POV-Ray : Newsgroups : povray.advanced-users : Create spline Server Time
28 Sep 2024 08:11:49 EDT (-0400)
  Create spline (Message 1 to 10 of 10)
Subject: Create spline
Date: 2 Mar 2009 08:40:03
Message: <web.49abe083a6290068c9ee64130@news.povray.org>
Hi all,
Is there any possibility to write a #macro that returns spline by value? I have
made such macro but I have to pass a parameter to the macro that will be a
place for spline. I excpect something like that:
#declare new_spline = createSpline(myArray);
Now I have to do it like that:
#declare new_spline = 0;
createSpline(myArr, new_spline)
//now I have new_spline initialized
Thanks in advance,
twister
Subject: Re: Create spline
Date: 2 Mar 2009 11:09:46
Message: <49ac04ca@news.povray.org>
  I can't really understand the problem you are having. Care to give an
example of a macro implementation which doesn't work as you want?
Date: 2 Mar 2009 18:05:00
Message: <web.49ac65a5db4d2f97f50167bc0@news.povray.org>
"twister" <twi### [at] o2pl> wrote:
> Hi all,
Could it perhaps be a problem with how you are initially setting up or loading
values into myArray? An array[] starts at location 0, not 1.  Just a thought.
Ken W.
Date: 3 Mar 2009 02:30:00
Message: <web.49acda93db4d2f97cac4259f0@news.povray.org>
> Hi all,
> Thanks in advance,
> twister
I think for whatever reason, splines have to be global in order to return
correctly from inside a macro.  For instance, in my array -> spline macro below,
if you try to return the local spline, POV-Ray will crash:
Charles
//Usage:
//#local MyNewSpline = Spline_From_Array(MyArray,MyArray_Length);
// The_Array should be an array of vectors 4D vectors in the form <x,y,z,t>
// where t is the position value along the spline to be created.
#macro Spline_From_Array(The_Array,Array_Length)
  //POV-Ray crashes if this gets changed to #local:
  #local ATempSpline = spline{
   cubic_spline
   #local Ctr = 0;
   #while (Ctr < Array_Length)
      #local Tempfloat = The_Array[Ctr].t; //avoids error on next line.
      Tempfloat,  <The_Array[Ctr].x, The_Array[Ctr].y, The_Array[Ctr].z>,
     #local Ctr = Ctr+1;
   #end //end while
  //The returned spline must be global or POV-Ray will crash:
  #declare ATempSpline_G = ATempSpline; //create a global variable
  //ATempSpline //Don't return this spline or POV-Ray will crash!
  ATempSpline_G //Return this spline
#end //end #macro Spline_From_Array(The_Array,Array_Length)
Date: 3 Mar 2009 02:35:01
Message: <web.49acdd97db4d2f97cac4259f0@news.povray.org>
Please disregard the comment in the macro:
It's a remnant from before I modified the macro.
Charles
Date: 3 Mar 2009 04:25:01
Message: <web.49acf63adb4d2f97c9ee64130@news.povray.org>
I have created such a #macro:
#macro createSpline(arr, arrSize, name)
  #local length = 0;
  #local i = 0;
  #while(i < arrSize - 1)
    #local length = length + vlength(arr[i+1] - arr[i]);
    #local i = i + 1;
  #local overallLength = length;
  #local length = 0;
  #local i = 0;
  #local sp = spline {
    natural_spline
    0.00, arr[0],
      length/overallLength, arr[i+1],
      #local i = i + 1;
    1.00, arr[arrSize - 1]
  #declare name = sp;
So I can use it in this way:
createSpline(myArr, 5, new_spline)
//here I have new_spline filled with spline object
But my intention is to create a #macro that returns spline by value, not by
parameter as above. I could then use my #macro in this way:
#declare new_spline = createSpline(myArr, 5);
//where myArr is an array with points defining a curve
Question 2: Is there any way (other than using #ifdef command) to check the size
of an array?
Best regards,
twister
Date: 3 Mar 2009 06:27:12
Message: <49ad1410@news.povray.org>
"twister" <twi### [at] o2pl> wrote in message
news:web.49acf63adb4d2f97c9ee64130@news.povray.org...
> by
If you look at Charles'  example (following his sig), you'll see that this
is what it does. Essentially in your example, where you #declare name = sp;
you can simply specify   sp (no quotes, brackets, semicolon etc.).
Alternatively you can just remove the '#local sp =' from in front of the
spline definition and the spline will be returned by the macro.
> the size
> of an array?
dimension_size(arr,1)
Chris B.
Date: 3 Mar 2009 08:00:00
Message: <web.49ad28c5db4d2f97bdc576310@news.povray.org>
Well, the normal procedure for return-by-value from a macro is this:
#macro MyMacro(foo, bar)
  #declare myReturnValue = ...<something complicated>...
  myReturnValue
I don't see why this shouldn't work for splines, too.
> size of an array?
Due to recent discussions, it may not be quite clear what you mean by "size"...
dimension_size(myArray,1) gives you the "official" size of a 1-dimensional
array.
#ifdef(myArray[i]) tests wheter there has actually been a value stored at index
i.
Aside from this, there is nothing. Remember, POV arrays are *not* dynamically
sized; they just might have some elements set to an undefined value (some
"null" value so to speak).
Date: 5 Mar 2009 09:45:00
Message: <web.49afe47cdb4d2f97c9ee64130@news.povray.org>
Thanks to all of you. create_spline macro works fine as I wanted to work.
Due to array size I meant number of elements in the array and for now
dimension_size is enough for me.
Best regards,
twister
Date: 5 Mar 2009 10:35:00
Message: <web.49aff023db4d2f97f567c3de0@news.povray.org>
To efficiently check the "populated size" of an array, you could use #ifdef in a
binary search manner:
#local iLastKnownPopulated = -1;
#local iFirstKnownUnpopulated = dimension_size(MyArray,1);
#while (iLastKnownPopulated + 1 < iFirstKnownUnpopulated)
  #local iMid = int((iLastKnownPopulated + iFirstKnownUnpopulated)/2);
  #ifdef(MyArray[iCenter])
    #local iLastKnownPopulated = iMid;
  #else
    #local iFirstKnownUnpopulated = iMid;
#local PopulatedArraySize = iFirstKnownUnpopulated;
(untested draft)
