POV-Ray : Newsgroups : povray.advanced-users : Beeing stupid... y=x*sin(1/x), how to? Server Time
30 Sep 2024 14:15:18 EDT (-0400)
  Beeing stupid... y=x*sin(1/x), how to? (Message 1 to 6 of 6)
Subject: Beeing stupid... y=x*sin(1/x), how to?
Date: 15 Dec 1999 12:38:00
Message: <MPG.12c18e98202e9328989683@news.povray.org>
Anyone, please, i'd love to plot a graph of the function, well, it's like
this:
I have y = x * sin(1/x), and its some graph in 2D, Well, now i want to
rotate that graph around the z-axe (one pointing up/down), and represent
that in POV. Is that possible withouht 3rd party programs/utils?
	Mike
Subject: Re: Beeing stupid... y=x*sin(1/x), how to?
Date: 15 Dec 1999 15:30:54
Message: <chrishuff_99-E0211D.15312415121999@news.povray.org>
In article <MPG.12c18e98202e9328989683@news.povray.org>, Mario Splivalo
> this:
If you mean you want to make a kind of lathe, swept around the z axis,
it would be pretty simple to do. One way would be to use an isosurface,
with a function like:
function {z - sqrt(x^2 + y^2)*sin(1/sqrt(x^2 + y^2))}
replacing x with sqrt(x^2 + y^2), which is the distance from the z axis.
Another way would be to use an actual lathe object, and use a #while
loop to calculate the position of each control point.
Or if you want to represent the actual graph in POV, not making a 3D
graph, you can use an image_map to use a picture of the graph for the
texture, or you can create it out of objects, something like
this(untested!):
#macro GetValAt(V)
    (V*sin(1/V))
#macro MakeGraph(Elems, XSize, graphRadius, graphTexture)
    #local stPos = < 0, 0, 0>;
    sphere {stPos, graphRadius
        texture {graphTexture}
    #local K=0;
    #while(K<Elems)
        #local endPos = <(K/(Elems - 1))*XSize, GetValAt((K/(Elems -
1))*XSize), 0>;
        cylinder {stPos, endPos, graphRadius
        sphere {endPos, graphRadius
        #local stPos = endPos;
        #local K=K+1;
This macro would be used like this:
MakeGraph(50, 5, 0.05, MyTexture)
Where:
Elems = the number of elements in the graph
XSize = the distance along the x axis the graph extends
graphRadius = the radius of the graph elements
graphTexture = the texture of the graph elements
Chris Huff
e-mail: chr### [at] yahoocom
Date: 15 Dec 1999 17:53:49
Message: <385845FC.F5F68C0E@ij.net>
> this:
    2D plot
#declare i = .001 ;
#declare inc = 10 ;
#while (i<inc)
sphere { 0.0, .005 translate <i,i*sin(2*pi/i),0>
texture{pigment {radial frequency 8} finish{specular 1}} }
#declare i = i + 1/1000 ;
And a 3D version if interested
#declare i = .001 ;
#declare inc = 10 ;
#while (i<inc)
sphere { 0.0, .005 translate <i,i*sin(2*pi/i),i*cos(2*pi/i)>
    Take the 2D version out to some value of x and then bring it back to zero
along i*sin(2*pi/i)+.00001 or a larger number if you want a noticable
thickness.
    But instead of plotting it, write the x and y values to a file, search on
File I/O to learn that. Then import the file and tag it as a surface of
rotation, SOR.
    Should work.
Date: 19 Dec 1999 19:26:19
Message: <MPG.12c7343caf4ca57d989687@news.povray.org>
In article <chrishuff_99-E0211D.15312415121999@news.povray.org>,
chr### [at] yahoocom says...
> > this:
Yes, and I get nothing... Or I am doing something wrong ;(
Yes, that, i think, will be the only way....
> this(untested!):
I need a 3D :)
	MIke
Date: 19 Dec 1999 19:27:36
Message: <MPG.12c73490f3b14807989688@news.povray.org>
In article <385845FC.F5F68C0E@ij.net>, jul### [at] ijnet says...
> > this:
>     2D plot
> #declare i = .001 ;
> #declare inc = 10 ;
> #while (i<inc)
> #end
> #declare i = .001 ;
> #declare inc = 10 ;
> #while (i<inc)
> #end
> thickness.
> rotation, SOR.
Hm, yes, it does, but, when making an fly-trough animation, it looks
ditch....
Can it be done using cubic, quadric, or quatric, or matrix, or something/
	Mike
Date: 19 Dec 1999 19:51:17
Message: <chrishuff_99-2E2D41.19515619121999@news.povray.org>
In article <MPG.12c7343caf4ca57d989687@news.povray.org>, Mario Splivalo
> > axis.
What is the isosurface you are using? Try something like this:
   location <0, 3.5, -10>
   look_at <0, 0, 0>
   angle 35
isosurface {
   function {y - sqrt(x^2 + z^2)*sin(1/sqrt(x^2 + z^2))}
   eval
// max_gradient 1.1
   threshold 0
   bounded_by {box {<-2,-2, 0>, < 2, 2, 2>}}
   //Make a cross-section of the surface
   //use clipped_by to make just the surface visible
   accuracy 0.001
      pigment {color rgb < 0.095, 0.44, 0.2 >}
      finish {ambient 0.35}
   scale 2 rotate y*45
light_source {< -40, 75, -40> color White}
Chris Huff
