POV-Ray : Newsgroups : povray.advanced-users : Colors too dark and washed out Server Time
20 May 2024 11:43:51 EDT (-0400)
  Colors too dark and washed out (Message 19 to 28 of 38)
Subject: Re: Colors too dark and washed out
Date: 23 Nov 2015 17:25:00
Message: <web.56539152a59c8aaffd54400e0@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> Also, does this mean that Lightsys is out of date?
No, Lightsys is fine, except for one place in CIE_Skylight.inc that uses ambient
where emission would be appropriate in POV-Ray 3.7.  The srgb keyword is
orthogonal to Lightsys.
Date: 23 Nov 2015 18:08:15
Message: <56539c5f$1@news.povray.org>
On 11/23/2015 5:12 PM, Cousin Ricky wrote:
> To Mike:  If you wish to keep the module compatible to 3.6, you obviously cannot
> use emission.  If you want the objects to glow and be compatible with both 3.6
> and 3.7, while keeping radiosity, you must put #version 3.6; at the head of the
> file, and stick with the high ambient.  If you don't care about 3.6
> compatibility, then use emission instead of ambient, and definitely put #version
> 3.7 at the head of the file.  However, with a higher diffuse value (which I
> recommend), you will have less need for emission.
That helps, thanks!
Mike
Date: 23 Nov 2015 18:37:52
Message: <5653a350$1@news.povray.org>
Am 23.11.2015 um 23:12 schrieb Cousin Ricky:
> When I try to render the data directly, the greens from G5 up look very cyan to
> me.  Munsell is supposed to visually space out the hues evenly, but the swath
> from G5 to BP5 transitions very slowly to my eyes.
> What weirds me out is that Munsell uses the very purplish illuminant C instead
> of the normal D65 or D50.  Whether it is used as the color system white point or
> the reference white point I have been unable to find out.  (That information is
> probably available for purchase.)  Worse, I have been unable to understand what
> "reference white point" even means, which certainly hampers my understanding of
> color.
In contrast to colour systems typically used in computer graphics (like
sRGB, CIE RGB, CIE XY etc.), which reference light colours, Munsell is a
system to reference pigment colours. Within the boundaries of such a
system, referencing an illuminant /per se/ doesn't make any sense.
Likewise, giving xyY coordinates for such a system doesn't make sense
either -- unless you also mention the lighting conditions under which
the pigments are viewed, i.e. the illuminant.
I would therefore conclude that the Munsell white point you dug up
refers to the illuminant that was used to measure the pigments' xyY
coordinates.
Thus -- assuming I got the colour physics right on this one -- for
proper representation of the actual Munsell pigments you'd need to
divide the pigment colours by the colour of illuminant C, in order to
undo the presumed white point bias. (Theoretically you'd need to to this
in continuous spectrum space; in practice, you should do this in either
XYZ or sRGB space, but whatever you choose it will be imprecise.)
You also need to make sure that the colour of all light emitters
(light_source, background, ambient_light and emission parameter) is
uniform, but as Munsell at its core only describes pigments, you can
choose any illuminant you like -- I'd recommend D65, i.e. <1,1,1>, to
make the image's overall hue harmonize with the surroundings the image
may be presented in, which will typically be web pages. (The W3C has
standardized sRGB as the colour space for the web, so any "pure" white
or grey on the web corresponds to D65).
As for the term "reference white point", this is the light colour that,
in any given context, corresponds to some "official" white. When talking
about colour systems, the term is synonymous to "system white point"
from all I know.
Date: 23 Nov 2015 18:38:18
Message: <5653a36a$1@news.povray.org>
Am 23.11.2015 um 22:37 schrieb Mike Horvath:
> On 11/23/2015 4:10 PM, clipka wrote:
>> Am 23.11.2015 um 21:08 schrieb Mike Horvath:
>>> Okay, I just re-rendered the scene specifying #version 3.6 instead of
>>> #version 3.7. There is a huge difference! I cannot explain it however. I
>>> don't know why there is such a big difference.
>> Specifying "#version 3.6" will put POV-Ray in backward compatibility
>> mode; among other thins, this will re-activating the "ambient" mechanism
>> even when radiosity is used, which might explain the difference.
> So, radiosity automatically turns ambient off in 3.7?
Exactly.
Date: 23 Nov 2015 18:42:00
Message: <5653a448$1@news.povray.org>
Am 23.11.2015 um 22:10 schrieb clipka:
(Darn, I've written better English before...)
Date: 23 Nov 2015 18:52:36
Message: <5653a6c4$1@news.povray.org>
On 11/23/2015 6:08 PM, Mike Horvath wrote:
> That helps, thanks!
> Mike
I should clarify, the colors are now lighter, but they are still washed out.
Mike
Date: 23 Nov 2015 20:21:59
Message: <5653bbb7@news.povray.org>
I just noticed that the data I am using has no values where C (chroma)
is zero. Shouldn't there be a column of gray values up the middle of the
shape?
Mike
On 11/22/2015 2:55 PM, Mike Horvath wrote:
> I am trying to re-render the Munsell color cylinder scene from the
> object collection. However, the results look too drab. Compare it to this:
> https://commons.wikimedia.org/wiki/File:Munsell_1929_color_solid.png
> Does anyone have any tips to improve the render?
> // Title: Munsell 1929 color solid v1.1
> // Author: Michael Horvath, http://isometricland.net
> // Created: 2009-11-10
> // Updated: 2015-11-22
> // This file is licensed under the terms of the CC-LGPL.
//------------------------------------------------------------------------------Includes
> #version 3.7
> #include "functions.inc"
> #include "math.inc"
> #include "CIE.inc"                    //
> http://www.ignorancia.org/en/index.php?page=Lightsys
//------------------------------------------------------------------------------Scenery
> global_settings
>      assumed_gamma    1.0
>      adc_bailout        0.005
>      max_trace_level    50
>      ambient_light    1
>      radiosity
>          pretrace_start    0.08
>          pretrace_end    0.01
>          count        50
>          error_bound    0.1
>          recursion_limit    1
>          normal        on
>          brightness    0.8
>          always_sample    yes
>          gray_threshold    0.8
>          media        on
> background {color srgb 1}
> light_source
>      <-1,+1,-1,> * 300
>      color srgb    1
>      parallel
> #local Muns_cam_view = 0;
> camera
>      #local Muns_cam_distance =    20;
>      #local Muns_cam_planesize =    3;
>      #local Muns_cam_aspectratio =    image_width/image_height;
>      orthographic
>      location    -z * Muns_cam_distance
>      direction    +z// * Muns_cam_distance
>      right        +x * Muns_cam_planesize
>      up        +y * Muns_cam_planesize/Muns_cam_aspectratio
>      #switch (Muns_cam_view)
>          #case (0)
>              rotate        +x * asind(tand(30))
>              rotate        +y * 045
> //            rotate        +y * 180
>          #break
>          #case (1)
>              rotate        +x * 090
>              rotate        +y * 045
>              rotate        +y * 180
>          #case (2)
>              rotate        +y * 045
>              rotate        +y * 180
>          #break
>      #end
> //------------------------------------------------------------------------------CSG
> objects
> // Munsell Renotation Data, http://www.cis.rit.edu/mcsl/online/munsell.php
> // h,    V,    C,    x,        y,        Y
> #declare Muns_coo_table = array[956][6]
> {002.5,    02,    02,    00.3825,    00.3785,    03.1260},
> {005.0,    02,    02,    00.3757,    00.3839,    03.1260},
