POV-Ray : Newsgroups : povray.advanced-users : Tricky Transform Problem and screen.inc Server Time
18 Nov 2025 11:44:45 EST (-0500)
  Tricky Transform Problem and screen.inc (Message 1 to 3 of 3)
Subject: Tricky Transform Problem and screen.inc
Date: 8 Jul 2006 01:00:01
Message: <web.44af3b0bdd2631736380c8890@news.povray.org>
Hey all.
I'm not sure how 'advanced' this is, but I think it would take some thought.
I have created a small set of axes to mark the direction of x, y and z. I
want to place an item in front of the screen. I have done this using
screen.inc. My problem is that Screen_Object rotates the object into the
plane normal to camera_position-camera_target. So my result is that the z
axis points to camera_position-camera_target, and the x and y axes are in
the plane of the screen. I want to rotate the axes back so that they --
once again -- point to positive x, y and z as they would have naturally
(before being rotated by screen.inc). Obviously the natural way to do this
is to rotate the axes ahead of time so that screen.inc will be rotating it
into the natural x, y and z directions.
If anyone can think of a good way to do this, I would be highly
appreciative.
Subject: Re: Tricky Transform Problem and screen.inc
Date: 8 Jul 2006 19:19:41
Message: <44b03d8d$1@news.povray.org>
> appreciative.
Perhaps you could use somthing like this for your axes (untested code):
object {
    Axes
    transform {Camera_Transform inverse}
    translate Camera_Location
Rune
http://runevision.com
Date: 10 Jul 2006 02:55:01
Message: <web.44b1f95f9de603d26380c8890@news.povray.org>
"Rune" <new### [at] runevisioncom> wrote:
> > appreciative.
> object {
>     Axes
> Rune
Haha! Brilliant! Thanks so much!
I had no idea that povray could calculate matrix inverses for you.
