warp {repeat x}
     warp {repeat y}
     scale 50
     warp {
       turbulence <1.5, 9, 1.5>
       octaves 1 //[6]
       lambda 1  //[2]
       omega 0.2 //[0.5]
     scale 1/50
//step 2:
#declare Landscape =
height_field {
   function 2000, 2000 {F_HF_00(x,y,z).hf}
   //smooth
   translate <-0.5, -0.5, -0.5>
   scale <-1, 1, 1>
   scale <MyScale, 100, MyScale>
   clipped_by {
     box {
       <-0.5, -0.5, -0.5>, <0.5, 0.5, 0.5>
       scale <MyScale, 1, MyScale> * <0.99, 500, 0.99>
Note: The clipped_by line might be necessary to cut out the artefacts
generated by the function at the borders of the height_field.
Date: 20 Jul 2016 02:12:59
Message: <578f166b$1@news.povray.org>
Bald Eagle wrote:
> At first I mis-read the docs and thought I could have 6-component vectors, and
> address them x, y, z, t, u, v.
> I trimmed that to 5, and thought that maybe x, y, z, u, v was the way to go, but
> I should have known better.
> I need to use those last 2 values - what are they called?
> Thanks!
Betcha thought you were asking a totally simple question.  :)
Sherry "Been Doing This For Twenty-Plus Years and Never Cease To Be
Enlightened, Educated, and Amazed" Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
