POV-Ray : Newsgroups : povray.advanced-users : UV mapping docs confusion Server Time
16 May 2026 17:49:15 EDT (-0400)
  UV mapping docs confusion (Message 1 to 4 of 4)
Subject: UV mapping docs confusion
Date: 19 Nov 2016 18:23:32
Message: <5830def4$1@news.povray.org>
http://wiki.povray.org/content/Reference:UV_Mapping
The docs say, "cone, cylinder : mapping is the same as the lemon object
listed below, however, keep in mind that a true cone is not a cylinder."
This is confusing because the lemon has a base, spindle and cap and I am
not sure the cylinder does too. Can someone explain what this means? Thanks.
Subject: Re: UV mapping docs confusion
Date: 19 Nov 2016 18:44:22
Message: <5830e3d6$1@news.povray.org>
> Thanks.
I was able to figure out what the base, spindle and cap are, but it took
me a while to do so. Could the docs be improved somehow?
Mike
Date: 20 Nov 2016 06:16:39
Message: <58318617$1@news.povray.org>
>> Thanks.
i try to honor developers wording when adding to docs ... perhaps
spindle wouldn't have been /my/ choice but after looking the term up
(for additional clarification) i decided it was safe.
base (beginning or bottom) spindle (middle or axis) cap (end or top) is
the way i rationalized the passage. additionally there are also two more
clues in the lemon object description that mention cylinder. that is ...
in the beginning passage and the very end (see also cone) ... unless
there is ton of confusion i'm leaning towards leaving it as is
Date: 20 Nov 2016 06:27:02
Message: <58318886$1@news.povray.org>
Using those terms is fine. Just tell the reader what they mean.
Mike
