POV-Ray : Newsgroups : povray.advanced-users : the POV-ray SDL--similar to Java and/or Python? Server Time
19 Mar 2026 18:56:00 EDT (-0400)
  the POV-ray SDL--similar to Java and/or Python? (Message 61 to 70 of 79)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: the POV-ray SDL--similar to Java and/or Python?
Date: 14 Sep 2006 13:30:37
Message: <450991bd@news.povray.org>
>   Btw, could you finally give me even a slight hint at how GC knows
> that an object is not used anylonger?
>   I don't get it.
You mark every object that exists as "garbage". Then you take each
global variable, local variable in currently running threads, etc. in
turn, and you mark the object that variable points to as "not garbage".
And then you find every object it points to and mark all those as "not
garbage". And then all the objects that *those* objects point to, and so
forth. Follow all the pointers until you stop finding objects that
aren't already marked.
At this point, anything still marked "garbage" gets deleted.
Simple, really. And slow. And various optimisations make it go much faster.
Date: 14 Sep 2006 13:32:14
Message: <4509921e$1@news.povray.org>
>>>   Oh, you have discovered a method to completely avoid memory
>>> fragmentation? :-o Is it efficient?
>> Yes, and yes.
>   That would mean that the memory allocation engine knows ahead of time
> the order in which objects will be "forgotten" (ie. nothing points to them
> anymore so they can be freed) so that it can group them in contiguous
> memory. Of course this is impossible (not even by analyzing the program
> because the order in which objects are "forgotten" may depend on things
> like user input).
>   The only other alternative is that it performs memory defragmentation
> before freeing the objects. But that doesn't sound any faster than
> freeing the objects directly.
Go through memory, find all the dead objects, and *then* defrag the
whole lot in a single pass. Done.
Date: 14 Sep 2006 14:23:57
Message: <45099e3d$1@news.povray.org>
GIYF.
Try ".net garbage collection" to see how .net does it, which is more
sophisticated than the "mark and sweep" algorithm Orchid described.
>   What you write sounds like it knows it by magic.
No more than a compiler knows "by magic" what you meant, or a SQL engine
knows "by magic" how to best order the operations to get good performance.
> be reference counting!) then how? The GC has to also make a difference
> between a reference being actually used in the currently-executed code
> and an orphan reference.
Yep. In the other message you already followed up to, I put both a
simplistic description and a number of links.  If you still have
questions, feel free to ask. I'll assume you followed that up.
     Just because you find out you are
     telepathic, don't let it go to your head.
Date: 14 Sep 2006 14:27:54
Message: <45099f2a$1@news.povray.org>
Um, yes. So, the reasonable conclusion would be "my initial premise is
incorrect."
No. It usually performs memory defragmentation as a concurrent part of
It depends on the ratio of freed objects to retained objects. If you
retain only 2% of the objects you created since the last GC, it's a net win.
>   Oh, of course there's a third possibility: It doesn't free objects if
> freeing them would cause fragmentation. But then they would consume
> memory even though they are not used. Doesn't sound reasonable if that
> memory would be needed for something else.
That is generally only done in systems that use pointers rather than
references. (I.e., systems where the address of the object can't change
due to the semantics of the language, like C, rather than something like
Java where there's no way to get to the underlying address given the
refernece.)  Optimistic garbage collection (GIYF) often works that way.
Date: 14 Sep 2006 14:32:43
Message: <4509a04b@news.povray.org>
  GC was supposed to be faster than a RC method.
Date: 14 Sep 2006 14:34:37
Message: <4509a0bd@news.povray.org>
  And how is that faster from simply freeing the dead objects? The original
point was that GC is much faster than freeing each object individually.
Moving the dead objects around in memory before freeing them isn't going
to help.
Date: 14 Sep 2006 15:11:59
Message: <4509a97e@news.povray.org>
  If it performs memory defragmentation, that means that memory does get
fragmented (and thus need the defragmentation in the first place). Your
original claim was that there's *no* fragmentation at all and that's why
freeing a group of objects is faster.
