POV-Ray : Newsgroups : povray.advanced-users : Rendering wet sponge Server Time
9 Jan 2025 18:17:41 EST (-0500)
  Rendering wet sponge (Message 1 to 5 of 5)
Subject: Rendering wet sponge
Date: 15 Aug 2011 09:40:00
Message: <web.4e492118fde8c643e30a4f6b0@news.povray.org>
I need to render wet sponge something like this
http://www.stanford.edu/~patkar/lenaerts.JPG
The sponge is a triangle mesh (surface mesh). I have a dry sponge texture and I
am using povray's mesh with uv mapping for rendering dry sponge. Now I need to
render some of the tringles darker depending on how wet they are. Is there a way
to do it without modifying the texture file?
I am using c++ to generate the povray file. The information I have is the list
of triangles, u,v coordinates of each triangle and degree of wetness of each
triangle. I do not want to modify the texture file because I have to do this for
100's of frames to get an animation.
Can someone help?
Thanks,
Saket
Subject: Re: Rendering wet sponge
Date: 15 Aug 2011 11:35:02
Message: <4e493ca6$1@news.povray.org>
Le 15/08/2011 15:37, Saket nous fit lire :
> Hi,
> Can someone help?
Just an idea: keep the sponge dry and add filtering/transmitting spheres
based on wetness.
If dry->wet darkens, a normal filtering is fine. (range 0 to 1)
If dry->wet lighten, you need a filtering factor which multiply the
actual colour.
If the triangle mesh was open to update with its own texture (no need to
UV map), it would be a simpler issue of using a palette of texture based
on wetness.
Date: 16 Aug 2011 02:35:00
Message: <web.4e4a0e786cc3925c420ab3060@news.povray.org>
> based on wetness.
> actual colour.
> on wetness.
Thanks for the reply.
As to your first point are you suggesting adding filtering spheres outside every
wet triangle?
Can you explain your last point?
I was planning to generate a filtering texture every frame and layer it over the
sponge texture, but povray wouldn't allow layering over an image map.
Saket
Date: 16 Aug 2011 04:40:08
Message: <4e4a2ce8$1@news.povray.org>
>> based on wetness.
>> actual colour.
(actually, that would be a transmit factor > 1)
>> on wetness.
> Hi,
> wet triangle?
I'm dumber. outside every wet vertex. (yes, a lot of tiny spheres!)
You need to raise max_trace_level a lot if not using version 3.7;
Mesh can have a texture per vertex (see the mesh2 syntax).
> mesh2 {
>    vertex_vectors {
>       9,
>       <0,0,0>, <0.5,0,0>, <0.5,0.5,0>,
>       <1,0,0>, <1,0.5,0>, <1,1,0>
>       <0.5,1,0>, <0,1,0>, <0,0.5,0>
>    texture_list {
>       3,
>       texture{pigment{rgb <0,0,1>}}
>       texture{pigment{rgb 1}}
>       texture{pigment{rgb <1,0,0>}}
>    face_indices {
>       8,
>       <0,1,2>,0,1,2,  <1,3,2>,1,0,2,
>       <3,4,2>,0,1,2,  <4,5,2>,1,0,2,
>       <5,6,2>,0,1,2,  <6,7,2>,1,0,2,
>       <7,8,2>,0,1,2,  <8,0,2>,1,0,2
Assuming you start with a dry mesh with a texture list of 10 textures,
and you have 20 degrees of wetness (per dry texture),
the dry-mesh with 10 textures would transform into a dry-and-wet-mesh
with 200 textures.
On the specification of the face_indices, your program would simply put
the right texture index according to the original mesh and the wetness.
Date: 16 Aug 2011 09:05:01
Message: <web.4e4a6ad96cc3925cdb59c7120@news.povray.org>
> with 200 textures.
Thanks,
Mesh2 worked perfectly.
Saket
