POV-Ray : Newsgroups : povray.advanced-users : Find exact position of a rotated camera Server Time
10 Jan 2025 01:26:04 EST (-0500)
  Find exact position of a rotated camera (Message 1 to 3 of 3)
Subject: Find exact position of a rotated camera
Date: 5 Jan 2011 07:00:01
Message: <web.4d245c4e38cab2dfcaf4e69e0@news.povray.org>
Hi all!
I need to find the exact position of a translated and rotated camera. Imagine a
sphere and a camera that points to it (with look_at to <0,0,0>, the center of
the sphere) with camera location at <0,0,-15000> and that then has been rotated
by +60 degrees in the x axis. What I need to find is the location vector of the
camera.
In fact I need the location vector of the camera to make a trace() on the
Any ideas will be welcome.
Please try to send me an email.
Thanks in advance!
CVADRAT
Subject: Re: Find exact position of a rotated camera
Date: 5 Jan 2011 08:00:00
Message: <web.4d246a3c780a807ec9c2a02e0@news.povray.org>
vrotate() should do the trick:
vrotate(A,B)
Rotate A about origin by B. Given the x,y,z coordinates of a point in space
designated by the vector A, rotate that point about the origin by an amount
specified by the vector B. Rotate it about the x-axis by an angle specified in
degrees by the float value B.x. Similarly B.y and B.z specify the amount to
rotate in degrees about the y-axis and z-axis. The result is a vector containing
the new x,y,z coordinates of the point.
In your example, the new location can be found by calling vrotate(<0,0,-15000>,
<60,0,0>).
Regards Roman
"CVADRAT" <lud### [at] cvadratcom> wrote:
> Hi all!
> camera.
> Thanks in advance!
> CVADRAT
Date: 20 Feb 2011 16:40:00
Message: <web.4d618925780a807ec734aecd0@news.povray.org>
> Hi all!
> camera.
> Thanks in advance!
> CVADRAT
You might want to try the code below.
Tor Olav
http://subcube.com
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#include "transforms.inc"
#declare Sphere =
  sphere {
    <0, 0, 0>, 500
    pigment { color White }
#declare pCameraLocation = <0, 0, -1500>;
#declare pCameraLookAt = <0, 0, 0>;
#declare Camera =
    location pCameraLocation
    look_at pCameraLookAt
// This should work as long as there is no uneven scaling
#declare CameraTransform =
  transform {
//    translate 400*y
    rotate 60*x
#declare NewCamera =
    Camera
    transform { CameraTransform }
#declare pNewCameraLocation =
  vtransform(
    pCameraLocation,
    CameraTransform
#declare pNewCameraLookAt =
  vtransform(
    pCameraLookAt,
    CameraTransform
#declare vNewCameraDirection =
  pNewCameraLookAt - pNewCameraLocation;
#declare vNormal = <0, 0, 0>;
#declare pIntersection =
  trace(
    Sphere,
    pNewCameraLocation,
    vNewCameraDirection,
    vNormal
background { color Blue/2 }
light_source { <100, 2000, -1000>, color White }
object { Sphere }
#if (vlength(vNormal) > 0)
  sphere {
    pIntersection, 10
    pigment { color Orange }
#else
  #debug "\n"
  #debug "No intersection"
  #debug "\n"
#end // if
//  Camera
  NewCamera
