POV-Ray : Newsgroups : povray.advanced-users : Undefined variables Server Time
30 Apr 2024 22:02:35 EDT (-0400)
  Undefined variables (Message 1 to 6 of 6)
Subject: Undefined variables
Date: 5 Feb 2018 17:46:55
Message: <5a78dedf$1@news.povray.org>
I am trying to create a macro:
   #macro BlurredReflection(InPigment, InFinish, InNormal)
But I don't want to *always* pass a value to the macro. Is there a way
to pass a "null" or "nil" value to the macro, and then check for it
using a conditional statement?
Thanks.
Mike
Subject: Re: Undefined variables
Date: 5 Feb 2018 17:58:31
Message: <5a78e197$1@news.povray.org>
>    #end
> Thanks.
> Mike
Not any that I'm aware of.
What you can do is define the macro with only a single, or no, parameter
and use some global variable and #if statements to assign defaut values
it any variable is not already defined.
Date: 5 Feb 2018 18:10:00
Message: <web.5a78e3f58fda426b5cafe28e0@news.povray.org>
I know what you mean.
I just came up with this idea 5 sec ago:
What if you "always" pass a vector to the macro - one that is reset to default
"null" values, and then you can re-#declare the vector before  calling the macro
with the vector as an argument.
That way the vector need not always have the same number of components, but it's
always ONE vector.
Date: 5 Feb 2018 20:46:40
Message: <5a790900$1@news.povray.org>
>    #end
> Thanks.
> Mike
There are optional parameters, which may help you out.
http://news.povray.org/povray.beta-test/thread/%3Cweb.58d3f1da55c5eb5fc437ac910%40news.povray.org%3E/
I had a similar need, but I ended up not using optionals, because the
caller still needs to be aware of the missing parameters via comma
count; i.e. BlurredReflection(Red,,)
I ended up just creating a mostly duplicate, different named macro with
the optional parameter.
#macro BlurredReflection(InPigment, Infinish) #end
#macro BlurredReflectionWithNormal(InPigment, InFinish, InNormal) #end
dik
Rendered 920576 of 921600 pixels (99%)
Date: 6 Feb 2018 08:10:18
Message: <5a79a93a$1@news.povray.org>
Am 05.02.2018 um 23:47 schrieb Mike Horvath:
>   #end
In the new versions, you can use e.g.
    #macro Fnord(A, optional B, C)
      #ifdef(local.B)
        #debug "Got a value for B.\n"
      #else
        #debug "B was left empty.\n"
      #endif
    Fnord(A,,C)
Date: 6 Feb 2018 08:16:54
Message: <5a79aac6$1@news.povray.org>
>>    #end
>        #ifdef(local.B)
>        #else
>        #endif
>      #end
>      Fnord(A,,C)
Interesting, thanks.
Mike
