Hi!
Swedish national television is having a contest where you can send in your 1
minute animations. Well, to keep it short Im thinking of giving it a go.
In their specifications they prefer the format to be in "720 * 576 Anamorph
or 1024 * 576 16:9 square pixel"
Ok, so I'm halted before I have even begun... I dunno what anamorph OR
square pixel means! Or, rephrased, which one of the above comes out of a
POV-Ray render?
Ehh.. yeah, I hope you understand my question... :/
With great expectations ;D
//RusHHouR
Umm... can this be on the right way..?
command line: +H576 +W1024
location <-58.0, 1.85, -58.0>
direction 1.5*z
up <0,9,0>
right <16,0,0>
look_at <-5.0, 23.0, 4.0>
angle 60
Le 03/18/2007 05:31 PM, RusHHouR nous fit lire :
> Hi!
> POV-Ray render?
They are requesting mpeg encoding (right ?), with flagged pixel
ratio. (so, fine tune your encoding software, for them, that's all).
They are either expecting DVD native (Pal) definition (720 x 576) to
be displayed on 16:9 screen format, or basic computer screen (1024 x
576, with square pixel ends up to a picture ratio of 16:9).
Remember to avoid the overscan zone in your production:
- 10% near borders might be unseen (eaten by TV set)
- 20% near border: no text/subtitle.
There is no problem for povray, has you can set the resolution
independantly of the view (for once, stay away of smart camera
settings using image_height/width).
So, make your camera ratio to 16:9, and either render at 720x576 or
1024x576 (depending on your encoder's capabilities: do some basic
testing, then make your choice).
You might appreciate some independant mpeg analysers to check your
setting.
Go!!! and good luck & fun!
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Great, great! File should be in .mov oddly enough. Probably becasue they
will also post it online.
Thanks a lot for your fast reply and help!
//RH
