POV-Ray : Newsgroups : povray.advanced-users : photons through a doublet of lenses Server Time
18 Nov 2025 08:17:11 EST (-0500)
  photons through a doublet of lenses (Message 1 to 4 of 4)
Subject: photons through a doublet of lenses
Date: 19 Mar 2008 12:10:00
Message: <web.47e14847e10d4672dcf53ead0@news.povray.org>
I have a new problem with a laser beam composed with photons. When I'm trying to
pass my ray through the doublet, photons are stopped at the interface of the
lenses. On the other hand, separately, the two lenses lets pass and diffracts
the rays as it is necessary. Is it a bug? How can I solve my problem?
Thank you
Sylvain
Subject: Re: photons through a doublet of lenses
Date: 19 Mar 2008 12:27:55
Message: <47e14d1b@news.povray.org>
"Sylvain Dub?" <jum### [at] hotmailcom> wrote:
> Hi,
  A small example scene demonstrating the problem would be helpful.
Date: 20 Mar 2008 12:52:17
Message: <47e2a451$1@news.povray.org>
Sylvain Dubé nous apporta ses lumieres en ce 2008/03/19 13:07:
> Hi,
> Thank you
> Sylvain
Are the lense set as target with refraction on? I assume yes.
What is your max_trace_level? Try setting it to a larger value.
A doublet mean that you have 4 surfaces. If your beam have already crossed 1
surface, or been reflected, you just reached the default value of 5, it just
can't go further.
Count each transparent object you encounter, multiply by 2. Add any reflective
surfaces encountered. Add 1 for the final target surface.
Set max_trace_level to that value, or more.
You know you've been raytracing too long when you think 80s movies have the
funniest special effects.
Aaron Gage a.k.a Slartibartfast
Date: 22 Jun 2008 10:10:01
Message: <web.485e5c756c8d64032c03ba270@news.povray.org>
> Hi,
> Thank you
> Sylvain
>You may want to try to "union" the two lenses together with a hyperfine gap beween
the two as to aviod the "incident s
urface problem".
                                                           -POVManiac