> {007.5,    02,    02,    00.3660,    00.3858,    03.1260},
> {010.0,    02,    02,    00.3556,    00.3848,    03.1260},
> {012.5,    02,    02,    00.3421,    00.3803,    03.1260},
> {015.0,    02,    02,    00.3309,    00.3743,    03.1260},
> {017.5,    02,    02,    00.3165,    00.3650,    03.1260},
> {020.0,    02,    02,    00.3069,    00.3580,    03.1260},
> {022.5,    02,    02,    00.2978,    00.3507,    03.1260},
> {025.0,    02,    02,    00.2918,    00.3450,    03.1260},
> {027.5,    02,    02,    00.2869,    00.3400,    03.1260},
> {030.0,    02,    02,    00.2820,    00.3341,    03.1260},
> {032.5,    02,    02,    00.2765,    00.3271,    03.1260},
> {035.0,    02,    02,    00.2697,    00.3175,    03.1260},
> {037.5,    02,    02,    00.2651,    00.3098,    03.1260},
> {040.0,    02,    02,    00.2606,    00.3010,    03.1260},
> {042.5,    02,    02,    00.2578,    00.2940,    03.1260},
> {045.0,    02,    02,    00.2559,    00.2874,    03.1260},
> {047.5,    02,    02,    00.2545,    00.2799,    03.1260},
> {050.0,    02,    02,    00.2558,    00.2725,    03.1260},
> {052.5,    02,    02,    00.2592,    00.2675,    03.1260},
> {055.0,    02,    02,    00.2638,    00.2624,    03.1260},
> {057.5,    02,    02,    00.2712,    00.2582,    03.1260},
> {060.0,    02,    02,    00.2803,    00.2567,    03.1260},
> {062.5,    02,    02,    00.2892,    00.2583,    03.1260},
> {065.0,    02,    02,    00.2984,    00.2612,    03.1260},
> {067.5,    02,    02,    00.3071,    00.2647,    03.1260},
> {070.0,    02,    02,    00.3161,    00.2691,    03.1260},
> {072.5,    02,    02,    00.3279,    00.2754,    03.1260},
> {075.0,    02,    02,    00.3383,    00.2829,    03.1260},
> {077.5,    02,    02,    00.3459,    00.2892,    03.1260},
> {080.0,    02,    02,    00.3532,    00.2957,    03.1260},
> {082.5,    02,    02,    00.3614,    00.3033,    03.1260},
> {085.0,    02,    02,    00.3692,    00.3111,    03.1260},
> {087.5,    02,    02,    00.3751,    00.3181,    03.1260},
> {090.0,    02,    02,    00.3811,    00.3274,    03.1260},
> {092.5,    02,    02,    00.3852,    00.3365,    03.1260},
> {095.0,    02,    02,    00.3880,    00.3476,    03.1260},
> {097.5,    02,    02,    00.3889,    00.3590,    03.1260},
> {100.0,    02,    02,    00.3872,    00.3688,    03.1260},
> {032.5,    02,    04,    00.2343,    00.3378,    03.1260},
> {035.0,    02,    04,    00.2234,    00.3150,    03.1260},
> {037.5,    02,    04,    00.2162,    00.2981,    03.1260},
> {047.5,    02,    04,    00.2063,    00.2400,    03.1260},
> {050.0,    02,    04,    00.2102,    00.2313,    03.1260},
> {052.5,    02,    04,    00.2175,    00.2245,    03.1260},
> {055.0,    02,    04,    00.2263,    00.2192,    03.1260},
> {057.5,    02,    04,    00.2420,    00.2148,    03.1260},
> {060.0,    02,    04,    00.2600,    00.2162,    03.1260},
> {062.5,    02,    04,    00.2758,    00.2208,    03.1260},
> {065.0,    02,    04,    00.2908,    00.2261,    03.1260},
> {067.5,    02,    04,    00.3048,    00.2321,    03.1260},
> {070.0,    02,    04,    00.3189,    00.2390,    03.1260},
> {072.5,    02,    04,    00.3382,    00.2496,    03.1260},
> {075.0,    02,    04,    00.3558,    00.2597,    03.1260},
> {077.5,    02,    04,    00.3702,    00.2683,    03.1260},
> {080.0,    02,    04,    00.3850,    00.2778,    03.1260},
> {082.5,    02,    04,    00.4021,    00.2900,    03.1260},
> {085.0,    02,    04,    00.4184,    00.3032,    03.1260},
> {087.5,    02,    04,    00.4335,    00.3169,    03.1260},
> {052.5,    02,    06,    00.1825,    00.1857,    03.1260},
> {055.0,    02,    06,    00.1942,    00.1811,    03.1260},
> {057.5,    02,    06,    00.2189,    00.1790,    03.1260},
> {060.0,    02,    06,    00.2440,    00.1840,    03.1260},
> {062.5,    02,    06,    00.2661,    00.1921,    03.1260},
> {065.0,    02,    06,    00.2850,    00.1992,    03.1260},
> {067.5,    02,    06,    00.3025,    00.2058,    03.1260},
> {070.0,    02,    06,    00.3207,    00.2132,    03.1260},
> {072.5,    02,    06,    00.3470,    00.2259,    03.1260},
> {075.0,    02,    06,    00.3708,    00.2380,    03.1260},
> {077.5,    02,    06,    00.3918,    00.2490,    03.1260},
> {080.0,    02,    06,    00.4139,    00.2608,    03.1260},
> {082.5,    02,    06,    00.4390,    00.2760,    03.1260},
> {085.0,    02,    06,    00.4642,    00.2934,    03.1260},
> {080.0,    02,    08,    00.4428,    00.2419,    03.1260},
> {002.5,    03,    02,    00.3703,    00.3700,    06.5550},
> {005.0,    03,    02,    00.3646,    00.3748,    06.5550},
> {007.5,    03,    02,    00.3589,    00.3778,    06.5550},
> {010.0,    03,    02,    00.3513,    00.3789,    06.5550},
> {012.5,    03,    02,    00.3412,    00.3768,    06.5550},
> {015.0,    03,    02,    00.3319,    00.3729,    06.5550},
> {017.5,    03,    02,    00.3180,    00.3644,    06.5550},
> {020.0,    03,    02,    00.3088,    00.3578,    06.5550},
> {022.5,    03,    02,    00.2999,    00.3500,    06.5550},
> {025.0,    03,    02,    00.2935,    00.3439,    06.5550},
> {027.5,    03,    02,    00.2890,    00.3391,    06.5550},
> {030.0,    03,    02,    00.2844,    00.3337,    06.5550},
> {032.5,    03,    02,    00.2799,    00.3271,    06.5550},
> {035.0,    03,    02,    00.2742,    00.3192,    06.5550},
> {037.5,    03,    02,    00.2699,    00.3120,    06.5550},
> {040.0,    03,    02,    00.2660,    00.3050,    06.5550},
> {042.5,    03,    02,    00.2636,    00.2983,    06.5550},
> {045.0,    03,    02,    00.2617,    00.2921,    06.5550},
> {047.5,    03,    02,    00.2616,    00.2857,    06.5550},
> {050.0,    03,    02,    00.2631,    00.2801,    06.5550},
> {052.5,    03,    02,    00.2663,    00.2756,    06.5550},
> {055.0,    03,    02,    00.2708,    00.2719,    06.5550},
> {057.5,    03,    02,    00.2777,    00.2687,    06.5550},
> {060.0,    03,    02,    00.2847,    00.2670,    06.5550},
> {062.5,    03,    02,    00.2922,    00.2680,    06.5550},
> {065.0,    03,    02,    00.2997,    00.2700,    06.5550},
> {067.5,    03,    02,    00.3088,    00.2740,    06.5550},
> {070.0,    03,    02,    00.3170,    00.2790,    06.5550},
> {072.5,    03,    02,    00.3272,    00.2861,    06.5550},
> {075.0,    03,    02,    00.3370,    00.2940,    06.5550},
> {077.5,    03,    02,    00.3450,    00.3001,    06.5550},
> {080.0,    03,    02,    00.3526,    00.3068,    06.5550},
> {082.5,    03,    02,    00.3591,    00.3130,    06.5550},
> {085.0,    03,    02,    00.3645,    00.3190,    06.5550},
> {087.5,    03,    02,    00.3690,    00.3248,    06.5550},
> {090.0,    03,    02,    00.3728,    00.3314,    06.5550},
> {092.5,    03,    02,    00.3757,    00.3391,    06.5550},
> {095.0,    03,    02,    00.3771,    00.3476,    06.5550},
> {097.5,    03,    02,    00.3771,    00.3549,    06.5550},
> {100.0,    03,    02,    00.3747,    00.3630,    06.5550},
> {002.5,    03,    04,    00.4277,    00.4166,    06.5550},
> {012.5,    03,    04,    00.3772,    00.4484,    06.5550},
> {015.0,    03,    04,    00.3554,    00.4429,    06.5550},
> {017.5,    03,    04,    00.3270,    00.4288,    06.5550},
> {020.0,    03,    04,    00.3053,    00.4123,    06.5550},
> {022.5,    03,    04,    00.2836,    00.3915,    06.5550},
> {025.0,    03,    04,    00.2711,    00.3780,    06.5550},
> {027.5,    03,    04,    00.2618,    00.3667,    06.5550},
> {030.0,    03,    04,    00.2525,    00.3537,    06.5550},
> {032.5,    03,    04,    00.2437,    00.3386,    06.5550},
> {035.0,    03,    04,    00.2343,    00.3200,    06.5550},
> {037.5,    03,    04,    00.2272,    00.3041,    06.5550},
> {040.0,    03,    04,    00.2221,    00.2886,    06.5550},
> {042.5,    03,    04,    00.2183,    00.2748,    06.5550},
