POV-Ray : Newsgroups : povray.advanced-users : Enabling relative coordinate placement Server Time
18 Nov 2025 04:35:57 EST (-0500)
  Enabling relative coordinate placement (Message 1 to 10 of 16)
Subject: Enabling relative coordinate placement
Date: 20 Sep 2009 12:40:00
Message: <web.4ab65a2cf8370660772dd76f0@news.povray.org>
Hi:
I am building a set of macros and hopefully functions that can assist an
architect in making a building using POVRay. I understand that I cannot export
2D technical sections of the resulting design but my hopes are that if I can cut
3D sections of the building, then I can wait until POVRay can support the
process more.
My hitch right now is that I cannot enable relative coordinate placement.
It is important to be able to create an object relative to the position of
another in architecture. For example a wall can be created with coordinates
<0,0,0> <150,8000,3000> (thickness = 0.15 m, length = 8 m, height = 3 m) then
rotated to 35 degrees and translated to <5000,1000,0>. It must be possible to
create a second wall at a relative position and angle to this one without having
to do the necessary calculation from the origin. For a professional activity the
work of redoing calculations each time a design is updated or reconfigured is
very frustrating, error-prone and time-consuming.
A macro can be created to automatically create the wall with the required
thickness, length, height, rotation and final position.
for example:
#declare BedRm_North_Wall = Make_Wall( Length, Height, Thickness, Rotate_Angle,
Translate_Distance )
These are my questions:
1. Ability to create new object by referencing the location of another. The
placement of the new object is a distance or angle relative to the existing
object. For example to create a new wall by referencing the position of
BedRm_North_Wall
   - #declare BedRm_South_Wall = Make_Wall_Offset( BedRm_North_Wall, New_Length,
New_Height, New_Thickness, Offset_Distance )
2. Functions in a macro or that can get information from a macro
   I would like to be able to perform actions on a declared object. For example
instead of rotating and/or translating when they are created, these actions can
be performed afterward for example
   - #declare BedRm_North_Wall = Make_Wall( Length, Height, Thickness )
   - BedRm_North_Wall_Rotate( angle )
   - BedRm_North_Wall_Offset( offset_distance )
An option would be to write a new (text-based) tool to interface with POVRay
which may be necessary. But if I can do the above I will rather get work done
with the wonderful existing POVRay SDL.
Subject: Re: Enabling relative coordinate placement
Date: 20 Sep 2009 12:56:14
Message: <4ab65eae$1@news.povray.org>
> BedRm_North_Wall
Definitely not possible in POV-Ray, unless you write your own framework
(i.e. basically place another language on top of SDL) to do this sort of
things.
you can define macros as:
   #macro Rotate_Object(Obj,Angle)
     object { Obj rotate Angle }
which you could then use like this:
   Rotate_Object ( BedRm_North_Wall, angle )
Date: 20 Sep 2009 13:30:00
Message: <web.4ab6655fba1022f6772dd76f0@news.povray.org>
> > BedRm_North_Wall
> things.
>    #end
Supposing the object has been translated to <1500,8000,0> my guess is that the
rotation you describe above will no longer work as expected. The wall has to be
rotated when created at <0,0,0> before being moved. Right?
Date: 20 Sep 2009 13:32:24
Message: <4ab66728@news.povray.org>
  If the object is already at <1500,8000,0>, then what you can do is simply:
translate -<1500,8000,0>
rotate whatever
translate <1500,8000,0>
Date: 20 Sep 2009 13:40:01
Message: <web.4ab66809ba1022f6772dd76f0@news.povray.org>
> > > BedRm_North_Wall
> > things.
> >    #end
OK I think I see you have done what I am saying. Thanks.
It looks like for the first question I have to implement a go-between script.
Date: 20 Sep 2009 16:10:04
Message: <4ab68c1c@news.povray.org>
"Kene" <nomail@nomail> wrote in message
news:web.4ab65a2cf8370660772dd76f0@news.povray.org...
> Hi:
> export
> can cut
> process more.
