![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How do you control the density of a medium at a given point?
For instance, if you use a spherical pattern then the medium is fully opaque at
the center of the sphere, and is fully transparent at the outer radius.
BUT, what if I want the sphere to be 25% transparent at 1/3 of the distance from
the center?
How do I control that?
Thanks!
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the center?
> Thanks!
> Mike
Hi Mike,
you can use color_maps or density_maps within the media. Something like this:
media{
emission 0.75
scattering {1, 0.5}
density { spherical
density_map {
[0.0 rgb 0]
[2/3 rgb 1]
[1.0 rgb 1]
Best regards,
Michael
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"MichaelJF" <mi-### [at] t-online de> wrote:
> Hi Mike,
> media{
> emission 0.75
> scattering {1, 0.5}
> density { spherical
> density_map {
> [0.0 rgb 0]
> [2/3 rgb 1]
> [1.0 rgb 1]
> Best regards,
> Michael
Are you sure? I thought color maps are just for changing the color of the media
at different densities, and density maps are for using multiple pre-defined
densities.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wouldn't it be better to define a new function instead of messing with the
color/density maps?
Something like this maybe (I'm still working on the ringworld project):
density
function {1-f_cylindrical(x,y,z)}
But how would I rewrite the function for my scene if:
1. the radius of the habitat ring is equal to "ring_radius" and the height of
the atmosphere is equal to "atmosphere_height"
2. the atmosphere should have 0 density at the top and some arbitrary low value
like 10% at the ring surface.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Hi Mike,
>> media{
>> emission 0.75
>> scattering {1, 0.5}
>> density { spherical
>> density_map {
>> [0.0 rgb 0]
>> [2/3 rgb 1]
>> [1.0 rgb 1]
>> Best regards,
>> Michael
> densities.
You can use a density map to control how dense the media will be, like
Michael shows. A density map interprets the grey values. rgb 0 is
transparent; rgb 1 is opaque. If you use colours, they are interpreted
as grey values.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Better to have a complete example:
background { rgb 1 }
camera { location <3,4,-5>*.8 look_at 0 angle 35 }
light_source { <20,40,10>, 1 }
box // floor
{ <-1.5,-1.01,-1.5>, <1.5,-1.2,1.5>
pigment { checker rgb 0.75, rgb 0.25 scale 0.2 }
box
{ -1,1 pigment { rgbt 1 } hollow
interior
{ media
{ scattering { 1, 0.5 }
density {
gradient y
color_map {
[ 0 rgb 1 ]
[ 1/3 rgb 1 ]
[ 2/3 rgb 0 ]
[1 rgb 0 ]
scale 2
translate -y
cylinder
{ <0.9, -1, 0.7>, <0.9, 0.9, 0.7>, 0.5
pigment { rgb <1, 0.8, 0.5> }
This is a modification of the demo-scene from the POV-documentation. I added
only the density (scaled and translated to meet the scene). As you can see,
there is no density at the top third, increasing to 1 at the bottom third.
Best regards,
Michael
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
