POV-Ray : Newsgroups : povray.advanced-users : Lightning Server Time
29 Jun 2024 14:57:41 EDT (-0400)
  Lightning (Message 11 to 13 of 13)
Subject: Re: Lightning
Date: 20 Oct 2013 11:55:01
Message: <web.5263fbabb67aff75850a064a0@news.povray.org>
"MichaelJF" <mi-### [at] t-onlinede> wrote:
> > I am curious to see what you can achieve. I have not tested Rune's code
> > in a lightning setting. Maybe it is not good for that. If time allows, I
> > shall have a few experiments.
> > Thomas
> May be I will use them as a comparison later. First I will test the other
> approach. If you will try the sample files be sure to add assumed_gamma 1 to the
> scene. Without I saw nearly nothing.
> Michael
Meanwhile I have implemented the first stage to construct a "leading" bolt (in
2D). The approach is very slow but first results looked promising. But now I
have to find a work around to compensate for the very high epsilon POV uses.
With a 64bit machine 1.69851e-013 is not zero, but POV treats it so. POV-eps
seems to be somewhere at 1.0e-5 or 1.0e-6 which is unacceptable completely
nowadays. I and others have experienced problems with this historical setting in
the past. Most likely one only has to change a constant within a header file but
no one dares to do so. And the problem is known...
Sorry, I'm a little bit frustrated having lost a days work due to this issue.
Take it serious but not too serious ;-) May be there more dependencies I cannot
judge.
Best regards,
Michael
Date: 20 Oct 2013 14:06:17
Message: <52641b99@news.povray.org>
>>> Thomas
>> Michael
> judge.
> Best regards,
> Michael
The epsilon value for 32 and 64 bits CPUs is the same as both have 64
bits FPUs.
The epsilon value used by POV-Ray is larger due to some conciderations,
like the need to raise some values to the third power in several places,
and some times even more, 1e-6^ 3 = 1e-18...
Date: 21 Oct 2013 11:35:01
Message: <web.526548d7b67aff75ff146f9f0@news.povray.org>
Thanks for the explanation, I feared for that. Meanwhile I remedied my issue
with additional storage and premultiplying all values concerned a little bit. As
far as I can judge so far, this approach can yield a fine result in 2D with POV
but one needs a lot of patience since only a brute force algorithm can be
implemented with POV. In 3D one will need a compiler and pointer structures to
overcome the space and time requirements.
Best regards,
Michael
