POV-Ray : Newsgroups : povray.advanced-users : object with 2 different ior (doublet of lens) Server Time
14 Mar 2026 21:06:01 EDT (-0400)
  object with 2 different ior (doublet of lens) (Message 1 to 3 of 3)
Subject: object with 2 different ior (doublet of lens)
Date: 23 Apr 2008 15:25:01
Message: <web.480f8bebca4ee21bdcf53ead0@news.povray.org>
Hi
I'm looking to simulate a doublet of lens. I have a problem with photons when I
take the two lens separately. Photons are stopped in the interface.
For now, I'm trying to construct my doublet in one object but I don't know if
it's the best way.
For exemple, this is my lens
#declare lentille = merge
 intersection
  cylinder{<0,0,16>,<0,0,1>,25.4}
  sphere{<0,0,15-83.2>,83.2}
  sphere{<0,0,71.1+3>,71.1}
  hollow
  pigment {Clear } interior { ior n1}
  photons {target reflection off refraction on collect off}
 intersection
  sphere{<0,0,247.7>, 247.7}
  cylinder{<0,0,7.7>,<0,0,-1>,25.4}
  hollow
  pigment {Clear } interior { ior n11}
In this way, are my ior conserved in each part?
Does there another solution?
Thank you
Sylvain
Subject: Re: object with 2 different ior (doublet of lens)
Date: 24 Apr 2008 12:18:18
Message: <4810b2ca$1@news.povray.org>
Sylvain Dubé nous illumina en ce 2008/04/23 15:20 -->
> Hi
> it's the best way.
>  intersection
>   hollow
>  intersection
>   hollow
> Thank you
> Sylvain
"hollow" is totaly, completely and uterly useless in your case, as your lense
don't contain any media.
Make sure that there is a slighy gap between the two components to prevent any
coincident surfaces. Also, make sure that the components never intersect as they
do in your sample. It's unrealistic. The behaviour is also hard to predict.
You don't need to use a merge, a simple union is good enough.
It's beter to place the photons block in the union rather than to each
individual component. If you use the same texture for all element, it's also
beter to place your texture in the union and not in each component definition.
What is your max_trace_level? It default to 5, and your doublet counts 4
surfaces. If your photons ever encounter even 1 surface prior to entering the
double lense, they won't get out. You must count 2 steps for each transparent
object, one for any reflection and one for the surface that will receive the
photons. If you are unsure, take a larger value than what you guessed, up to 256.
Your solution may be as simple as adding:
global_settings{max_trace_level 7}
Make it the first line of your scene.
I've tested your sample, after moving the elements so that they no longer
overlap, and with max_trace_level of 6.
The provided lense have a prety short focal lenght. Maybe your receiving surface
was set to far away and the photons got to dispersed to still be visible...
You know you've been raytracing too long when you tell stories to your kids that
include stuff like "Once there was a polygon mesh who was very sad because he
was only Gourard shaded."
     -- Taps a.k.a. Tapio Vocadlo
Date: 24 Apr 2008 15:04:37
Message: <4810d9c5@news.povray.org>
Alain napsal(a):
>> Hi
>> photons when I
>> know if
>> it's the best way.
>>  intersection
>>   hollow
>>  intersection
>>   hollow
>> Thank you
>> Sylvain
> lense don't contain any media.
> prevent any coincident surfaces. Also, make sure that the components
> never intersect as they do in your sample. It's unrealistic. The
> also beter to place your texture in the union and not in each component
> definition.
> entering the double lense, they won't get out. You must count 2 steps
> for each transparent object, one for any reflection and one for the
> surface that will receive the photons. If you are unsure, take a larger
> longer overlap, and with max_trace_level of 6.
> surface was set to far away and the photons got to dispersed to still be
> visible...
If you move the objects slightly apart you will get a visible gap. I
think the refraction works this way: It remembers the objects it is in
and uses the IOR of the last object entered and not escaped. Not sure
how this applies to a union but merge will cause problems.
the ultimate time-killer:
+a0.0 +am2 +r9
Johnny D