I've done a few similar things. I used a somewhat different approach some
time ago, using Inkscape to draw floor plans in the SVG 2D vector graphics
format. That uses POV-Ray macros to use the prism objects that Inkscape can
export to create the corresponding buildings. See
http://www.geocities.com/povstairs/povhouse/ for the sort of things it was
able to do.
If you prefer to work directly in POV-Ray, you can certainly generate
cross-sections through a building using CSG (as illustrated in the
documentation accompanying the site above). For example, you could take a
thin slice through a union of all the walls, place a flat plane beneath it
(with a grid pattern drawn on it) and use an orthographic camera to 'draw'
the floor plan.
POV-Ray does have some features that make this sort of thing fairly
straight-forward once you're familiar with the syntax and constructs. I
wouldn't wish to overstate the ease with which this can be done as it's a
lot of work, but your post implies that you're looking to invest a fair bit
of time, so getting a straight-forward standardised approach at the outset
is probably a good starting point.
One feature that I would consider important is the array syntax which allows
you to store arrays of objects, text strings, transformations etc. The other
is the 'transform' syntax which means you can easily store transformations
and read them back later so that you can accumulate or reverse (inverse)
them.
With a bit of careful design, you can set up an array to hold the component
parts of the building, a corresponding array to hold the transformation and
as many other arrays as you feel you need to index these two main arrays.
One of the indexing arrays can hold the name of the component, so that, once
declared, you can use the name of the object to refer to it instead of
having to remember the indices. This also makes your code more readable.
You can add other indexing information as you require, for example you could
add an indicator to show if it's part of the walls, the roof, the floors or
the furniture (a sort of 'category' classification).
To add a component you would call a macro that increments the array index,
stores the object, the transformation, the component name and the category
etc, passed in as parameters. You can create a simple macro to look up any
previous transformation based upon the component name, so that you can
position a component relative to any component that's already been declared.
You can then have a set of macros to draw your chosen image, whether it be a
3D perspective image or a 2D plan or section. These macros can decide what
to include in the image based on the 'category' array, or on any other
indexing information you choose to implement.
p.s. Once you get to the stage where you're adding detail, you may find the
StairCase macro on the POV-Ray object collection at
http://lib.povray.org/collection/staircase/chrisb%202.0/staircase.html
handy, along with some of the other 'canned' architectural objects (chairs,
tables etc.). Scroll down to see the staircases fitted inside a more complex
architectural structure.
Chris B.
Date: 20 Sep 2009 16:13:59
Message: <4ab68d07$1@news.povray.org>
You might want to look at the LOME program I wrote
http://sourceforge.net/projects/lome/
It isn't SDL macros, but it generates SDL. It might be easier to start with
a custom language that outputs SDL than to try to make SDL easy to use by an
architect.
Date: 20 Sep 2009 16:52:05
Message: <4ab695f5$1@news.povray.org>
> some time ago, using Inkscape to draw floor plans in the SVG 2D vector
> graphics format. That uses POV-Ray macros to use the prism objects that
> Inkscape can export to create the corresponding buildings. See
> was able to do.
Only one more month and it will be gone!
-Mike
Date: 20 Sep 2009 17:59:10
Message: <4ab6a5ae$1@news.povray.org>
"SharkD" <mik### [at] gmailcom> wrote in message
news:4ab695f5$1@news.povray.org...
>> was able to do.
> -Mike
Well I'm glad you pointed that out, I hadn't noticed that geocities was
going.
Chris B.
Date: 21 Sep 2009 01:40:01
Message: <web.4ab710eeba1022f6772dd76f0@news.povray.org>
> > Hi:
> > export
> > can cut
> > process more.
> able to do.
> the floor plan.
> them.
> Regards,
> Chris B.
This is great! Exactly what I was looking for. It sounds like worth the effort
because I wanted to stay with the SDL as much as possible. I will investigate
this instead of creating a new program for now. I am also interested in your
method for floor plans.
I was starting a program that reads a custom SDL and draws simple shapes at the
right location using a split screen of TOP, FRONT and SIDE views as I type. Has
this been done before? I will come back to it later. I think that design is so
much more fun when you can type. Then exports to POVray SDL. Its just like
having a conversation if you know what I mean.
But first I need to get a handle on your idea. Thanks a million!