> {045.0,    03,    04,    00.2176,    00.2632,    06.5550},
> {047.5,    03,    04,    00.2200,    00.2536,    06.5550},
> {050.0,    03,    04,    00.2246,    00.2467,    06.5550},
> {052.5,    03,    04,    00.2312,    00.2405,    06.5550},
> {055.0,    03,    04,    00.2393,    00.2361,    06.5550},
> {057.5,    03,    04,    00.2520,    00.2319,    06.5550},
> {060.0,    03,    04,    00.2660,    00.2319,    06.5550},
> {062.5,    03,    04,    00.2792,    00.2342,    06.5550},
> {065.0,    03,    04,    00.2928,    00.2386,    06.5550},
> {067.5,    03,    04,    00.3072,    00.2448,    06.5550},
> {070.0,    03,    04,    00.3214,    00.2517,    06.5550},
> {072.5,    03,    04,    00.3400,    00.2624,    06.5550},
> {075.0,    03,    04,    00.3586,    00.2742,    06.5550},
> {077.5,    03,    04,    00.3739,    00.2851,    06.5550},
> {080.0,    03,    04,    00.3889,    00.2969,    06.5550},
> {082.5,    03,    04,    00.4021,    00.3076,    06.5550},
> {085.0,    03,    04,    00.4148,    00.3190,    06.5550},
> {087.5,    03,    04,    00.4240,    00.3302,    06.5550},
> {090.0,    03,    04,    00.4308,    00.3412,    06.5550},
> {092.5,    03,    04,    00.4360,    00.3563,    06.5550},
> {095.0,    03,    04,    00.4376,    00.3715,    06.5550},
> {097.5,    03,    04,    00.4378,    00.3865,    06.5550},
> {100.0,    03,    04,    00.4341,    00.4018,    06.5550},
> {032.5,    03,    06,    00.2132,    00.3468,    06.5550},
> {035.0,    03,    06,    00.2020,    00.3188,    06.5550},
> {037.5,    03,    06,    00.1928,    00.2958,    06.5550},
> {040.0,    03,    06,    00.1861,    00.2722,    06.5550},
> {042.5,    03,    06,    00.1826,    00.2536,    06.5550},
> {045.0,    03,    06,    00.1835,    00.2375,    06.5550},
> {047.5,    03,    06,    00.1875,    00.2258,    06.5550},
> {050.0,    03,    06,    00.1933,    00.2173,    06.5550},
> {052.5,    03,    06,    00.2022,    00.2101,    06.5550},
> {055.0,    03,    06,    00.2122,    00.2052,    06.5550},
> {057.5,    03,    06,    00.2311,    00.2010,    06.5550},
> {060.0,    03,    06,    00.2511,    00.2031,    06.5550},
> {062.5,    03,    06,    00.2691,    00.2072,    06.5550},
> {065.0,    03,    06,    00.2870,    00.2135,    06.5550},
> {067.5,    03,    06,    00.3057,    00.2208,    06.5550},
> {070.0,    03,    06,    00.3243,    00.2293,    06.5550},
> {072.5,    03,    06,    00.3501,    00.2425,    06.5550},
> {075.0,    03,    06,    00.3765,    00.2569,    06.5550},
> {077.5,    03,    06,    00.3990,    00.2708,    06.5550},
> {080.0,    03,    06,    00.4218,    00.2864,    06.5550},
> {082.5,    03,    06,    00.4409,    00.3009,    06.5550},
> {085.0,    03,    06,    00.4592,    00.3168,    06.5550},
> {087.5,    03,    06,    00.4738,    00.3316,    06.5550},
> {090.0,    03,    06,    00.4854,    00.3467,    06.5550},
> {092.5,    03,    06,    00.4954,    00.3692,    06.5550},
> {047.5,    03,    08,    00.1583,    00.1987,    06.5550},
> {050.0,    03,    08,    00.1658,    00.1905,    06.5550},
> {052.5,    03,    08,    00.1780,    00.1833,    06.5550},
> {055.0,    03,    08,    00.1908,    00.1799,    06.5550},
> {057.5,    03,    08,    00.2149,    00.1761,    06.5550},
> {060.0,    03,    08,    00.2387,    00.1786,    06.5550},
> {062.5,    03,    08,    00.2615,    00.1845,    06.5550},
> {065.0,    03,    08,    00.2819,    00.1910,    06.5550},
> {067.5,    03,    08,    00.3037,    00.1981,    06.5550},
> {070.0,    03,    08,    00.3269,    00.2075,    06.5550},
> {072.5,    03,    08,    00.3598,    00.2233,    06.5550},
> {075.0,    03,    08,    00.3930,    00.2395,    06.5550},
> {077.5,    03,    08,    00.4234,    00.2556,    06.5550},
> {080.0,    03,    08,    00.4552,    00.2741,    06.5550},
> {082.5,    03,    08,    00.4821,    00.2918,    06.5550},
> {085.0,    03,    08,    00.5064,    00.3114,    06.5550},
> {087.5,    03,    08,    00.5251,    00.3297,    06.5550},
> {052.5,    03,    10,    00.1576,    00.1600,    06.5550},
> {055.0,    03,    10,    00.1718,    00.1562,    06.5550},
> {057.5,    03,    10,    00.2005,    00.1536,    06.5550},
> {060.0,    03,    10,    00.2278,    00.1565,    06.5550},
> {062.5,    03,    10,    00.2548,    00.1638,    06.5550},
> {065.0,    03,    10,    00.2772,    00.1707,    06.5550},
> {067.5,    03,    10,    00.3020,    00.1794,    06.5550},
> {070.0,    03,    10,    00.3286,    00.1889,    06.5550},
> {072.5,    03,    10,    00.3681,    00.2054,    06.5550},
> {075.0,    03,    10,    00.4073,    00.2235,    06.5550},
> {077.5,    03,    10,    00.4445,    00.2419,    06.5550},
> {080.0,    03,    10,    00.4851,    00.2618,    06.5550},
> {082.5,    03,    10,    00.5191,    00.2811,    06.5550},
> {085.0,    03,    10,    00.5500,    00.3024,    06.5550},
> {055.0,    03,    12,    00.1557,    00.1356,    06.5550},
> {002.5,    04,    02,    00.3633,    00.3654,    12.0000},
> {005.0,    04,    02,    00.3590,    00.3701,    12.0000},
> {007.5,    04,    02,    00.3542,    00.3727,    12.0000},
> {010.0,    04,    02,    00.3436,    00.3732,    12.0000},
> {012.5,    04,    02,    00.3382,    00.3706,    12.0000},
> {015.0,    04,    02,    00.3312,    00.3678,    12.0000},
> {017.5,    04,    02,    00.3185,    00.3604,    12.0000},
> {020.0,    04,    02,    00.3109,    00.3550,    12.0000},
> {022.5,    04,    02,    00.3012,    00.3470,    12.0000},
> {025.0,    04,    02,    00.2959,    00.3417,    12.0000},
> {027.5,    04,    02,    00.2919,    00.3371,    12.0000},
> {030.0,    04,    02,    00.2880,    00.3327,    12.0000},
> {032.5,    04,    02,    00.2840,    00.3270,    12.0000},
> {035.0,    04,    02,    00.2799,    00.3208,    12.0000},
> {037.5,    04,    02,    00.2764,    00.3148,    12.0000},
> {040.0,    04,    02,    00.2740,    00.3091,    12.0000},
> {042.5,    04,    02,    00.2727,    00.3038,    12.0000},
> {045.0,    04,    02,    00.2723,    00.2992,    12.0000},
> {047.5,    04,    02,    00.2733,    00.2947,    12.0000},
> {050.0,    04,    02,    00.2753,    00.2910,    12.0000},
> {052.5,    04,    02,    00.2782,    00.2876,    12.0000},
> {055.0,    04,    02,    00.2816,    00.2842,    12.0000},
> {057.5,    04,    02,    00.2861,    00.2819,    12.0000},
> {060.0,    04,    02,    00.2911,    00.2804,    12.0000},
> {062.5,    04,    02,    00.2962,    00.2807,    12.0000},
> {065.0,    04,    02,    00.3022,    00.2825,    12.0000},
> {067.5,    04,    02,    00.3093,    00.2859,    12.0000},
> {070.0,    04,    02,    00.3162,    00.2902,    12.0000},
> {072.5,    04,    02,    00.3231,    00.2951,    12.0000},
> {075.0,    04,    02,    00.3310,    00.3010,    12.0000},
> {077.5,    04,    02,    00.3371,    00.3061,    12.0000},
> {080.0,    04,    02,    00.3417,    00.3106,    12.0000},
> {082.5,    04,    02,    00.3461,    00.3150,    12.0000},
> {085.0,    04,    02,    00.3508,    00.3200,    12.0000},
> {087.5,    04,    02,    00.3538,    00.3236,    12.0000},
> {090.0,    04,    02,    00.3582,    00.3294,    12.0000},
> {092.5,    04,    02,    00.3624,    00.3367,    12.0000},
> {095.0,    04,    02,    00.3651,    00.3442,    12.0000},
> {097.5,    04,    02,    00.3662,    00.3504,    12.0000},
> {100.0,    04,    02,    00.3660,    00.3590,    12.0000},
> {002.5,    04,    04,    00.4138,    00.4076,    12.0000},
> {005.0,    04,    04,    00.4069,    00.4188,    12.0000},
> {007.5,    04,    04,    00.3982,    00.4272,    12.0000},
> {010.0,    04,    04,    00.3871,    00.4321,    12.0000},
> {012.5,    04,    04,    00.3708,    00.4329,    12.0000},
> {015.0,    04,    04,    00.3538,    00.4284,    12.0000},
