![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is there anyway to change how a gradient density fades off?
The following scene has a density that's a linear gradient. That is it falls off
in a linear fashion. Is there any way to change this so the density falls off
say at a geometric or exponential rate? Maybe instead of a linear decreasing
density, something where the density is sinosoidal?
Maybe a density map of some type?
Any help appreciated.
#declare cam_pos=(x*4+y*3+z*-2)*2;
location cam_pos
look_at (x*1+y*0+z*0)*0.5
light_source {
cam_pos
color White // add *2 if this light is not bright enough
cylinder { 0, <1,0,0>, 1
pigment {rgbt 1}
hollow
finish{ ambient 0.000 diffuse 0.000 specular 0}
interior{
media{
emission y/2
density {gradient -x scale 1.01}
scale x*3
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>falls off
You can use a function as the density pattern, like this:
http://www.econym.demon.co.uk/isotut/patterns.htm#density
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mike Williams napsal(a):
>> falls off
>> falls off
>> decreasing
or you can add a grayscale color map (I assume you want a colourless
gas) or a waveform.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Woody nous apporta ses lumieres en ce 2008/01/17 06:44:
> camera {
> location cam_pos
> light_source {
> cam_pos
> pigment {rgbt 1}
> hollow
> interior{
> media{
> emission y/2
> scale x*3
In addition to what others have proposed, you can experiment with the various
wave forms available. They are:
ramp_wave //the default for the gradient pattern
triangle_wave // used in the marble and wood patterns
sine_wave
scallop_wave // use the absolute value of a sine
cubic_wave
poly_wave [float]
You know you've been raytracing too long when your wife's raytraced image you
made to flatter her is the only one you see of her anymore.
Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
