POV-Ray : Newsgroups : povray.advanced-users : Height field old style? Server Time
29 Jun 2024 02:15:22 EDT (-0400)
  Height field old style? (Message 1 to 8 of 8)
Subject: Height field old style?
Date: 31 Jan 2014 14:45:00
Message: <web.52ebfc19f1b27a0714d2732a0@news.povray.org>
I came across a file with a height field given in the following manner:
#declare Coul= pigment { color rgb <0.4,0.2,0>}
height_field {
    pattern 100,100 {
        hf_gray_16
        cylindrical color_map { [0 rgb 0] [1 rgb 1] }
        translate 1
        scale .3
    //smooth
    pigment {Coul}
    clipped_by {plane {-y,-.05}}
    scale <5,2,5>
POV gives an error about "pattern":
Parse Error: Expected 'map file spec', pattern found instead
but I could not find the way to produce a height field without a GIF or PNG, or
a function. Is there a way to correct or convert the above lines?
Subject: Re: Height field old style?
Date: 31 Jan 2014 15:28:35
Message: <52ec0773$1@news.povray.org>
Le 31/01/2014 20:40, Franz von Dardel nous fit lire :
> height_field {
>     pattern 100,100 {
>         hf_gray_16
>         translate 1
>         scale .3
>     //smooth
>     pigment {Coul}
>     scale <5,2,5>
Does not seems to have ever been a valid povray official syntax.
Yet, might be some patch/extensions.
Does not seems to appear in megapov 1.2.1 (latest)
Or missing some lines ?
Traditional usage of pattern in height field requires to use function.
Such as:
#declare P1=function{pattern{leopard
   turbulence 0.3 scale 0.05}}
#declare P2=function{pattern{crackle
   turbulence 0.3 scale 0.7}}
#declare P=function{P1(x,0,z)*0.3 +P2(x,0,z)}
height_field{function 300,300 {P(x,0,y)}
  translate <-0.5,0,-0.5> ...
Date: 31 Jan 2014 15:31:29
Message: <52ec0821$1@news.povray.org>
Am 31.01.2014 20:40, schrieb Franz von Dardel:
> height_field {
>      pattern 100,100 {
>          hf_gray_16
>          translate 1
>          scale .3
>      //smooth
>      pigment {Coul}
>      scale <5,2,5>
I think this should do the job (untested):
height_field {
      function 100,100 { pigment {
          hf_gray_16
          translate 1
          scale .3
Date: 31 Jan 2014 22:08:10
Message: <52ec651a@news.povray.org>
>> height_field {
>>      pattern 100,100 {
>>          hf_gray_16
>>          translate 1
>>          scale .3
>>      //smooth
>>      pigment {Coul}
>>      scale <5,2,5>
>> or PNG, or
> height_field {
>           hf_gray_16
>           translate 1
>           scale .3
I'm not sure about the hf_gray_16 in this context... Maybe it just does
nothing.
Up to version 3.6.x, it was to be used in the global_settings block to
output the image as a 16 bits gray level image.
With version 3.7, you use a command line switch to do the same.
Date: 1 Feb 2014 06:40:00
Message: <web.52ecdcad94a3ffcb14d2732a0@news.povray.org>
> >> height_field {
> >>      pattern 100,100 {
> >>          hf_gray_16
> >>          translate 1
> >>          scale .3
> >>      //smooth
> >>      pigment {Coul}
> >>      scale <5,2,5>
> >> or PNG, or
> > height_field {
> >           hf_gray_16
> >           translate 1
> >           scale .3
> nothing.
I have tried function instead of pattern. Doesn't work. It (logically) expects a
function.
Date: 1 Feb 2014 07:57:32
Message: <52ecef3c$1@news.povray.org>
pattern 100, 100
feels vaguely familiar to me, something from the deep past maybe, but I
cannot find any file in my 15 years old archives that uses this
configuration.
However, searching the web, I came across this:
http://www.cs.trinity.edu/~jhowland/class.files.cs357.html/pov-new/MegaPOV/demos/textures/patterns/pattern_hf.pov
This clearly refers to MegaPOV 0.4, in 1999. I don't know what that did
in particular compared to POV-Ray back then, but I guess that it was one
of the first possibilities to use functions in a height_field. I do not
have version 0.4 any more so I cannot check.
Comments by Le_Forgeron and Alain are the way to go.
Date: 1 Feb 2014 08:07:14
Message: <52ecf182$1@news.povray.org>
And this is the documentation of pattern found on the same site. Note
the facultative use hf_gray_16.
[quote]
8.4. Pattern Image Type
Author: Ronald L. Parker
pattern Width, Height { [hf_gray_16] PIGMENT }
This keyword defines a new bitmap image type. The pixels of the image
can be derived from any standard pigment. This image may be used
wherever a tga image may be used. Some uses include creating
heightfields from procedural textures or wrapping a 2d texture such as
hexagons around a cylinder (though a better way to do this is with the
new cylindrical warp.)
A pattern statement be used wherever an image specifier like tga or png
may be used. Width and Height specify the resolution of the resulting
bitmap image. The pigment body may contain transformations. If present,
they apply only to the pigment and not to the object as a whole.
This image type currently ignores any filter values that may be present
in the pigment, but it keeps transparency information. If present, the
hf_gray_16 specifier causes POV-Ray to create an image that uses the TGA
16-bit red/green mapping.
Example:
#declare QuickLandscape =
height_field {
   pattern 200,200 {
     hf_gray_16
     bozo
     color_map {
       [0 rgb 0]
       [1 rgb 1]
[/quote]
Date: 1 Feb 2014 17:28:09
Message: <52ed74f9$1@news.povray.org>
Am 01.02.2014 12:38, schrieb Franz von Dardel:
>>> height_field {
>>>            hf_gray_16
>>>            translate 1
>>>            scale .3
>> nothing.
> function.
Then try this one:
#declare MyFn = function { pigment {
   translate 1
   scale .3
height_field {
   function 100,100 { MyFn(x,0,z) }
or, maybe:
height_field {
   function 100,100 { MyFn(x,0,z).red }
