POV-Ray : Newsgroups : povray.advanced-users : Paraboloid with thickness Server Time
13 Aug 2025 12:35:05 EDT (-0400)
  Paraboloid with thickness (Message 1 to 5 of 5)
Subject: Paraboloid with thickness
Date: 26 Jan 2021 02:56:19
Message: <600fcb23$1@news.povray.org>
How would I create a paraboloid with thickness N?
I'm guessing I need need to create an offset surface of some sort. Does
it need to be an isosurface?
Mike
Subject: Re: Paraboloid with thickness
Date: 26 Jan 2021 05:30:00
Message: <web.600fee1222c070976396ca3e0@news.povray.org>
Hi Mike,
I think you could use an isosurface like this:
#declare _thickness = 1.0;
#declare thickParaboloid =
  function { abs(pow(x,2) + pow(z,2) - y) - _thickness * 0.5}
isosurface {
  function { thickParaboloid(x,y,z) }
  max_gradient 15.0
  contained_by { box { -5, 5 } }
  texture { pigment { color rgb 1.0 } }
Or, you could approximate it with a lathe object.
Hope it will help.
Pascal
> Mike
Date: 26 Jan 2021 17:31:44
Message: <60109850$1@news.povray.org>
On 1/26/2021 5:26 AM, BayashiPascal wrote:
> Hi Mike,
> isosurface {
>    max_gradient 15.0
> Hope it will help.
> Pascal
>> Mike
Thank you! I will test it out.
Mike
Date: 28 Jan 2021 21:13:16
Message: <60136f3c$1@news.povray.org>
My immediate thought was that this is a job for the quadric primitive.
Alas, after two days of weird results, it became clear that the quadric
has bounding pathologies, even in POV-Ray 3.8.  I knew there was a bug
in 3.7's quadric--in fact, I discovered it; but whatever was done to fix
it hasn't completely resolved the bounding issues.
However, I found that poly { 2 } does not have these problems.
The following code creates a paraboloid with the apex downward, apex at
the origin, radius R, height H, and wall thickness T:
----------[BEGIN CODE]----------
// parameters
#declare R = ;
#declare H = ;
#declare T = ;
// derived
#declare A = H / pow (R, 2);
#declare T1 = (2 * H * T) / (sqrt (1 + pow (2 * H / R, 2)) * R);
#declare A1 = (H - T) / pow (R - T1, 2);
intersection
{ cylinder { 0, H * y, R }
   poly { 2, <A, 0, 0, 0, 0, 0, -1, A, 0, 0> }
   poly { 2, <-A1, 0, 0, 0, 0, 0, 1, -A1, 0, -T> }
-----------[END CODE]-----------
T1 is the horizontal component of the wall thickness at height H.  It
was derived by taking the derivative of the parabola in the x-y plane at
x and plugging it into the Pythagorean equation.
One thing I noticed about BayashiPascal's code is that the contained_by
box is much larger than the paraboloid.  All that extra volume slows
down the rendering of the isosurface, so you’ll want to tighten that up.
  By using box { <-R, -_thickness / 2, -R>, <R, 5, R> } where R = sqrt
(5 + _thickness / 2), I was able to reduce the max_gradient to 6.4 and
cut 1/3 off the render time.
Date: 28 Jan 2021 23:20:00
Message: <web.60138beb22c070976396ca3e0@news.povray.org>
Right. Thanks for improving my lazy solution.
Pascal