> {017.5,    04,    04,    00.3281,    00.4157,    12.0000},
> {020.0,    04,    04,    00.3100,    00.4018,    12.0000},
> {022.5,    04,    04,    00.2891,    00.3821,    12.0000},
> {025.0,    04,    04,    00.2781,    00.3704,    12.0000},
> {027.5,    04,    04,    00.2702,    00.3602,    12.0000},
> {030.0,    04,    04,    00.2628,    00.3498,    12.0000},
> {032.5,    04,    04,    00.2552,    00.3375,    12.0000},
> {035.0,    04,    04,    00.2480,    00.3232,    12.0000},
> {037.5,    04,    04,    00.2429,    00.3108,    12.0000},
> {040.0,    04,    04,    00.2384,    00.2984,    12.0000},
> {042.5,    04,    04,    00.2360,    00.2872,    12.0000},
> {045.0,    04,    04,    00.2363,    00.2782,    12.0000},
> {047.5,    04,    04,    00.2388,    00.2704,    12.0000},
> {050.0,    04,    04,    00.2429,    00.2648,    12.0000},
> {052.5,    04,    04,    00.2487,    00.2597,    12.0000},
> {055.0,    04,    04,    00.2562,    00.2560,    12.0000},
> {057.5,    04,    04,    00.2657,    00.2528,    12.0000},
> {060.0,    04,    04,    00.2759,    00.2522,    12.0000},
> {062.5,    04,    04,    00.2855,    00.2531,    12.0000},
> {065.0,    04,    04,    00.2958,    00.2565,    12.0000},
> {067.5,    04,    04,    00.3084,    00.2622,    12.0000},
> {070.0,    04,    04,    00.3210,    00.2686,    12.0000},
> {072.5,    04,    04,    00.3340,    00.2770,    12.0000},
> {075.0,    04,    04,    00.3491,    00.2872,    12.0000},
> {077.5,    04,    04,    00.3612,    00.2963,    12.0000},
> {080.0,    04,    04,    00.3715,    00.3042,    12.0000},
> {082.5,    04,    04,    00.3806,    00.3125,    12.0000},
> {085.0,    04,    04,    00.3916,    00.3223,    12.0000},
> {087.5,    04,    04,    00.3990,    00.3300,    12.0000},
> {090.0,    04,    04,    00.4078,    00.3412,    12.0000},
> {092.5,    04,    04,    00.4141,    00.3539,    12.0000},
> {095.0,    04,    04,    00.4187,    00.3679,    12.0000},
> {097.5,    04,    04,    00.4208,    00.3809,    12.0000},
> {100.0,    04,    04,    00.4189,    00.3948,    12.0000},
> {002.5,    04,    06,    00.4542,    00.4391,    12.0000},
> {012.5,    04,    06,    00.3968,    00.4857,    12.0000},
> {015.0,    04,    06,    00.3718,    00.4852,    12.0000},
> {017.5,    04,    06,    00.3355,    00.4739,    12.0000},
> {020.0,    04,    06,    00.3069,    00.4550,    12.0000},
> {022.5,    04,    06,    00.2735,    00.4215,    12.0000},
> {032.5,    04,    06,    00.2278,    00.3463,    12.0000},
> {035.0,    04,    06,    00.2182,    00.3240,    12.0000},
> {037.5,    04,    06,    00.2113,    00.3052,    12.0000},
> {040.0,    04,    06,    00.2065,    00.2863,    12.0000},
> {042.5,    04,    06,    00.2048,    00.2708,    12.0000},
> {045.0,    04,    06,    00.2060,    00.2572,    12.0000},
> {047.5,    04,    06,    00.2102,    00.2470,    12.0000},
> {050.0,    04,    06,    00.2157,    00.2407,    12.0000},
> {052.5,    04,    06,    00.2235,    00.2343,    12.0000},
> {055.0,    04,    06,    00.2325,    00.2300,    12.0000},
> {057.5,    04,    06,    00.2471,    00.2266,    12.0000},
> {060.0,    04,    06,    00.2618,    00.2263,    12.0000},
> {062.5,    04,    06,    00.2763,    00.2300,    12.0000},
> {065.0,    04,    06,    00.2903,    00.2347,    12.0000},
> {067.5,    04,    06,    00.3076,    00.2416,    12.0000},
> {070.0,    04,    06,    00.3248,    00.2493,    12.0000},
> {072.5,    04,    06,    00.3442,    00.2595,    12.0000},
> {075.0,    04,    06,    00.3671,    00.2733,    12.0000},
> {077.5,    04,    06,    00.3850,    00.2859,    12.0000},
> {080.0,    04,    06,    00.3999,    00.2972,    12.0000},
> {082.5,    04,    06,    00.4141,    00.3085,    12.0000},
> {085.0,    04,    06,    00.4299,    00.3226,    12.0000},
> {087.5,    04,    06,    00.4415,    00.3340,    12.0000},
> {090.0,    04,    06,    00.4535,    00.3500,    12.0000},
> {092.5,    04,    06,    00.4612,    00.3674,    12.0000},
> {095.0,    04,    06,    00.4651,    00.3859,    12.0000},
> {097.5,    04,    06,    00.4655,    00.4029,    12.0000},
> {100.0,    04,    06,    00.4618,    00.4213,    12.0000},
> {042.5,    04,    08,    00.1737,    00.2524,    12.0000},
> {045.0,    04,    08,    00.1759,    00.2345,    12.0000},
> {047.5,    04,    08,    00.1821,    00.2232,    12.0000},
> {050.0,    04,    08,    00.1893,    00.2160,    12.0000},
> {052.5,    04,    08,    00.1995,    00.2094,    12.0000},
> {055.0,    04,    08,    00.2103,    00.2050,    12.0000},
> {057.5,    04,    08,    00.2304,    00.2023,    12.0000},
> {060.0,    04,    08,    00.2497,    00.2038,    12.0000},
> {062.5,    04,    08,    00.2685,    00.2089,    12.0000},
> {065.0,    04,    08,    00.2855,    00.2150,    12.0000},
> {067.5,    04,    08,    00.3066,    00.2228,    12.0000},
> {070.0,    04,    08,    00.3280,    00.2318,    12.0000},
> {072.5,    04,    08,    00.3533,    00.2438,    12.0000},
> {075.0,    04,    08,    00.3833,    00.2600,    12.0000},
> {077.5,    04,    08,    00.4072,    00.2750,    12.0000},
> {080.0,    04,    08,    00.4282,    00.2890,    12.0000},
> {082.5,    04,    08,    00.4472,    00.3031,    12.0000},
> {085.0,    04,    08,    00.4690,    00.3209,    12.0000},
> {087.5,    04,    08,    00.4850,    00.3359,    12.0000},
> {090.0,    04,    08,    00.4995,    00.3557,    12.0000},
> {092.5,    04,    08,    00.5071,    00.3777,    12.0000},
> {095.0,    04,    08,    00.5070,    00.3994,    12.0000},
> {097.5,    04,    08,    00.5038,    00.4204,    12.0000},
> {052.5,    04,    10,    00.1805,    00.1888,    12.0000},
> {055.0,    04,    10,    00.1925,    00.1843,    12.0000},
> {057.5,    04,    10,    00.2158,    00.1811,    12.0000},
> {060.0,    04,    10,    00.2388,    00.1837,    12.0000},
> {062.5,    04,    10,    00.2619,    00.1903,    12.0000},
> {065.0,    04,    10,    00.2814,    00.1967,    12.0000},
> {067.5,    04,    10,    00.3056,    00.2060,    12.0000},
> {070.0,    04,    10,    00.3306,    00.2162,    12.0000},
> {072.5,    04,    10,    00.3608,    00.2301,    12.0000},
> {075.0,    04,    10,    00.3960,    00.2489,    12.0000},
> {077.5,    04,    10,    00.4259,    00.2651,    12.0000},
> {080.0,    04,    10,    00.4528,    00.2811,    12.0000},
> {082.5,    04,    10,    00.4774,    00.2969,    12.0000},
> {085.0,    04,    10,    00.5043,    00.3176,    12.0000},
> {087.5,    04,    10,    00.5235,    00.3351,    12.0000},
> {090.0,    04,    10,    00.5418,    00.3580,    12.0000},
> {092.5,    04,    10,    00.5475,    00.3856,    12.0000},
> {062.5,    04,    12,    00.2559,    00.1730,    12.0000},
> {065.0,    04,    12,    00.2778,    00.1808,    12.0000},
> {067.5,    04,    12,    00.3045,    00.1905,    12.0000},
> {072.5,    04,    12,    00.3683,    00.2162,    12.0000},
> {075.0,    04,    12,    00.4104,    00.2361,    12.0000},
> {077.5,    04,    12,    00.4450,    00.2541,    12.0000},
> {082.5,    04,    12,    00.5072,    00.2897,    12.0000},
> {085.0,    04,    12,    00.5385,    00.3129,    12.0000},
> {087.5,    04,    12,    00.5603,    00.3321,    12.0000},
> {085.0,    04,    14,    00.5734,    00.3057,    12.0000},
> {002.5,    05,    02,    00.3534,    00.3570,    19.7700},
> {005.0,    05,    02,    00.3500,    00.3620,    19.7700},
> {007.5,    05,    02,    00.3470,    00.3640,    19.7700},
> {010.0,    05,    02,    00.3422,    00.3648,    19.7700},
> {012.5,    05,    02,    00.3352,    00.3636,    19.7700},
> {015.0,    05,    02,    00.3289,    00.3612,    19.7700},
> {017.5,    05,    02,    00.3188,    00.3560,    19.7700},
> {020.0,    05,    02,    00.3110,    00.3508,    19.7700},
> {022.5,    05,    02,    00.3030,    00.3445,    19.7700},
