POV-Ray : Newsgroups : povray.advanced-users : About mm_per_unit Server Time
29 Apr 2024 11:25:02 EDT (-0400)
  About mm_per_unit (Message 1 to 2 of 2)
Subject: About mm_per_unit
Date: 9 Dec 2015 15:09:55
Message: <56688a93$1@news.povray.org>
Presently, you can't use mm_per_unit in a scene.
You can't use it in a #declare as follow:
#declare Dimention = Something * mm_per_unit;
or in a scale statement.
It would be nice if it could be made accessible as a builtin constant
like pi.
That could be usefull to create objects that can auto scale according to
the scale of the scene.
The author of the scene would only need to set that value in the
global_settings, and an imported object could scale itself, adjusting a
fade_distance or media density accordingly.
Subject: Re: About mm_per_unit
Date: 9 Dec 2015 18:46:43
Message: <5668bd63$1@news.povray.org>
Am 09.12.2015 um 21:10 schrieb Alain:
I guess what you want would be
    #declare Dimension = Something / mm_per_unit;
> like pi.
Why not simply declare a suitable variable yourself, and use it like this:
    #declare mm = 10; // one millimeter in POV-Ray units
    global_settings {
      mm_per_unit 1/mm
    #declare Dimension = Something * mm;
