POV-Ray : Newsgroups : povray.advanced-users : Spline disambiguation Server Time
15 May 2024 14:15:39 EDT (-0400)
  Spline disambiguation (Message 1 to 7 of 7)
Subject: Spline disambiguation
Date: 6 Mar 2016 11:35:00
Message: <web.56dc5b683a65c3815e7df57c0@news.povray.org>
So, there are cubic and "natural" splines that can be used independently, and
then there's the bezier spline that seems to only be invoked with lathe and sor.
Is there a true bezier spline that can be used as a regular spline?  Is it the
same as natural spline?  (I would think that given the different name, the
answer is no)
Subject: Re: Spline disambiguation
Date: 6 Mar 2016 12:10:07
Message: <56dc646f@news.povray.org>
> answer is no)
1. Have a look at
https://github.com/LeForgeron/povray/wiki/Splines
2. linear, quadratic and cubic are "regular" splines, of Bézier.
https://en.wikipedia.org/wiki/B%C3%A9zier_curve
So what is your true Bézier spline ?
In lathe, the bezier_spline is made of segments of spline, point 4 of segment N must
be identical to point 1 of segment N+1
but otherwise there is no requirement of continuity of derivative at that point.
Points 2 & 3 of each segments are only control points and are only involved in one
single segment.
Date: 6 Mar 2016 15:33:47
Message: <56dc942b$1@news.povray.org>
> answer is no)
For the "natural" spline, it looks like it's similar to the cubic
spline, but continuing up to the first and last point with curve been
out of controll at those points.
Date: 6 Mar 2016 16:30:28
Message: <56dca174@news.povray.org>
Am 06.03.2016 um 18:10 schrieb Le_Forgeron:
>> answer is no)
Actually, no -- Bezier splines are a particular sub-type of cubic
splines, not vice versa.
The mathematical terms "linear spline", "quadratic spline" and "cubic
spline" refer to the type of functions that make up the spline's
individual segments, in this case 1st, 2nd and 3rd order polynomials
respectively.
Terms like "natural spline", "Bezier spline" or "Catmull-Rom spline" do
not refer to the type of underlying functions, but to specific schemes
of how these functions are parameterized via a set of control points.
It is true, however, that every possible cubic spline can be represented
as a Bezier spline.
As for POV-Ray's "cubic_spline", that's actually a misnomer insofar as
it's not the only cubic spline supported by POV-Ray;
"catmull_rom_spline" would have been a more accurate name.
Date: 6 Mar 2016 16:50:00
Message: <web.56dca4e9b7fce5205e7df57c0@news.povray.org>
So, If I'm interpreting that correctly,
1. the cubic spline is a cubic spline of the CR type.
2. the natural spline is a cubic spline of another.
3. bezier_spline cannot be use in a spline or sphere sweep declaration
Thanks
Date: 6 Mar 2016 17:20:42
Message: <56dcad3a$1@news.povray.org>
Am 06.03.2016 um 22:45 schrieb Bald Eagle:
That is correct.
That's correct as well. It's an inconsistency, and it's /somewhere/ on
the agenda to be resolved, but at present that's how it is.
Date: 6 Mar 2016 18:25:00
Message: <web.56dcbb3db7fce5205e7df57c0@news.povray.org>
Right on.   Not complaining.
Until it's resolved, I always have
http://news.povray.org/web.55fe784eb76273e03fda44f40%40news.povray.org
and
http://www.joshuarenglish.com/cyclopedia/bezier.html
I was just trying to clarify what the status of the splines was.
Thanks