> {025.0,    05,    02,    00.2978,    00.3392,    19.7700},
> {027.5,    05,    02,    00.2945,    00.3355,    19.7700},
> {030.0,    05,    02,    00.2910,    00.3310,    19.7700},
> {032.5,    05,    02,    00.2880,    00.3270,    19.7700},
> {035.0,    05,    02,    00.2841,    00.3210,    19.7700},
> {037.5,    05,    02,    00.2812,    00.3161,    19.7700},
> {040.0,    05,    02,    00.2796,    00.3111,    19.7700},
> {042.5,    05,    02,    00.2791,    00.3071,    19.7700},
> {045.0,    05,    02,    00.2794,    00.3032,    19.7700},
> {047.5,    05,    02,    00.2803,    00.3000,    19.7700},
> {050.0,    05,    02,    00.2821,    00.2966,    19.7700},
> {052.5,    05,    02,    00.2847,    00.2942,    19.7700},
> {055.0,    05,    02,    00.2882,    00.2923,    19.7700},
> {057.5,    05,    02,    00.2918,    00.2908,    19.7700},
> {060.0,    05,    02,    00.2959,    00.2905,    19.7700},
> {062.5,    05,    02,    00.3000,    00.2912,    19.7700},
> {065.0,    05,    02,    00.3045,    00.2928,    19.7700},
> {067.5,    05,    02,    00.3103,    00.2959,    19.7700},
> {070.0,    05,    02,    00.3148,    00.2986,    19.7700},
> {072.5,    05,    02,    00.3199,    00.3019,    19.7700},
> {075.0,    05,    02,    00.3256,    00.3065,    19.7700},
> {077.5,    05,    02,    00.3296,    00.3098,    19.7700},
> {080.0,    05,    02,    00.3332,    00.3131,    19.7700},
> {082.5,    05,    02,    00.3360,    00.3158,    19.7700},
> {085.0,    05,    02,    00.3392,    00.3192,    19.7700},
> {087.5,    05,    02,    00.3425,    00.3229,    19.7700},
> {090.0,    05,    02,    00.3465,    00.3278,    19.7700},
> {092.5,    05,    02,    00.3506,    00.3337,    19.7700},
> {095.0,    05,    02,    00.3530,    00.3395,    19.7700},
> {097.5,    05,    02,    00.3540,    00.3445,    19.7700},
> {100.0,    05,    02,    00.3546,    00.3514,    19.7700},
> {002.5,    05,    04,    00.3968,    00.3954,    19.7700},
> {005.0,    05,    04,    00.3915,    00.4057,    19.7700},
> {007.5,    05,    04,    00.3850,    00.4120,    19.7700},
> {010.0,    05,    04,    00.3762,    00.4158,    19.7700},
> {012.5,    05,    04,    00.3621,    00.4143,    19.7700},
> {015.0,    05,    04,    00.3482,    00.4097,    19.7700},
> {017.5,    05,    04,    00.3274,    00.3994,    19.7700},
> {020.0,    05,    04,    00.3111,    00.3881,    19.7700},
> {022.5,    05,    04,    00.2943,    00.3735,    19.7700},
> {025.0,    05,    04,    00.2841,    00.3628,    19.7700},
> {027.5,    05,    04,    00.2775,    00.3545,    19.7700},
> {030.0,    05,    04,    00.2711,    00.3455,    19.7700},
> {032.5,    05,    04,    00.2659,    00.3369,    19.7700},
> {035.0,    05,    04,    00.2591,    00.3246,    19.7700},
> {037.5,    05,    04,    00.2550,    00.3150,    19.7700},
> {040.0,    05,    04,    00.2512,    00.3040,    19.7700},
> {042.5,    05,    04,    00.2492,    00.2954,    19.7700},
> {045.0,    05,    04,    00.2493,    00.2879,    19.7700},
> {047.5,    05,    04,    00.2511,    00.2808,    19.7700},
> {050.0,    05,    04,    00.2547,    00.2757,    19.7700},
> {052.5,    05,    04,    00.2600,    00.2720,    19.7700},
> {055.0,    05,    04,    00.2662,    00.2687,    19.7700},
> {057.5,    05,    04,    00.2739,    00.2666,    19.7700},
> {060.0,    05,    04,    00.2821,    00.2659,    19.7700},
> {062.5,    05,    04,    00.2898,    00.2667,    19.7700},
> {065.0,    05,    04,    00.2986,    00.2699,    19.7700},
> {067.5,    05,    04,    00.3100,    00.2750,    19.7700},
> {070.0,    05,    04,    00.3198,    00.2807,    19.7700},
> {072.5,    05,    04,    00.3298,    00.2869,    19.7700},
> {075.0,    05,    04,    00.3421,    00.2954,    19.7700},
> {077.5,    05,    04,    00.3515,    00.3024,    19.7700},
> {080.0,    05,    04,    00.3594,    00.3090,    19.7700},
> {082.5,    05,    04,    00.3660,    00.3148,    19.7700},
> {085.0,    05,    04,    00.3740,    00.3220,    19.7700},
> {087.5,    05,    04,    00.3806,    00.3294,    19.7700},
> {090.0,    05,    04,    00.3879,    00.3398,    19.7700},
> {092.5,    05,    04,    00.3925,    00.3494,    19.7700},
> {095.0,    05,    04,    00.3968,    00.3614,    19.7700},
> {097.5,    05,    04,    00.3991,    00.3714,    19.7700},
> {100.0,    05,    04,    00.3995,    00.3840,    19.7700},
> {002.5,    05,    06,    00.4380,    00.4292,    19.7700},
> {005.0,    05,    06,    00.4302,    00.4435,    19.7700},
> {007.5,    05,    06,    00.4199,    00.4551,    19.7700},
> {010.0,    05,    06,    00.4072,    00.4621,    19.7700},
> {012.5,    05,    06,    00.3879,    00.4646,    19.7700},
> {015.0,    05,    06,    00.3663,    00.4614,    19.7700},
> {017.5,    05,    06,    00.3354,    00.4483,    19.7700},
> {020.0,    05,    06,    00.3108,    00.4301,    19.7700},
> {022.5,    05,    06,    00.2841,    00.4045,    19.7700},
> {025.0,    05,    06,    00.2690,    00.3860,    19.7700},
> {027.5,    05,    06,    00.2598,    00.3724,    19.7700},
> {030.0,    05,    06,    00.2519,    00.3587,    19.7700},
> {032.5,    05,    06,    00.2448,    00.3452,    19.7700},
> {035.0,    05,    06,    00.2360,    00.3270,    19.7700},
> {037.5,    05,    06,    00.2292,    00.3125,    19.7700},
> {040.0,    05,    06,    00.2234,    00.2952,    19.7700},
> {042.5,    05,    06,    00.2210,    00.2823,    19.7700},
> {045.0,    05,    06,    00.2215,    00.2701,    19.7700},
> {047.5,    05,    06,    00.2248,    00.2612,    19.7700},
> {050.0,    05,    06,    00.2299,    00.2548,    19.7700},
> {052.5,    05,    06,    00.2365,    00.2488,    19.7700},
> {055.0,    05,    06,    00.2447,    00.2449,    19.7700},
> {057.5,    05,    06,    00.2563,    00.2417,    19.7700},
> {060.0,    05,    06,    00.2686,    00.2412,    19.7700},
> {062.5,    05,    06,    00.2806,    00.2444,    19.7700},
> {065.0,    05,    06,    00.2932,    00.2487,    19.7700},
> {067.5,    05,    06,    00.3093,    00.2555,    19.7700},
> {070.0,    05,    06,    00.3243,    00.2630,    19.7700},
> {072.5,    05,    06,    00.3396,    00.2718,    19.7700},
> {075.0,    05,    06,    00.3585,    00.2842,    19.7700},
> {077.5,    05,    06,    00.3726,    00.2941,    19.7700},
> {080.0,    05,    06,    00.3851,    00.3039,    19.7700},
> {082.5,    05,    06,    00.3960,    00.3130,    19.7700},
> {085.0,    05,    06,    00.4078,    00.3238,    19.7700},
> {087.5,    05,    06,    00.4180,    00.3348,    19.7700},
> {090.0,    05,    06,    00.4299,    00.3499,    19.7700},
> {092.5,    05,    06,    00.4365,    00.3640,    19.7700},
> {095.0,    05,    06,    00.4420,    00.3808,    19.7700},
> {097.5,    05,    06,    00.4440,    00.3954,    19.7700},
> {100.0,    05,    06,    00.4428,    00.4128,    19.7700},
> {002.5,    05,    08,    00.4685,    00.4524,    19.7700},
> {012.5,    05,    08,    00.4088,    00.5068,    19.7700},
> {015.0,    05,    08,    00.3815,    00.5093,    19.7700},
> {017.5,    05,    08,    00.3412,    00.4976,    19.7700},
> {020.0,    05,    08,    00.3080,    00.4759,    19.7700},
> {022.5,    05,    08,    00.2710,    00.4380,    19.7700},
> {025.0,    05,    08,    00.2511,    00.4107,    19.7700},
> {027.5,    05,    08,    00.2395,    00.3915,    19.7700},
> {052.5,    05,    08,    00.2157,    00.2278,    19.7700},
> {055.0,    05,    08,    00.2255,    00.2239,    19.7700},
> {057.5,    05,    08,    00.2417,    00.2204,    19.7700},
> {060.0,    05,    08,    00.2572,    00.2211,    19.7700},
> {062.5,    05,    08,    00.2728,    00.2240,    19.7700},
> {065.0,    05,    08,    00.2885,    00.2296,    19.7700},
> {067.5,    05,    08,    00.3087,    00.2375,    19.7700},
