POV-Ray : Newsgroups : povray.advanced-users : Fishtail math ><}}}*> Server Time
15 Oct 2025 03:58:10 EDT (-0400)
  Fishtail math ><}}}*> (Message 1 to 10 of 26)
Subject: Fishtail math ><}}}*>
Date: 19 Nov 1999 05:08:04
Message: <8E83722CAseed7@212.120.113.81>
I'm trying to animate the tail of an ASCII-fish. I figured out how to do it
the long way but I'm looking for a short cut.
Concider eleven spheres on a string from the origin to <10,0>.
around the current position of the second sphere.
3. leave the first and second sphere in its position. rotate the whole
sphere.
Now, is there a direct way to calculate the position of a sphere, without
going through the above loop. What will the position of sphere 7 be when
Ingo
Subject: Re: Fishtail math ><}}}*>
Date: 19 Nov 1999 10:55:58
Message: <gXE1OEmQIwaKCy6cD1iiNG2nHd=4@4ax.com>
>sphere.
>Ingo
Will you please explain how you will animate this? Will you change the
11*clock?
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 11:20:07
Message: <383578A0.390793C0@xs4all.nl>
> do it
> tenth
> sphere.
> without
> when
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
I don't know if I understand your method exactly but I did a similar
thing with a reasonable result using sin/cos-functions. This gives a
nice curve. The position of each sphere is based on its place in the
string _plus_ a clock value. This way the first sphere will move also.
This is easy to avoid by moving the whole string relative to the
translation of this first sphere. Sounds far more complicated then it
actually is 8)
Groeten!
Remco
Date: 19 Nov 1999 11:33:05
Message: <dXs1OOq1xINLNt=bgKiRd2qGA45t@4ax.com>
On Fri, 19 Nov 1999 17:19:44 +0100, Remco de Korte
>actually is 8)
>Groeten!
>Remco
But will this keep the distance between two consequitive spheres
constant? I don't think so, and unless your fish is made of natural
rubber, it's gonna hurt big time :)
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 13:22:23
Message: <8E83C37DBseed7@212.120.113.81>
>11*clock?
11*clock.
Ingo
Date: 19 Nov 1999 13:23:47
Message: <8E83CA50Eseed7@212.120.113.81>
>>thing with a reasonable result using sin/cos-functions. ........
Exactly the reason why I don't want to use the sin / cos method.
Ingo
Date: 19 Nov 1999 15:45:52
Message: <wLY1OMbzDPA1TyjiGtT0qa19CQA+@4ax.com>
>>11*clock?
>11*clock.
>Ingo
Okay, I'll try to put up a #while loop to do it.
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 15:48:30
Message: <3835B78C.EEB1C568@xs4all.nl>
> Ingo
How much stress will that cause?
And you're not telling me that you've never had to stretch while moving
haven't you?
Anyway, it's probably bad physics for a robot, but it works (for me) in
an image.
If the distance between sphere's really would be the problem you could
easily change your calculations to provide for that. That wouldn't
change the fact that if you had a really 3D-body there still would be
some stretching (inside vs outside of curve).
Remco
Date: 19 Nov 1999 16:16:44
Message: <8E83E29AAseed7@212.120.113.81>
>haven't you?
>an image.
That's true, but it's like YKYHBRTLW You create a motor using every part
..... even the ones that don't show ..... just for authenticity.
Ingo
Date: 19 Nov 1999 16:58:14
Message: <dMc1OCY1+UrtvmpLUIKrpJRSdMCZ@4ax.com>
>>11*clock?
>11*clock.
>Ingo
//try this
#declare Pos=array[11]
#declare i=0;
#while (i<11) #declare Pos[i]=<i,0,0>; #declare i=i+1; #end
#declare i=1;
#while (i<11)
  #declare Pos[i]=vrotate((Pos[i]-Pos[i-1]),<0,0,10*clock>)+Pos[i-1];
  #declare i=i+1;
Peter Popov
ICQ: 15002700
