POV-Ray : Newsgroups : povray.advanced-users : Making color legend Server Time
8 Feb 2026 22:07:00 EST (-0500)
  Making color legend (Message 1 to 7 of 7)
Subject: Making color legend
Date: 22 May 2007 02:40:02
Message: <web.46528fc8fd45f3f74ac3566b0@news.povray.org>
Hi All,
I want to make a color legend for following my application.
My application is, I make a cube with different color faces, which colors
correspond to the force acting on them.
This color set up shows x,y,z direction forces.
texture{pigment{rgb <  2 ,  2 , 2 > }}
Now my problem I should put a color legend which shows the color and force
relation.
Is it possible make automatically in POV-ray?
If not how can I do the above job? Please help me........
Thanks a lot in adavnce.
Rgds,
Sitha.
Subject: Re: Making color legend
Date: 22 May 2007 05:01:08
Message: <4652b154$1@news.povray.org>
Is this intended to be an animation?
Is the data generated by some other program?
For now I'll assume you want a still, and the
data is generated inside pov.
Color in pov normally varies from 0 to 1.
POV has the ability to use splines to interpolate between
vectors, and color is just another vector.
Example...
#declare CMap = spline {
   linear_spline
   0.0, <0,0,1> //blue
   0.33,<0,1,0> //green
   0.66,<1,1,0> //yellow
   1.0, <1,0,0> //red
Which can then be used as your pigment.
pigment { color CMap(Xforce) }
> relation.
It sounds like you want a gradient pigment, and some text labels.
Example...
union {
 box {<0,0,0>,<1,0.2,0.001>
      gradient x
      color_map {
         [0 Blue]
         [0.33 Green]
         [0.66 Yellow]
         [1 Red]
      translate <-0.001,0,0>
   scale <1.5,1,1>
 text {
    ttf "timrom.ttf" "0" 0.05, 0
    pigment { White}
    scale 0.2
    translate <0.04,0.04,-0.01>
 text {
    ttf "timrom.ttf" "1" 0.05, 0
    pigment { White}
    scale 0.2
    translate <1.4,0.04,-0.01>
 translate <0.2,-1,-0.1>
Pov doesn't have a built in legend function, you'll
need to reposition your legend object if you move the
camera.
However, with a little math it's possible to
place an object to look like it is in the same spot
in relation to the camera.
Date: 22 May 2007 05:25:02
Message: <web.4652b66fb27d7bb9c4e49fa40@news.povray.org>
> camera.
There is screen.inc
POV-Ray 3.6 Documentation Online View - 2.7.20.3 screen.inc
Screen.inc will enable you to place objects and textures right in front of
the camera. When you move the camera, the objects placed with screen.inc
will follow the movement and stay in the same position on the screen.
Date: 22 May 2007 22:50:02
Message: <web.4653ab94b27d7bb94ac3566b0@news.povray.org>
Dear Tim,
Thank you very much for your help. I hope your idea will help me very much.
Thanks a lot again.
Rgds,
Sitha.
Date: 22 May 2007 22:55:01
Message: <web.4653ac81b27d7bb94ac3566b0@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> wrote:
> There is screen.inc
Dear Stephen,
I dont understand your explanation. Do you mean that POV has in built
function to make legend?
Rgds,
Sitha.
Date: 22 May 2007 22:55:02
Message: <web.4653acecb27d7bb94ac3566b0@news.povray.org>
> There is screen.inc
Sorry Stephen I misunderstood your explanation. Now I got your idea.
Thanks a lot.
Rgds,
Sitha.
Date: 23 May 2007 05:30:01
Message: <web.46540934b27d7bb9b3e3af320@news.povray.org>
> > There is screen.inc
Join the club you are not the only one :-)
animation.
