POV-Ray : Newsgroups : povray.advanced-users : wrapping height-field around a complex shape Server Time
18 Dec 2025 09:22:55 EST (-0500)
  wrapping height-field around a complex shape (Message 1 to 4 of 4)
Subject: wrapping height-field around a complex shape
Date: 3 Feb 2009 04:45:00
Message: <web.498811b6f0bf7a9c626c89e40@news.povray.org>
i'm trying to wrap several dozens of height-fields around a curved shape
(similar to an S-shape)
how would i go about this?
do i use a spline or an iso-surface? and how do i correct the orientation?
the result should look as if the shape has an irregular "skin" or "hair"
covering the entire (cylindrical) surface
thank you in advance
Subject: Re: wrapping height-field around a complex shape
Date: 26 Feb 2009 14:57:14
Message: <49a6f41a@news.povray.org>
"aelgoa" <wra### [at] gmailcom> wrote in message
news:web.498811b6f0bf7a9c626c89e40@news.povray.org...
Nobody seems to have taken up on this question so I'll give it a shot.
You can use a heightfield as a function in an isosurface so, if you can
define the cylindrical S-shape you want as a function, you may be able to
suitably combine a single heightfield with  the S-shape. Mike Williams'
isosurface tutorial may give you some inspiration for this sort of thing.
I can't think how you'd go about wrapping several dozen height fields around
such a shape because it would be difficult to imagine how you could get them
to mesh together in any sort of a decent way.
If you don't have to use height fields, then there are quite a few hair
growth macros about (there's one on the POV-Ray object collection), so you
may be able to achieve what you want with one of those. You can get an
S-shape using a sphere sweep which you could grow hair out of. If you're
after a sort of skin texture, then you might want to use a mesh object with
a uv-mapped image map to provide the texture.
Chris B.
Date: 26 Feb 2009 19:48:50
Message: <49a73872@news.povray.org>
>> orientation?
> to suitably combine a single heightfield with  the S-shape. Mike
> Williams' isosurface tutorial may give you some inspiration for this
> sort of thing.
> around such a shape because it would be difficult to imagine how you
> could get them to mesh together in any sort of a decent way.
If the curved surface is "cylindrical" meaning it snakes through two
dimensions, but is constant in the third then I can picture it but it
would be quite invovled.
I would picture the surface first as a flat 'ribbon' that is then
adapted to the curve by slicing it into arbitrary tiles that would
correspond to segments along the actual curved surface. Each tile would
correspond to a separate hf used.  The tiles could be laid along the
surface in arbitrary segments for which the anchor points and normals
would be known.  Hf's could be oriented with the normals and translated
to fit the anchor points of each segment.
Each hf could be 'elevated' with a pattern before being translated to
its place on the surface.  The pattern could be made continuous and
coherent at the edges by 'applying' the pattern to the ribbon of hf's
while the 'ribbon' is flat, so to speak, in a primary plane.  To do this
you'd have to translate the pattern, by sucessive tile lengths, in the
plane, before creating the hf with it, since you can only apply the
pattern in the 1 unit box at the origin.  This is doable though a bit
mind bending because if the way the hf function reverses the axis.  Once
the hf is created and scaled if necessary it is oriented and translated
to the receiving curved surface.
The hf would not of course reflect the pattern as it intersects  the
curved surface in space, but rather how it would intersect the primary
plane used along the 'ribbon'.
Date: 27 Feb 2009 00:18:49
Message: <49a777b9$1@news.povray.org>
I posted an example in p.b.images
