POV-Ray : Newsgroups : povray.advanced-users : normal to spline Server Time
27 Mar 2026 08:48:53 EDT (-0400)
  normal to spline (Message 1 to 9 of 9)
Subject: normal to spline
Date: 9 Apr 2008 11:10:01
Message: <web.47fcdb6ee879b19f5245d3740@news.povray.org>
is there a way to find the normals to a (non-linear) spline at calculated
points?
TIA
Steven
Subject: Re: normal to spline
Date: 9 Apr 2008 11:35:00
Message: <web.47fce193e221823ae42298f0@news.povray.org>
"stevenvh" <nomail@nomail> wrote:
> Hi,
> points?
> TIA
> Steven
I would recommend finite differences.  The fist derivative is the tangent.  So
if r(t) is the vector defined by the spline, the first derivative is
dr/dt = ( r(t+eps) - r(t-eps) ) / (2*eps)
t = (dr/dt) / |dr/dt|
where epsilon is some small constant.  So normalize the result and you have a
tangent vector.  At this point all you really need to do is cross the tangent
vector with a random vector and you should have a normal vector.  However, if
you want the normal vector in the direction of the curvature, you need to
calculate the second derivative with a finite difference.  As long as the
spline isn't a straight line this should not be collinear with the tangent:
d2r/dt2 = ( r(t+eps) - 2.0*r(t) + r(t-eps) ) / (eps^2)
The problem is that this won't be perpendicular to the tangent vector.  So the
solution is to define the normal vector by subtracting the component of the
second derivative that lies along the tangent vector.  Then all you have is a
vector that's perpendicular to the tangent vector.  Thus
n = d2r/dt2 - t * vdot( d2r/dt2, t )
n = n / |n|
Let me know if that's not clear enough.  I hope that's right, but someone asked
me this before so I even have an OpenGL demo with NURBS if you're interested.
 - Ricky
Date: 9 Apr 2008 16:25:00
Message: <web.47fd2509e2218235245d3740@news.povray.org>
Hi Ricky,
thanks for the explanation.
I want to place a number of cuboids along a spline path, and rotate them
according to the twisting of the path.
I'll need the tangent as one of the cuboid's axes, but I also need the direction
of curvature to know how the cuboid is to be rotated around the tangent axis.
That's the background.
I've been thinking :-)
Finding the tangent axis is easy: that's r(t+1) - r(t-1), translated to r(t),
right?
Now, as long as r(t-1), r(t) and r(t+1) are not collinear, they define a circle
whose center (c) is the center of curvature in r(t), right? So my normal vector
is r(t) - c(t).
Two points of attention:
1. r(t-1), r(t) and r(t+1) are collinear. In that case I would move c with r,
i.e. c(t) = c(t-1) + r(t) - r(t-1).
2. if the three points are nearly collinear the problem may be ill-conditioned.
I guess I could treat them as collinear if the radius of curvature becomes very
large.
So, what do you think?
As for your OpenGL demo, I have no experience, but I'm interested. Is there a
way on this forum to send you my e-mail address privately?
Again thanks.
Steven
Date: 10 Apr 2008 22:13:48
Message: <47fec95c$1@news.povray.org>
> r(t),
> right?
> circle
> vector
> is r(t) - c(t).
> r,
> ill-conditioned.
> very
> large.
Given three points you can define a plane, so if you take three
close together points from a path you can find the tangent.
Once you have the tangent, you can take a tangent point, and
two points from the path to define a plane that has a normal
in the direction of curve.
This should work in most situations, but may have odd behavior
along a straight line. You may also need to check the direction
of the normal and reverse it if the curve is flipped, though this
sample doesn't seem to misbehave without that sort of check.
