POV-Ray : Newsgroups : povray.advanced-users : I need help whit a laser beam reflection Server Time
18 Nov 2025 08:14:32 EST (-0500)
  I need help whit a laser beam reflection (Message 1 to 4 of 4)
Subject: I need help whit a laser beam reflection
Date: 5 Mar 2008 14:15:00
Message: <web.47cef0ccceab9865a0bf9ac50@news.povray.org>
I'm trying to simulate a laser beam using photons through an optical path.
I saw many exemples of this (how to see the beam, functions of radius, count,
spacing, media,...) but when I'm trying to do this by myself, the beam after
reflection is always composed by many distant luminous points.
After many hours of working and manipulations of settings, I'm not able to do
anything to correct this.
This is a simplification of my code.
If you know the problem and are able to do something, could you indicate me the
right code?
Thank you
Sylvain
#version 3.6;
#include "math.inc"
#include "arrays.inc"
#include "analytical_g.inc"
#declare Use_Photons = yes;
global_settings
        assumed_gamma 1.0 max_trace_level 50
        #if(Use_Photons)
                photons
                autostop 0 count 200000 spacing 0.01 radius 0.05 media 1000
camera
        angle 90 right -x*image_width/image_height
        location  < 30 , 0 , 0>
        look_at   <0.0 , 0 ,0>
        //Rotate_Around_Trans(<-40,0,0>,<0,0,1000>)
        //rotate <0,90,0>
sphere{<0,0,0>,1 hollow texture{pigment{gradient <0,1,0> color_map{[0.0 color
Black][0.8 color rgb<0.1,0.6,0.9>][1.0 color rgb<0.1,0.6,0.9>]}}finish {ambient
1 diffuse 0}}scale 10000}
#declare Scatter_M = material {texture {pigment { rgbt 1 }finish {ambient 0
diffuse 0}} interior {media {method 3 intervals 1 samples 70, 1000 scattering
{1, rgb 0.1 extinction 0.00001}}}}
sphere {<0,0,0>, 400 hollow material { Scatter_M }  photons {pass_through }}
#declare P1MP = <0, 1, 1 >;
#declare P2MP = <0, -1,-1 >;
#declare P3MP = <0, 1, -1>;
#declare P4MP = <0, -1, 1 >;
polygon{
        5, P1MP, P3MP, P2MP, P4MP, P1MP
        hollow
        finish { reflection {1.0} ambient 0 diffuse 0 }
        pigment { White }
        photons {target reflection on refraction off collect off}
        rotate y*-45
        rotate z*-45
light_source { y*20, Red*10 cylinder  radius 0 falloff 0.5 tightness 0.5
photons {reflection on refraction on} point_at 0 Rotate_Around_Trans(<0,0,45>,
0)}
Subject: Re: I need help whit a laser beam reflection
Date: 5 Mar 2008 18:55:17
Message: <47cf32e5@news.povray.org>
> I saw many [examples] of this (how to see the beam, functions of radius,
> count,
> after
> do
The light source shouldn't be inside the media object.
The media object is the target for photons to be deposited on.
The media statement in global photons controls the balance
between photons deposited on media and on normal surfaces.
Something like media 1000,0.1 will make most of the photons
deposit in the media.
The camera probably shouldn't be inside the media object either.
Date: 6 Mar 2008 08:40:02
Message: <web.47cff3026f3acb29a0bf9ac50@news.povray.org>
thank you but, these lines
aren't present for the simulation. The second block is only to see the beam.
Unfortunately, my problem is still present.
Thank you again
Sylvain
Date: 7 Mar 2008 01:10:10
Message: <47d0dc42$1@news.povray.org>
Try this code, photons are touchy...
#version 3.6;
global_settings {
   assumed_gamma 1.0 max_trace_level 99
   #if (Use_Photons)
      photons {
         spacing 0.01
         autostop 1
         radius 0.05
         media 1000,0.1
   location  <0, 0, -11>
   angle 30
sphere { // background
   <0,0,0>,1
   inverse
         gradient <0,1,0>
         color_map {
            [0.0 color rgb<0.1,0.6,0.9>]
            [0.8 color Black]
      finish {
         ambient 1
         diffuse 0
      translate 0.5*y
   scale 42
      pigment { color rgbf 1 }
   interior {
      media {
         scattering {1, color White extinction 0.01}
         method 3
         intervals 10
         samples 70, 1000
light_source {<5, 15, 0>, color rgb < 1, 0, 0>*10
    spotlight radius 0.02 falloff 0.10 point_at < 0, 0, 0>
    photons {refraction on reflection on}
box {<-1,0,-1>,<1,-0.001,1>
   rotate <0,0,45>
   rotate <0,-45,0>
   pigment {White}
   finish {ambient 0 diffuse 0 reflection 1}
   photons {reflection on}
box {<-3,0.001,-3>,<3,3,3>
   hollow
   rotate <0,0,45>
   rotate <0,-45,0>
   photons {target}
