POV-Ray : Newsgroups : povray.advanced-users : How to make Elliptical Hyperboloid and paraboloid Server Time
14 Mar 2026 12:56:43 EDT (-0400)
  How to make Elliptical Hyperboloid and paraboloid (Message 1 to 5 of 5)
Subject: How to make Elliptical Hyperboloid and paraboloid
Date: 4 Aug 2015 01:50:01
Message: <web.55c051fd5b0c230128e16ee0@news.povray.org>
I'm trying to make a elliptical hyperboloid like
http://img.ctrlv.in/img/15/08/04/55c051410afa4.png
and
paraboloid like
http://img.ctrlv.in/img/15/08/04/55c0511271b75.png
As I was searching on POV-Ray I got
http://www.povray.org/documentation/view/3.6.1/471/
Is there a good way to draw these two? Is there any macro for these?
Be yourself and make others happy :)
Feeler
Subject: Re: How to make Elliptical Hyperboloid and paraboloid
Date: 4 Aug 2015 03:49:36
Message: <55c06e90$1@news.povray.org>
> and
> paraboloid like
no real need of macro, your two objects are basic quadric.
If you get the equations for them, the transcription is easy
http://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_5_3_6
For instance, a paraboloid on y axis, with circular base is
quadric { < 1, 0, 1> , <0, 0, 0>, < 0, -1 , 0>, 0 }
(To reverse it's direction, toggle the minus sign.
To translate it along the y axis, change the single 0 at the end.)
An hyperboloid can have 2 forms: one with a single surface (sheet),
another with two sheets.
http://mathworld.wolfram.com/Hyperboloid.html
http://mathworld.wolfram.com/EllipticHyperboloid.html
quadric { < a2, b2, -c2> , <0,0,0>,<0,0,0>, -1 }
for an hyperboloid along z axis (a2, b2 and c2 being the squared
coefficients of the reference ellipsoid)
Date: 4 Aug 2015 23:20:01
Message: <web.55c1804523fc98f43a54b22b0@news.povray.org>
> > and
> > paraboloid like
Thanks a lot. Its very helpfull to me. But these quadric equations formed
infinite hyperboliod and peraboloid. Is there a way to limit these to.
I have a starting point and a height point i.e. I have to make it between these
two point, is it possible?
Date: 5 Aug 2015 01:28:33
Message: <55c19f01@news.povray.org>
you can add the object modifier "clipped_by { ... }" to limit the region
of space in which an object such as a quadric is to be present.
for the paraboloid, the easiest value for ... is a plane (remember that
povray's plane are not just an infinite surface, it's also an infinite
volume splitting the universe in two).
You "just" have to position the plane at the "height point", with the
normal away from the starting point.
For the hyperboloid, a box is probably what you are expecting. The
delicate part is to compute the two corners from your two points.
(that's easy is the hyperboloid is along the axis, it becomes less easy
if it is rotated in the formula itself)
quadric { < 1, 0, 1> ,< 0, 0, 0>,< 0, -1, 0>, 0
    clipped_by { y, 4 }
Date: 5 Aug 2015 01:28:58
Message: <55c19f1a$1@news.povray.org>
>     clipped_by { plane { y, 4 } }
