POV-Ray : Newsgroups : povray.advanced-users : Implicit loops in function(x,y,z) Server Time
8 Jul 2024 16:24:24 EDT (-0400)
  Implicit loops in function(x,y,z) (Message 11 to 18 of 18)
Subject: Re: Implicit loops in function(x,y,z)
Date: 15 Jul 2008 10:48:04
Message: <487cb8a4$1@news.povray.org>
Warp wrote:
>   The function name, once #declared, is in the SDL namespace, and the SDL
> can call that function. I don't think that's so confusing.
Never thought of it quite like that, that makes a lot of sense.
The distinction, like many other things, becomes largely second nature
once you work with it enough, in my experience.
-The Mildly Infamous Blue Herring
Date: 28 Sep 2008 10:05:01
Message: <web.48df8ec326dbfbf05fa61cfc0@news.povray.org>
Hi all,
after some research, I finally found this discussion which talks about a subject
very close to my problem.
I am currently trying to generate a function that interpolates the values of a
physical parameter from a 3-dimensional array. I have the same kind of error
message as what has been posted here, when I use the following code (my array
is named SapceSample, and it has nx*ny*nz elements):
#declare ExtrapFunc=function(px,py,pz){
.... SpaceSample[floor(px)[floor(py)][floor(pz)] ...;
The error message is:
Parse Error: ... undeclared identifier 'px'.
So I suppose that when POV-Ray hits the '[', it goes back to the SDL language,
as Warp explained in message #4.
Does anyone know any simple means to go round this problem? Is the only solution
to get a continuous representation of my parameter to define nx*ny*nz functions?
Otherwise, I read some things about the 'density_file' and df3 files. It seems
like that kind of stuff could work for my interpolation, but also that it can
only be used in the scattering media. Is it possible to generate a function
from that?
Thanks a lot for your help,
Hibou
Date: 28 Sep 2008 10:25:05
Message: <48df93c1@news.povray.org>
  Currently user-defined functions do not support arrays. I don't think
there's any way around this limitation.
> from that?
  You can create a pattern from a df3 file, and consequently you can create
a pattern function from one. You can then call this pattern function with
spatial coordinates and it will return the value of the df3 at those
coordinates (interpolated).
Date: 28 Sep 2008 16:12:49
Message: <YW$5yiA1P+3IFwhT@econym.demon.co.uk>
Wasn't it CoucouHibou who wrote:
>Hi all,
>a subject
Arrays are always evaluated at parse time, whereas px is only meaningful
at run time.
Inside functions, all you can do with arrays is things like this:
  http://www.econym.demon.co.uk/isotut/arrays.htm
Mike Williams
Gentleman of Leisure
Date: 29 Sep 2008 07:50:01
Message: <web.48e0c02b26dbfbf085d1f9f50@news.povray.org>
  That is what I did eventually. Thanks for your help.
  Hibou
Date: 3 Oct 2008 12:00:01
Message: <web.48e640cf26dbfbf085d1f9f50@news.povray.org>
  Hi again,
  I have a little question now. Concerning the interpolate mode in the
density_file command: type 2 interpolation yields weird results! It creates
some big cubic holes in my pattern function while interpolate 1 is correct. I
thought the tricubic interpolation would be smoother and would not show this
mesh-like effect that we can see on the trilinear interpolation, but it seems
to have other defects that can not be compensated for.
  I do not know if this is normal as I do not know much about interpolation
weaknesses (maybe it is just that I have a tricky function, I actually did not
test this on spiral.df3). This is not crucial to my figure, as I compensate for
the lack of smooth interpolation by a higher resolution in the df3, but I am
just curious about it.
  Thanks for your answer,
  Hibou
Date: 3 Oct 2008 13:24:54
Message: <48e65566$1@news.povray.org>
CoucouHibou nous illumina en ce 2008-10-03 11:57 -->
>   Hi again,
>   Hibou
This is a known bug. When the interpolation encounter a zero, it algorythm
generate some negative values resulting in those ugly artefacts.
A workaround is to have a DF3 file with NO ZERO values, but small values. Then,
you use a color_map to turn those small values to a zero density.
I've tryed spiral.df3 and interpolate 2, and the result is orrible.
If you want to try the 3.7 beta, it should be corrected.
If Barbie is so popular, why do you have to buy her friends?
Date: 3 Oct 2008 18:40:00
Message: <web.48e69e7f26dbfbf05fa61cfc0@news.povray.org>
  OK, thanks, it should be easy for me to generate a .df3 with no 0 value.
Concerning the 3.7 beta 28, I tried to compile it on my lab's computer, but
there were several errors which I could not correct as I do not know C... But
it is no big deal actually, what I have for the moment is really satisfactory.
  Thanks a lot,
  Hibou
