POV-Ray : Newsgroups : povray.advanced-users : About Crevice Grime - Feature Request Server Time
11 Oct 2025 10:20:53 EDT (-0400)
  About Crevice Grime - Feature Request (Message 1 to 3 of 3)
Subject: About Crevice Grime - Feature Request
Date: 13 Mar 2011 17:15:01
Message: <web.4d7d32d6f7de3da4cdaada170@news.povray.org>
I'd thought about this a long time ago when I was writing my proximity pattern
code: programs like Meshlab can colour polygons based on lots of functions,
including ambient occlusion.
What What POV is missing (as far as I'm aware) is the ability to extract the
colour of a polygon and use it as a pigment. If I have a model that has each
polygon with a grayscale value based on something like AO, I'd like to be able
to use that gray value in a pigment_pattern to drive POV's more sophisticated
pigment code (grime in crevices, damage on exposed edges etc).
Does that make sense? Have I explained it clearly?
Subject: Re: About Crevice Grime - Feature Request
Date: 14 Mar 2011 02:38:15
Message: <4d7db7d7$1@news.povray.org>
Am 13.03.2011 22:10, schrieb Edouard:
If I understand your request correctly, that feature already exists: It
is called "mesh camera". It will still require two render passes, but
should do what you want.
Note however that this is a limited solution, as it can be used for mesh
objects only.
Date: 14 Mar 2011 06:31:31
Message: <4d7dee83$1@news.povray.org>
   Yes, indeed... the mesh texture can be easily baked as a grayscale
image, which can be used then in several ways with POV-Ray textures. I
did some tests with "pseudo-AO" which were interrupted by Real Life:
http://www.ignorancia.org/uploads/tools-and-objects/mesh_camera/baking_demo_ao_bronze-verdi.jpg
http://www.ignorancia.org/uploads/tools-and-objects/mesh_camera/baking_demo_ao_marble-verdi.jpg
http://www.ignorancia.org/uploads/tools-and-objects/mesh_camera/baking_demo_ao_copper.jpg
> objects only.
   Which is just what Edouard requested... :)
Jaime Vives Piqueres