> {070.0,    05,    08,    00.3280,    00.2464,    19.7700},
> {072.5,    05,    08,    00.3490,    00.2570,    19.7700},
> {075.0,    05,    08,    00.3748,    00.2729,    19.7700},
> {077.5,    05,    08,    00.3932,    00.2852,    19.7700},
> {080.0,    05,    08,    00.4105,    00.2980,    19.7700},
> {082.5,    05,    08,    00.4252,    00.3101,    19.7700},
> {085.0,    05,    08,    00.4413,    00.3240,    19.7700},
> {087.5,    05,    08,    00.4563,    00.3387,    19.7700},
> {090.0,    05,    08,    00.4713,    00.3575,    19.7700},
> {092.5,    05,    08,    00.4795,    00.3758,    19.7700},
> {095.0,    05,    08,    00.4830,    00.3960,    19.7700},
> {097.5,    05,    08,    00.4820,    00.4141,    19.7700},
> {100.0,    05,    08,    00.4770,    00.4338,    19.7700},
> {055.0,    05,    10,    00.2080,    00.2041,    19.7700},
> {057.5,    05,    10,    00.2285,    00.2020,    19.7700},
> {060.0,    05,    10,    00.2478,    00.2030,    19.7700},
> {062.5,    05,    10,    00.2665,    00.2075,    19.7700},
> {065.0,    05,    10,    00.2845,    00.2137,    19.7700},
> {067.5,    05,    10,    00.3080,    00.2230,    19.7700},
> {070.0,    05,    10,    00.3308,    00.2328,    19.7700},
> {072.5,    05,    10,    00.3560,    00.2452,    19.7700},
> {075.0,    05,    10,    00.3880,    00.2630,    19.7700},
> {077.5,    05,    10,    00.4108,    00.2773,    19.7700},
> {080.0,    05,    10,    00.4332,    00.2918,    19.7700},
> {082.5,    05,    10,    00.4533,    00.3058,    19.7700},
> {085.0,    05,    10,    00.4747,    00.3227,    19.7700},
> {087.5,    05,    10,    00.4927,    00.3399,    19.7700},
> {090.0,    05,    10,    00.5113,    00.3630,    19.7700},
> {092.5,    05,    10,    00.5175,    00.3844,    19.7700},
> {095.0,    05,    10,    00.5161,    00.4064,    19.7700},
> {097.5,    05,    10,    00.5108,    00.4276,    19.7700},
> {082.5,    05,    12,    00.4820,    00.3002,    19.7700},
> {085.0,    05,    12,    00.5071,    00.3194,    19.7700},
> {087.5,    05,    12,    00.5280,    00.3389,    19.7700},
> {002.5,    06,    02,    00.3480,    00.3540,    30.0500},
> {005.0,    06,    02,    00.3457,    00.3580,    30.0500},
> {007.5,    06,    02,    00.3431,    00.3601,    30.0500},
> {010.0,    06,    02,    00.3398,    00.3611,    30.0500},
> {012.5,    06,    02,    00.3342,    00.3607,    30.0500},
> {015.0,    06,    02,    00.3288,    00.3592,    30.0500},
> {017.5,    06,    02,    00.3193,    00.3550,    30.0500},
> {020.0,    06,    02,    00.3112,    00.3496,    30.0500},
> {022.5,    06,    02,    00.3039,    00.3437,    30.0500},
> {025.0,    06,    02,    00.2988,    00.3382,    30.0500},
> {027.5,    06,    02,    00.2958,    00.3344,    30.0500},
> {030.0,    06,    02,    00.2929,    00.3303,    30.0500},
> {032.5,    06,    02,    00.2902,    00.3268,    30.0500},
> {035.0,    06,    02,    00.2872,    00.3219,    30.0500},
> {037.5,    06,    02,    00.2849,    00.3172,    30.0500},
> {040.0,    06,    02,    00.2837,    00.3132,    30.0500},
> {042.5,    06,    02,    00.2835,    00.3097,    30.0500},
> {045.0,    06,    02,    00.2842,    00.3063,    30.0500},
> {047.5,    06,    02,    00.2854,    00.3037,    30.0500},
> {050.0,    06,    02,    00.2871,    00.3012,    30.0500},
> {052.5,    06,    02,    00.2897,    00.2991,    30.0500},
> {055.0,    06,    02,    00.2923,    00.2978,    30.0500},
> {057.5,    06,    02,    00.2955,    00.2963,    30.0500},
> {060.0,    06,    02,    00.2988,    00.2961,    30.0500},
> {062.5,    06,    02,    00.3016,    00.2960,    30.0500},
> {065.0,    06,    02,    00.3050,    00.2967,    30.0500},
> {067.5,    06,    02,    00.3107,    00.2993,    30.0500},
> {070.0,    06,    02,    00.3146,    00.3018,    30.0500},
> {072.5,    06,    02,    00.3188,    00.3048,    30.0500},
> {075.0,    06,    02,    00.3232,    00.3085,    30.0500},
> {077.5,    06,    02,    00.3261,    00.3113,    30.0500},
> {080.0,    06,    02,    00.3292,    00.3141,    30.0500},
> {082.5,    06,    02,    00.3318,    00.3166,    30.0500},
> {085.0,    06,    02,    00.3343,    00.3190,    30.0500},
> {087.5,    06,    02,    00.3381,    00.3228,    30.0500},
> {090.0,    06,    02,    00.3417,    00.3268,    30.0500},
> {092.5,    06,    02,    00.3453,    00.3321,    30.0500},
> {095.0,    06,    02,    00.3474,    00.3373,    30.0500},
> {097.5,    06,    02,    00.3487,    00.3421,    30.0500},
> {100.0,    06,    02,    00.3491,    00.3483,    30.0500},
> {002.5,    06,    04,    00.3840,    00.3867,    30.0500},
> {005.0,    06,    04,    00.3794,    00.3955,    30.0500},
> {007.5,    06,    04,    00.3745,    00.4004,    30.0500},
> {010.0,    06,    04,    00.3679,    00.4033,    30.0500},
> {012.5,    06,    04,    00.3572,    00.4038,    30.0500},
> {015.0,    06,    04,    00.3461,    00.4008,    30.0500},
> {017.5,    06,    04,    00.3275,    00.3922,    30.0500},
> {020.0,    06,    04,    00.3124,    00.3822,    30.0500},
> {022.5,    06,    04,    00.2967,    00.3695,    30.0500},
> {025.0,    06,    04,    00.2868,    00.3595,    30.0500},
> {027.5,    06,    04,    00.2807,    00.3522,    30.0500},
> {030.0,    06,    04,    00.2749,    00.3443,    30.0500},
> {032.5,    06,    04,    00.2702,    00.3369,    30.0500},
> {035.0,    06,    04,    00.2648,    00.3262,    30.0500},
> {037.5,    06,    04,    00.2604,    00.3169,    30.0500},
> {040.0,    06,    04,    00.2578,    00.3078,    30.0500},
> {042.5,    06,    04,    00.2571,    00.3008,    30.0500},
> {045.0,    06,    04,    00.2579,    00.2938,    30.0500},
> {047.5,    06,    04,    00.2602,    00.2881,    30.0500},
> {050.0,    06,    04,    00.2637,    00.2840,    30.0500},
> {052.5,    06,    04,    00.2684,    00.2804,    30.0500},
> {055.0,    06,    04,    00.2734,    00.2778,    30.0500},
> {057.5,    06,    04,    00.2798,    00.2752,    30.0500},
> {060.0,    06,    04,    00.2863,    00.2747,    30.0500},
> {062.5,    06,    04,    00.2932,    00.2759,    30.0500},
> {065.0,    06,    04,    00.3001,    00.2778,    30.0500},
> {067.5,    06,    04,    00.3107,    00.2831,    30.0500},
> {070.0,    06,    04,    00.3181,    00.2871,    30.0500},
> {072.5,    06,    04,    00.3272,    00.2929,    30.0500},
> {075.0,    06,    04,    00.3371,    00.3001,    30.0500},
> {077.5,    06,    04,    00.3439,    00.3056,    30.0500},
> {080.0,    06,    04,    00.3508,    00.3112,    30.0500},
> {082.5,    06,    04,    00.3566,    00.3163,    30.0500},
> {085.0,    06,    04,    00.3628,    00.3221,    30.0500},
> {087.5,    06,    04,    00.3692,    00.3291,    30.0500},
> {090.0,    06,    04,    00.3768,    00.3381,    30.0500},
> {092.5,    06,    04,    00.3806,    00.3467,    30.0500},
> {095.0,    06,    04,    00.3840,    00.3564,    30.0500},
> {097.5,    06,    04,    00.3860,    00.3652,    30.0500},
> {100.0,    06,    04,    00.3861,    00.3767,    30.0500},
> {002.5,    06,    06,    00.4203,    00.4176,    30.0500},
> {005.0,    06,    06,    00.4140,    00.4305,    30.0500},
> {007.5,    06,    06,    00.4060,    00.4400,    30.0500},
> {010.0,    06,    06,    00.3960,    00.4452,    30.0500},
> {012.5,    06,    06,    00.3799,    00.4470,    30.0500},
> {015.0,    06,    06,    00.3622,    00.4438,    30.0500},
> {017.5,    06,    06,    00.3351,    00.4321,    30.0500},
> {020.0,    06,    06,    00.3128,    00.4175,    30.0500},
> {022.5,    06,    06,    00.2892,    00.3963,    30.0500},
> {025.0,    06,    06,    00.2748,    00.3795,    30.0500},
> {027.5,    06,    06,    00.2662,    00.3672,    30.0500},
> {030.0,    06,    06,    00.2591,    00.3558,    30.0500},
> {032.5,    06,    06,    00.2526,    00.3448,    30.0500},