#include "math.inc"
#include "transforms.inc"
#default {finish{ambient 0.7}}
// --- camera, lights &
background ------------------------------------------
   location  <0.0, 1, -4.0>
   direction 1.5*z
   look_at   <0.0, 0.5,  0.0>
background {Gray85}
light_source {
  <-30, 30, -30>
  color rgb <1, 1, 1>
macros ---------------------------------------------------------------
#declare Path_Spline = spline {
   natural_spline
   0, <-2,0,0>
   1, <-1,0,0>
   2, <-0.5,0.5,0>
   3, <0,1,1>
   4, <0.5,0.5,0>
   5, <1,0,0>
   6, <2,0,0>
#macro Path_Normal(N, rez)
   #local P1 = Path_Spline(N-rez);
   #local P2 = Path_Spline(N);
   #local P3 = Path_Spline(N+rez);
   #local HPerp = VPerp_To_Plane(vnormalize(P2-P1),vnormalize(P3-P2));
   #local Perp = VPerp_To_Plane(vnormalize(HPerp-P2),vnormalize(P3-P2));
   (Perp)
// show spline
#local C = 0;
#while (C <= 6)
   sphere{Path_Spline(C),0.01 pigment {Yellow}}
   #local C=C+0.005;
// inside of curve
#local C = 0.5;
#while (C <= 5.5)
   #local Perp = Path_Normal(C,0.1);
   sphere {Path_Spline(C)+Perp/10,0.01 pigment{Orange}}
   #local C=C+0.005;
Date: 11 Apr 2008 01:55:00
Message: <web.47fefcf2e2218235245d3740@news.povray.org>
> #include "math.inc"
> camera {
>    direction 1.5*z
> background {Gray85}
> light_source {
>   <-30, 30, -30>
>   color rgb <1, 1, 1>
>    natural_spline
>    0, <-2,0,0>
>    1, <-1,0,0>
>    2, <-0.5,0.5,0>
>    3, <0,1,1>
>    4, <0.5,0.5,0>
>    5, <1,0,0>
>    6, <2,0,0>
>    (Perp)
> #end
> // show spline
> #local C = 0;
> #while (C <= 6)
>    #local C=C+0.005;
> #end
> // inside of curve
> #local C = 0.5;
> #while (C <= 5.5)
>    #local C=C+0.005;
> #end
Thanks, Tim.
While I agree with your code, I'm a bit puzzled by the results.
I changed point 3 of the spline to <0,1,0>, so that the spline lies in the Z=0
plane.
First observation: if the spline lies in the Z=0 plane, so should the orange
locus, but it doesn't. I don't know why.
OTOH the orange curve is discontinuous where you expect it, i.e. at the
inflection points of the spline.
I also would write (P3-P1) instead of (P3-P2) in the calculation of Perp, but
since P1, P2 and P3 are nearly collinear this shouldn't make much difference
(and it doesn't).
Thanks again.
Steven
(Learned this lesson: "VPerp_To_Plane" :-))
Date: 11 Apr 2008 04:51:31
Message: <47ff2693@news.povray.org>
> Thanks, Tim.
> Z=0
> plane.
> orange
Oops, the new point is P2-HPerp, not HPerp...
> but
> difference
> (and it doesn't).
Depending on which order you define the points for HPerp, the
Path_Normal will be on the inside of the curve, or on the outside.
   #local HPerp = VPerp_To_Plane(P1-P2,P3-P2);
   //#local HPerp = VPerp_To_Plane(P2-P1,P3-P1);
   #local Perp = VPerp_To_Plane((P2-HPerp)-P3,P2-P3);
   (Perp)
Date: 11 Apr 2008 12:01:08
Message: <47ff8b44@news.povray.org>
stevenvh nous apporta ses lumieres en ce 2008/04/09 16:20:
> Hi Ricky,
> right?
> is r(t) - c(t).
> large.
> Again thanks.
> Steven
An easy way: use the spline follow macro.
You define a spline, then call the macro with the spline name and a position as
parameters. It returns the coordinate at that point along with the orientation.
There is a sample scene showing it's working and application.
You'll find it in /scene/animation/splinefollow/splinefollow.pov
You know you've been raytracing too long when you prefer bald romatic partners,
because they're easier to model.
