POV-Ray : Newsgroups : povray.advanced-users : Spherical isosurface Server Time
14 Mar 2026 11:09:00 EDT (-0400)
  Spherical isosurface (Message 1 to 10 of 17)
Subject: Spherical isosurface
Date: 28 Nov 2016 18:42:34
Message: <583cc0ea$1@news.povray.org>
Clipka gave me these formulas to generate a cylindrical isosurface.
#declare fL = function(x,y,z) {y*100}
#declare fC = function(x,y,z) {sqrt(x*x+z*z)*128}
#declare fH = function(x,y,z) {atan2d(x,z)}
What would be a formula for a sphere? L should be latitude, H longitude,
and C radius.
Thanks.
Subject: Re: Spherical isosurface
Date: 29 Nov 2016 01:19:51
Message: <583d1e07$1@news.povray.org>
> and C radius.
> Thanks.
Would I use atan(x,y) for L? This produces values between -90..90
degrees, correct? Or should it be atan(z,y)?
Thanks.
Mike
Date: 29 Nov 2016 06:10:00
Message: <web.583d615dc3db15af9c5d6c810@news.povray.org>
> > and C radius.
> > Thanks.
I sure don't know enough to tell you much of anything, the sphere equation is
something like:
function(x,y,z,r) {(pow(x,2)+pow(y,2)+pow(z,2))-pow(r,2)}
There's also the inbuilt function called internal (61) used by functions.inc for
its f_sphere(x,y,z,r) where r is radius. Hopefully I got this right, please
don't count on it!
P.S. I was trying, rather clumsily, to get the idea of what you might have been
trying to make and only succeeded in creating strange isosurface shapes. Some
were a partial sphere with both a vertical and horizontal cut across it,
thinking I changed to atan(y) and atan2(x,z) but I got lost in the fascination
of new shapes.
Date: 29 Nov 2016 07:55:00
Message: <web.583d7a91c3db15afc437ac910@news.povray.org>
I always start here:
http://www.econym.demon.co.uk/isotut/
whenever I have any questions about isosurfaces.
Like Christoph said, it takes a certain "way" of thinking to successfully play
with isosurfaces.
I'd also be aware that you may use code and equations that successfully yield a
visible isosurface in a render.  That surface may or may not be correct - so I'd
also be thinking about placing visible markers, sending numeric results to the
debug stream, overlaying the isosurface onto your stacked-block model, or some
other way of performing sanity and accuracy checks.
Aside from that, as Christoph said, "don't listen to that man"
I use this
https://www.maxiaids.com/Media/Thumbs/0008/0008988-big-keys-lx-color-abc-300.jpg
to write my SDL code, and when I'm down in the basement POVving, my mom makes me
wear a special helmet so I don't injure myself when trying to visualize 3D
vectors or do Big Boy math.  ;)
:D
Date: 29 Nov 2016 11:58:01
Message: <583db399$1@news.povray.org>
>>> and C radius.
>>> Thanks.
> something like:
> don't count on it!
> Bob
> of new shapes.
Thanks for trying, at least.
Mike
Date: 29 Nov 2016 12:03:27
Message: <583db4df$1@news.povray.org>
That tutorial only gives a single function for a sphere. I need separate
functions for latitude, longitude and radius, that get combined later
using an additional function.
Like this:
#declare fD = function(C) {abs(C-0.5)-0.5}
#declare fDist = function(Dr,Dg,Db) {max(Dr,Dg,Db)}
#declare fR = function(L,C,H) {convertLCH2RGBa1(L,C,H)}
#declare fG = function(L,C,H) {convertLCH2RGBa2(L,C,H)}
#declare fB = function(L,C,H) {convertLCH2RGBa3(L,C,H)}
#declare fL = function(x,y,z) {90+atand(x/y)}			// wrong!
#declare fFinal = function(L,C,H)
	fDist
		fD(fR(L,C,H)),
		fD(fG(L,C,H)),
		fD(fB(L,C,H))
Mike
Date: 29 Nov 2016 12:59:05
Message: <583dc1e9$1@news.povray.org>
> and C radius.
> Thanks.
Maybe this?
#declare fL = function(x,y,z) {90+atand(sqrt(x*x+z*z)*128/y*100)}
Problem: L ranges from 0..100, and C ranges from 0..128, and I want to
avoid generating a flattened ellipsoid.
Mike
Date: 29 Nov 2016 15:05:00
Message: <web.583ddf60c3db15afc437ac910@news.povray.org>
> > and C radius.
https://en.wikipedia.org/wiki/Spherical_coordinate_system
Conversely, the Cartesian coordinates may be retrieved from the spherical
coordinates
https://wikimedia.org/api/rest_v1/media/math/render/svg/d7bcd516d317c31ac48ed36e2ead9537a5f16e2e
> Mike
#declare C = C*(100/128);
Date: 29 Nov 2016 15:26:51
Message: <583de48b$1@news.povray.org>
Am 29.11.2016 um 00:42 schrieb Mike Horvath:
> and C radius.
What you need is _not_ "formulas to generate a [spherical] isosurface".
What you need is formulas to convert from a point in cartesian space to
a colour in the spherical (as oppsed to cylindrical) LCh model.
This is just a small building block in your isosurface function, and in
and of itself has no special relation to isosurfaces whatsoever. (You'll
need to use the same formula to eventually compute an RGB colour pigment.)
If Chroma (C) is to be (spherical) radius, that part is easy:
    #declare fC = function(x,y,z) { sqrt(x*x+y*y+z*z)*CONST }
Hue (H) should be unchanged:
    #declare fH = function(x,y,z) { atan2(x,z)*CONST }
Luminance gets a bit more complicated: You have to use an atan-based
formula to get an angle, but you must plug in the y coordinate and the
distance between the y axis; the latter is equal to sqrt(x*x+z*z), so
this gives you:
    #declare fL = function(x,y,z) { atan2(sqrt(x*x+z*z),y)*CONST }
Choose CONST values as needed; atan2()*CONST may happen to be replacable
by atan2d() again.
Date: 29 Nov 2016 15:59:10
Message: <583dec1e@news.povray.org>
>>> and C radius.
> coordinates
>> Mike
THANK YOU!!
This had what I needed:
https://en.wikipedia.org/wiki/Spherical_coordinate_system#Cartesian_coordinates
I'm not sure I'm 100% correct, but here are my calculations:
#declare fL = function(x,y,z) {acosd(y/sqrt(x*x+y*y+z*z))/180*100}
#declare fC = function(x,y,z) {sqrt(x*x+y*y+z*z)*128}
#declare fH = function(x,y,z) {atan2d(z,x)}
	fDist
		fD(fR(L,C,H)),
		fD(fG(L,C,H)),
		fD(fB(L,C,H))
I just wish the results were more interesting.
Mike
Download 'cielch_color_solid_sphere_isosurface_light.png' (61 KB)
Preview of image 'cielch_color_solid_sphere_isosurface_light.png'