  So it's faster only under certain conditions, not all?
Date: 14 Sep 2006 15:20:05
Message: <web.4509ab21dcfb777fd4bf45760@news.povray.org>
Please you all in this fight: STOP IT! It becomes ridiculous ans off-topic.
This thread is for 'advanced' users. I can't see no advanced behaviour
here...
   Thanks in advance for your comprehension.
       Bruno.
Date: 14 Sep 2006 15:25:42
Message: <4509acb6$1@news.povray.org>
That's called "Mark and sweep."  It's also fairly slow, if you don't
tend to generate a lot of garbage. That and reference counting are
basically the two oldest, most primitive attempts at garbage collection.
25 years of research has improved things tremendously. Even generational
GC like MS uses is a dozen years old.
 > The original
Well, it's faster than freeing each one individually *and* doing the
math to maintain the reference counters.
 > them isn't going to help.
You don't move the dead objects around, any more than a disk defrag
copies the contents of unallocated sectors out of the way of the file
being moved. You only move the live objects around. If you have many
more dead objects than live objects, it's a win, especially if new
allocations are sped up by not having to avoid clobbering live objects
(i.e., sped up by not having to walk a free-space chain looking for a
sufficiently-large hole). Figuring out how to identify dead objects
without actually looking at them at all is challenging but mostly solved.
If you're looking for a description with reference to C++, try
ftp://gatekeeper.research.compaq.com/pub/DEC/SRC/research-reports/SRC-102.pdf
which is probably about as extensive and detailed as you need. Note that
  this paper too is 15 years old, and people haven't stopped researching.
Note that [Zorn 92] in the citations discusses actual measurements of
actual efficiency. If you don't want to do the googling,
http://www.cs.ubc.ca/local/reading/proceedings/spe91-95/spe/vol23/issue7/spe836.pdf
This paper is also 15 years old, so it's saying 15 years ago, we already
knew how to make GC more efficient than doing things manually, including
with reference counting. Note that cfrac was written using reference
counting, and when the researcher changed it to use GC, the time went
from 215 seconds to 175 seconds. And this is conservative GC, meaning
there's no support from the language helping out, which isn't the norm
for GCed languages.
Wow! Look!  Actual Data!  But don't mind me, because I don't know
anything about the topic at all, no. Because, ya know, I just make stuff
up without ever having read any research in the field I'm talking about,
thinking that if I don't understand it already, it must not be important
enough to learn about.
Of course, the performance relative to explicit management depends in
part on the algorithm your version of new and delete uses. What
algorithm are you comparing to? Do you even know what algorithm your
libraries use? Do you even know the order of efficiency of it? Have you
tried replacing it with a faster one?
http://gcc.gnu.org/ml/gcc/2002-08/msg00577.html
Wow. Linus himself saying "The gcc allocators have just always been
bad." So what are you comparing your manual-allocation efficiency to?
Date: 14 Sep 2006 16:02:59
Message: <4509b573$1@news.povray.org>
of freeing the objects.
You're oversimplifying. You asked if I have an efficient way to avoid
fragmentation. The answer is "yes".
 > Your
No. My claim is that's why the whole system overall is faster. I take it
from this description that you didn't bother to read yet the pages I
linked to? Did you not understand the description, or the explanation of
why it's more efficient than individual allocations and deallocations?
But yes, Bruno is right. It doesn't make any sense to discuss the
benefits and flaws of the details of various systems before you learn
how they work.
See the other post. Of course every algorithm that works for all uses
will have a situation under which a specific pattern is inefficient. If
you only ever create files and never delete them or move them, having an
i-node listing individual blocks is inefficient compared to just listing
the start sector and length. If you only ever allocate and never free,
or you always allocate in a LIFO order, GC is a net loss compared to
using a stack. If nothing you allocate dynamically ever has an embedded
pointer to something else, reference counting isn't too bad. Even
bubble-sort is efficient with few enough items in your list.