> {035.0,    06,    06,    00.2441,    00.3290,    30.0500},
> {037.5,    06,    06,    00.2384,    00.3155,    30.0500},
> {040.0,    06,    06,    00.2335,    00.3015,    30.0500},
> {042.5,    06,    06,    00.2312,    00.2899,    30.0500},
> {045.0,    06,    06,    00.2320,    00.2789,    30.0500},
> {047.5,    06,    06,    00.2352,    00.2708,    30.0500},
> {050.0,    06,    06,    00.2399,    00.2650,    30.0500},
> {052.5,    06,    06,    00.2465,    00.2599,    30.0500},
> {055.0,    06,    06,    00.2533,    00.2558,    30.0500},
> {057.5,    06,    06,    00.2638,    00.2531,    30.0500},
> {060.0,    06,    06,    00.2740,    00.2533,    30.0500},
> {062.5,    06,    06,    00.2842,    00.2550,    30.0500},
> {065.0,    06,    06,    00.2950,    00.2585,    30.0500},
> {067.5,    06,    06,    00.3101,    00.2650,    30.0500},
> {070.0,    06,    06,    00.3226,    00.2716,    30.0500},
> {072.5,    06,    06,    00.3362,    00.2799,    30.0500},
> {075.0,    06,    06,    00.3520,    00.2904,    30.0500},
> {077.5,    06,    06,    00.3635,    00.2987,    30.0500},
> {080.0,    06,    06,    00.3740,    00.3074,    30.0500},
> {082.5,    06,    06,    00.3832,    00.3158,    30.0500},
> {085.0,    06,    06,    00.3921,    00.3244,    30.0500},
> {087.5,    06,    06,    00.4000,    00.3340,    30.0500},
> {090.0,    06,    06,    00.4103,    00.3473,    30.0500},
> {092.5,    06,    06,    00.4180,    00.3600,    30.0500},
> {095.0,    06,    06,    00.4229,    00.3750,    30.0500},
> {097.5,    06,    06,    00.4242,    00.3876,    30.0500},
> {100.0,    06,    06,    00.4240,    00.4030,    30.0500},
> {002.5,    06,    08,    00.4517,    00.4421,    30.0500},
> {005.0,    06,    08,    00.4426,    00.4588,    30.0500},
> {007.5,    06,    08,    00.4321,    00.4719,    30.0500},
> {012.5,    06,    08,    00.4006,    00.4885,    30.0500},
> {015.0,    06,    08,    00.3772,    00.4880,    30.0500},
> {017.5,    06,    08,    00.3418,    00.4768,    30.0500},
> {020.0,    06,    08,    00.3116,    00.4563,    30.0500},
> {022.5,    06,    08,    00.2799,    00.4239,    30.0500},
> {052.5,    06,    08,    00.2274,    00.2406,    30.0500},
> {055.0,    06,    08,    00.2360,    00.2365,    30.0500},
> {057.5,    06,    08,    00.2505,    00.2347,    30.0500},
> {060.0,    06,    08,    00.2637,    00.2352,    30.0500},
> {062.5,    06,    08,    00.2770,    00.2372,    30.0500},
> {065.0,    06,    08,    00.2905,    00.2421,    30.0500},
> {067.5,    06,    08,    00.3099,    00.2502,    30.0500},
> {070.0,    06,    08,    00.3259,    00.2584,    30.0500},
> {072.5,    06,    08,    00.3437,    00.2688,    30.0500},
> {075.0,    06,    08,    00.3648,    00.2820,    30.0500},
> {077.5,    06,    08,    00.3791,    00.2929,    30.0500},
> {080.0,    06,    08,    00.3930,    00.3038,    30.0500},
> {082.5,    06,    08,    00.4065,    00.3144,    30.0500},
> {085.0,    06,    08,    00.4187,    00.3251,    30.0500},
> {087.5,    06,    08,    00.4318,    00.3383,    30.0500},
> {090.0,    06,    08,    00.4449,    00.3550,    30.0500},
> {092.5,    06,    08,    00.4533,    00.3708,    30.0500},
> {095.0,    06,    08,    00.4592,    00.3900,    30.0500},
> {097.5,    06,    08,    00.4596,    00.4064,    30.0500},
> {100.0,    06,    08,    00.4570,    00.4249,    30.0500},
> {002.5,    06,    10,    00.4760,    00.4607,    30.0500},
> {017.5,    06,    10,    00.3463,    00.5196,    30.0500},
> {020.0,    06,    10,    00.3086,    00.4949,    30.0500},
> {072.5,    06,    10,    00.3509,    00.2578,    30.0500},
> {075.0,    06,    10,    00.3769,    00.2738,    30.0500},
> {077.5,    06,    10,    00.3960,    00.2860,    30.0500},
> {080.0,    06,    10,    00.4150,    00.2989,    30.0500},
> {082.5,    06,    10,    00.4320,    00.3118,    30.0500},
> {085.0,    06,    10,    00.4480,    00.3250,    30.0500},
> {087.5,    06,    10,    00.4655,    00.3412,    30.0500},
> {090.0,    06,    10,    00.4812,    00.3619,    30.0500},
> {092.5,    06,    10,    00.4891,    00.3806,    30.0500},
> {095.0,    06,    10,    00.4921,    00.4022,    30.0500},
> {097.5,    06,    10,    00.4904,    00.4220,    30.0500},
> {100.0,    06,    10,    00.4843,    00.4416,    30.0500},
> {092.5,    06,    12,    00.5215,    00.3887,    30.0500},
> {095.0,    06,    12,    00.5199,    00.4119,    30.0500},
> {097.5,    06,    12,    00.5145,    00.4331,    30.0500},
> {002.5,    07,    02,    00.3436,    00.3507,    43.0600},
> {005.0,    07,    02,    00.3419,    00.3540,    43.0600},
> {007.5,    07,    02,    00.3396,    00.3558,    43.0600},
> {010.0,    07,    02,    00.3369,    00.3569,    43.0600},
> {012.5,    07,    02,    00.3328,    00.3569,    43.0600},
> {015.0,    07,    02,    00.3284,    00.3559,    43.0600},
> {017.5,    07,    02,    00.3190,    00.3516,    43.0600},
> {020.0,    07,    02,    00.3117,    00.3469,    43.0600},
> {022.5,    07,    02,    00.3047,    00.3413,    43.0600},
> {025.0,    07,    02,    00.3001,    00.3366,    43.0600},
> {027.5,    07,    02,    00.2972,    00.3333,    43.0600},
> {030.0,    07,    02,    00.2945,    00.3297,    43.0600},
> {032.5,    07,    02,    00.2927,    00.3269,    43.0600},
> {035.0,    07,    02,    00.2898,    00.3225,    43.0600},
> {037.5,    07,    02,    00.2878,    00.3182,    43.0600},
> {040.0,    07,    02,    00.2869,    00.3143,    43.0600},
> {042.5,    07,    02,    00.2867,    00.3110,    43.0600},
> {045.0,    07,    02,    00.2875,    00.3078,    43.0600},
> {047.5,    07,    02,    00.2888,    00.3058,    43.0600},
> {050.0,    07,    02,    00.2908,    00.3039,    43.0600},
> {052.5,    07,    02,    00.2932,    00.3025,    43.0600},
> {055.0,    07,    02,    00.2952,    00.3011,    43.0600},
> {057.5,    07,    02,    00.2982,    00.3003,    43.0600},
> {060.0,    07,    02,    00.3005,    00.3000,    43.0600},
> {062.5,    07,    02,    00.3031,    00.3000,    43.0600},
> {065.0,    07,    02,    00.3059,    00.3010,    43.0600},
> {067.5,    07,    02,    00.3109,    00.3037,    43.0600},
> {070.0,    07,    02,    00.3138,    00.3054,    43.0600},
> {072.5,    07,    02,    00.3170,    00.3076,    43.0600},
> {075.0,    07,    02,    00.3206,    00.3104,    43.0600},
> {077.5,    07,    02,    00.3232,    00.3125,    43.0600},
> {080.0,    07,    02,    00.3258,    00.3148,    43.0600},
> {082.5,    07,    02,    00.3284,    00.3170,    43.0600},
> {085.0,    07,    02,    00.3306,    00.3190,    43.0600},
> {087.5,    07,    02,    00.3335,    00.3220,    43.0600},
> {090.0,    07,    02,    00.3360,    00.3253,    43.0600},
> {092.5,    07,    02,    00.3392,    00.3298,    43.0600},
> {095.0,    07,    02,    00.3421,    00.3349,    43.0600},
> {097.5,    07,    02,    00.3437,    00.3397,    43.0600},
> {100.0,    07,    02,    00.3443,    00.3454,    43.0600},
> {002.5,    07,    04,    00.3761,    00.3800,    43.0600},
> {005.0,    07,    04,    00.3718,    00.3885,    43.0600},
> {007.5,    07,    04,    00.3677,    00.3925,    43.0600},
> {010.0,    07,    04,    00.3624,    00.3951,    43.0600},
> {012.5,    07,    04,    00.3534,    00.3953,    43.0600},
> {015.0,    07,    04,    00.3437,    00.3929,    43.0600},
> {017.5,    07,    04,    00.3267,    00.3848,    43.0600},
> {020.0,    07,    04,    00.3133,    00.3764,    43.0600},
> {022.5,    07,    04,    00.2992,    00.3644,    43.0600},
> {025.0,    07,    04,    00.2902,    00.3548,    43.0600},
> {027.5,    07,    04,    00.2850,    00.3482,    43.0600},
> {030.0,    07,    04,    00.2803,    00.3415,    43.0600},
> {032.5,    07,    04,    00.2764,    00.3354,    43.0600},
