POV-Ray : Newsgroups : povray.advanced-users : Defining a mandel function/ pattern WITHIN povray Server Time
12 Oct 2025 00:37:35 EDT (-0400)
  Defining a mandel function/ pattern WITHIN povray (Message 1 to 5 of 5)
Subject: Defining a mandel function/ pattern WITHIN povray
Date: 19 Oct 2007 12:10:00
Message: <web.4718d5b659db5e5d40d56c170@news.povray.org>
Hello.
Is it possible to define a mandel function pattern within povray itself?
Basically, I'd like to be able to set a higher level. I am guessing that it
might be possible to write you own pattern to do this. One could insert a
higher level than the current 32000 limit, or insert othe equations.
Has anyone tried?   tia.
Subject: Re: Defining a mandel function/ pattern WITHIN povray
Date: 19 Oct 2007 14:21:02
Message: <4718f58e@news.povray.org>
  Actually yes, with recursive functions. It will be a bit slow, though.
  A higher level of what?
  Is there really such a limit?
> Has anyone tried?
  In fact, yes. It's possible to use recursive functions to achieve this.
Date: 19 Oct 2007 15:30:01
Message: <web.471904d69474a87540d56c170@news.povray.org>
Render this SDL as an animation with two frames
// --- begin SDL
box{<-50,-50,5>,<50,50,11>
        pigment{
                mandel  32766+frame_number
                pigment_map{[0 rgb x][0.5 rgb y][1.0 rgb z]}
                scale 1
        finish{ambient rgb 1}
// -- End SDL
Date: 19 Oct 2007 15:46:58
Message: <471909b2@news.povray.org>
> // --- begin SDL
>         pigment{
>                 scale 1
> // -- End SDL
  I don't even expect to see any difference at that zoom level and with
such a small change in number of iterations.
Date: 19 Oct 2007 15:55:00
Message: <web.47190b319474a87540d56c170@news.povray.org>
> level and with such a small change in number of iterations.
Neither did I.
