I want to build a prism from an extruded polygon. I have a set of points in 3D
that represent the polygon boundary, they should all lie on the same plane. I
would guess this problem is encountered frequently. Is there a pre-existing a
macro that would find the average normal (to remove numerical noise) and
generate the transform matrix.
So, given a set of 3D points generate the polygon on the floor, extrude it, and
transform so it sits in space correctly.
I know how to do the math, just hoping someone has something pre-tested.
Thanks
"tensor" <nomail@nomail> wrote:
> Hi,
> Thanks
Cancel this request. Thanks anyway. I'll write the macro myself, was hoping for
something quick.
Thanks
Subject: Re: Looking for a macro to transform a set of coplanar points
Date: 11 Jun 2010 12:20:36
Message: <4c126254$1@news.povray.org>
> Hi,
> Thanks
If all your points lies more or less on a reference plane, like the x-z
plane, you can just remove the Y component:
#declare Point2D=<Point3D.x, point3D.z>