John VanSickle
Date: 11 Apr 2008 12:07:31
Message: <47ff8cc3$1@news.povray.org>
> Again thanks.
> Steven
The common way to send an e-mail address on a news group is to obfuscate it. It
often look like:
some.name AT domain DISCARD DOT com
You can also add some trhowaway character in the address. For example, I've
added a single DOT in my user name. Try to send me an e-mail with my address as
it apears, and it will bounce, remove the dot after "electro" and I will receive it.
Please hassle me, I thrive on stress.
Date: 11 Apr 2008 13:15:01
Message: <web.47ff9bfbe221823ae42298f0@news.povray.org>
> right?
I think you pretty much have it, and by now everyone else has pretty much hit
the nail on the head.  Had a small attack of real life these last couple days,
but here's the code anyway, and here's the OpenGL demo:
http://rsreusser.googlepages.com/nurbs3d.tar.gz
Fun to play around with, but not a great example of good coding.  I'm not sure
how to compile that on Windows, although it should be perfectly compatible.  On
Linux or Mac OS X it should be trivial.
 - Ricky
And just for kicks, this one calculates and plots the radius of curvature too:
camera{ location <3.5,2,-3.5> look_at <2.7,0,0> }
plane{y,0 pigment{rgb 1}}
background{rgb 0.5}
light_source{<25,25,-25>, rgb 1
    area_light 10*x,10*y,5,5 circular orient jitter
#declare sp=
    spline {
 natural_spline
 0.0, <0.0, 0,  0>,
 0.2, <1.0, 0.2, 0.5>,
 0.4, <2.0, 0.4,-0.9>,
 0.6, <3.5, 0.2, 1.0>,
 0.8, <4.0, 0.1,-0.3>,
 1.0, <5.0, 0.0, 0.0>
cylinder{0,x,0.01 pigment{rgb x}}
cylinder{0,y,0.01 pigment{rgb y}}
cylinder{0,z,0.01 pigment{rgb z}}
union{
    #declare npt = 100;
    #declare c=0;
    #declare p0 = sp(0.0);
    #declare rad=0.02;
    #while(c<npt)
 #declare tv = c/(npt-1);
 #declare p1 = sp(tv);
 sphere{p0,rad pigment{rgb <tv,0,1-tv>}}
 #if(c>0) cylinder{p0,p1,rad pigment{rgb <tv,0,1-tv>}} #end
 #declare p0=p1;
 #declare c=c+1;
union{
    #declare points = array[4]{0.17, 0.37, 0.61, 0.85}
    #declare eps = 0.0001;
    #declare ncirc = dimension_size(points,1);
    #declare c=0;
    #while(c<ncirc)
 #declare tv=points[c];
 #declare pm=sp(tv-eps);
 #declare p0=sp(tv);
 #declare pp=sp(tv+eps);
 #declare drdt = (pp-pm)/(2.0*eps);
 #declare velocity = vlength(drdt);
 #declare tangent = vnormalize(drdt);
 #declare d2rdt2 = (pp-2.0*p0+pm)/(eps*eps);
 #declare accel = vlength(d2rdt2);
 #declare perp = vnormalize(d2rdt2-vdot(tangent,d2rdt2)*tangent);
 #declare crad = velocity*velocity/accel;
 #declare perp2 = vcross(tangent,perp);
 #declare e1=perp;
 #declare e2=perp2;
 #declare e3=tangent;
 #declare c0=p0+perp*crad;
 torus{crad,rad/2
     matrix < e1.x, e1.y, e1.z,
       e2.x, e2.y, e2.z,
       e3.x, e3.y, e3.z,
       c0.x, c0.y, c0.z >
 cylinder{p0,p0+e1/5,rad/4 pigment{rgb x}}
 cylinder{p0,p0+e2/5,rad/4 pigment{rgb y}}
 cylinder{p0,p0+e3/5,rad/4 pigment{rgb z}}
 #declare c=c+1;
    pigment{rgb 2}