> {035.0,    07,    04,    00.2712,    00.3269,    43.0600},
> {037.5,    07,    04,    00.2671,    00.3189,    43.0600},
> {040.0,    07,    04,    00.2642,    00.3109,    43.0600},
> {042.5,    07,    04,    00.2629,    00.3038,    43.0600},
> {045.0,    07,    04,    00.2633,    00.2972,    43.0600},
> {047.5,    07,    04,    00.2651,    00.2927,    43.0600},
> {050.0,    07,    04,    00.2685,    00.2886,    43.0600},
> {052.5,    07,    04,    00.2729,    00.2848,    43.0600},
> {055.0,    07,    04,    00.2773,    00.2828,    43.0600},
> {057.5,    07,    04,    00.2833,    00.2809,    43.0600},
> {060.0,    07,    04,    00.2886,    00.2801,    43.0600},
> {062.5,    07,    04,    00.2950,    00.2810,    43.0600},
> {065.0,    07,    04,    00.3009,    00.2831,    43.0600},
> {067.5,    07,    04,    00.3111,    00.2880,    43.0600},
> {070.0,    07,    04,    00.3181,    00.2920,    43.0600},
> {072.5,    07,    04,    00.3254,    00.2971,    43.0600},
> {075.0,    07,    04,    00.3332,    00.3032,    43.0600},
> {077.5,    07,    04,    00.3389,    00.3079,    43.0600},
> {080.0,    07,    04,    00.3446,    00.3125,    43.0600},
> {082.5,    07,    04,    00.3499,    00.3171,    43.0600},
> {085.0,    07,    04,    00.3552,    00.3222,    43.0600},
> {087.5,    07,    04,    00.3611,    00.3282,    43.0600},
> {090.0,    07,    04,    00.3671,    00.3360,    43.0600},
> {092.5,    07,    04,    00.3715,    00.3439,    43.0600},
> {095.0,    07,    04,    00.3750,    00.3530,    43.0600},
> {097.5,    07,    04,    00.3772,    00.3613,    43.0600},
> {100.0,    07,    04,    00.3778,    00.3719,    43.0600},
> {002.5,    07,    06,    00.4073,    00.4073,    43.0600},
> {005.0,    07,    06,    00.4009,    00.4198,    43.0600},
> {007.5,    07,    06,    00.3943,    00.4264,    43.0600},
> {010.0,    07,    06,    00.3864,    00.4305,    43.0600},
> {012.5,    07,    06,    00.3728,    00.4316,    43.0600},
> {015.0,    07,    06,    00.3581,    00.4291,    43.0600},
> {017.5,    07,    06,    00.3341,    00.4191,    43.0600},
> {020.0,    07,    06,    00.3142,    00.4058,    43.0600},
> {022.5,    07,    06,    00.2933,    00.3873,    43.0600},
> {025.0,    07,    06,    00.2801,    00.3721,    43.0600},
> {027.5,    07,    06,    00.2728,    00.3622,    43.0600},
> {042.5,    07,    06,    00.2418,    00.2960,    43.0600},
> {045.0,    07,    06,    00.2410,    00.2854,    43.0600},
> {047.5,    07,    06,    00.2436,    00.2787,    43.0600},
> {050.0,    07,    06,    00.2478,    00.2728,    43.0600},
> {052.5,    07,    06,    00.2538,    00.2677,    43.0600},
> {055.0,    07,    06,    00.2596,    00.2643,    43.0600},
> {057.5,    07,    06,    00.2687,    00.2612,    43.0600},
> {060.0,    07,    06,    00.2776,    00.2612,    43.0600},
> {062.5,    07,    06,    00.2873,    00.2633,    43.0600},
> {065.0,    07,    06,    00.2961,    00.2663,    43.0600},
> {067.5,    07,    06,    00.3111,    00.2730,    43.0600},
> {070.0,    07,    06,    00.3221,    00.2786,    43.0600},
> {072.5,    07,    06,    00.3338,    00.2854,    43.0600},
> {075.0,    07,    06,    00.3470,    00.2949,    43.0600},
> {077.5,    07,    06,    00.3562,    00.3022,    43.0600},
> {080.0,    07,    06,    00.3648,    00.3098,    43.0600},
> {082.5,    07,    06,    00.3728,    00.3170,    43.0600},
> {085.0,    07,    06,    00.3805,    00.3244,    43.0600},
> {087.5,    07,    06,    00.3888,    00.3336,    43.0600},
> {090.0,    07,    06,    00.3984,    00.3452,    43.0600},
> {092.5,    07,    06,    00.4053,    00.3570,    43.0600},
> {095.0,    07,    06,    00.4091,    00.3701,    43.0600},
> {097.5,    07,    06,    00.4107,    00.3820,    43.0600},
> {100.0,    07,    06,    00.4102,    00.3960,    43.0600},
> {002.5,    07,    08,    00.4353,    00.4312,    43.0600},
> {005.0,    07,    08,    00.4271,    00.4462,    43.0600},
> {007.5,    07,    08,    00.4184,    00.4568,    43.0600},
> {010.0,    07,    08,    00.4090,    00.4641,    43.0600},
> {012.5,    07,    08,    00.3919,    00.4684,    43.0600},
> {015.0,    07,    08,    00.3722,    00.4669,    43.0600},
> {017.5,    07,    08,    00.3406,    00.4558,    43.0600},
> {020.0,    07,    08,    00.3140,    00.4387,    43.0600},
> {022.5,    07,    08,    00.2861,    00.4129,    43.0600},
> {067.5,    07,    08,    00.3109,    00.2584,    43.0600},
> {070.0,    07,    08,    00.3256,    00.2654,    43.0600},
> {072.5,    07,    08,    00.3417,    00.2745,    43.0600},
> {075.0,    07,    08,    00.3603,    00.2869,    43.0600},
> {077.5,    07,    08,    00.3722,    00.2963,    43.0600},
> {080.0,    07,    08,    00.3851,    00.3067,    43.0600},
> {082.5,    07,    08,    00.3961,    00.3160,    43.0600},
> {085.0,    07,    08,    00.4067,    00.3256,    43.0600},
> {087.5,    07,    08,    00.4196,    00.3382,    43.0600},
> {090.0,    07,    08,    00.4308,    00.3533,    43.0600},
> {092.5,    07,    08,    00.4371,    00.3679,    43.0600},
> {095.0,    07,    08,    00.4402,    00.3842,    43.0600},
> {097.5,    07,    08,    00.4415,    00.3996,    43.0600},
> {100.0,    07,    08,    00.4399,    00.4164,    43.0600},
> {002.5,    07,    10,    00.4606,    00.4516,    43.0600},
> {005.0,    07,    10,    00.4509,    00.4696,    43.0600},
> {007.5,    07,    10,    00.4400,    00.4830,    43.0600},
> {012.5,    07,    10,    00.4091,    00.5030,    43.0600},
> {015.0,    07,    10,    00.3852,    00.5051,    43.0600},
> {017.5,    07,    10,    00.3461,    00.4950,    43.0600},
> {090.0,    07,    10,    00.4600,    00.3596,    43.0600},
> {092.5,    07,    10,    00.4671,    00.3768,    43.0600},
> {095.0,    07,    10,    00.4711,    00.3972,    43.0600},
> {097.5,    07,    10,    00.4704,    00.4151,    43.0600},
> {100.0,    07,    10,    00.4667,    00.4335,    43.0600},
> {002.5,    08,    02,    00.3406,    00.3484,    59.1000},
> {005.0,    08,    02,    00.3394,    00.3518,    59.1000},
> {007.5,    08,    02,    00.3379,    00.3540,    59.1000},
> {010.0,    08,    02,    00.3359,    00.3552,    59.1000},
> {012.5,    08,    02,    00.3327,    00.3555,    59.1000},
> {015.0,    08,    02,    00.3284,    00.3542,    59.1000},
> {017.5,    08,    02,    00.3194,    00.3502,    59.1000},
> {020.0,    08,    02,    00.3121,    00.3459,    59.1000},
> {022.5,    08,    02,    00.3053,    00.3404,    59.1000},
> {025.0,    08,    02,    00.3009,    00.3359,    59.1000},
> {027.5,    08,    02,    00.2981,    00.3326,    59.1000},
> {030.0,    08,    02,    00.2957,    00.3293,    59.1000},
> {032.5,    08,    02,    00.2940,    00.3268,    59.1000},
> {035.0,    08,    02,    00.2919,    00.3228,    59.1000},
> {037.5,    08,    02,    00.2900,    00.3183,    59.1000},
> {040.0,    08,    02,    00.2894,    00.3152,    59.1000},
> {042.5,    08,    02,    00.2897,    00.3124,    59.1000},
> {045.0,    08,    02,    00.2908,    00.3096,    59.1000},
> {047.5,    08,    02,    00.2922,    00.3077,    59.1000},
> {050.0,    08,    02,    00.2935,    00.3062,    59.1000},
> {052.5,    08,    02,    00.2957,    00.3047,    59.1000},
> {055.0,    08,    02,    00.2974,    00.3039,    59.1000},
> {057.5,    08,    02,    00.3003,    00.3034,    59.1000},
> {060.0,    08,    02,    00.3027,    00.3035,    59.1000},
> {062.5,    08,    02,    00.3048,    00.3040,    59.1000},
> {065.0,    08,    02,    00.3065,    00.3047,    59.1000},
> {067.5,    08,    02,    00.3107,    00.3070,    59.1000},
> {070.0,    08,    02,    00.3131,    00.3084,    59.1000},
> {072.5,    08,    02,    00.3154,    00.3100,    59.1000},
> {075.0,    08,    02,    00.3180,    00.3120,    59.1000},
> {077.5,    08,    02,    00.3200,    00.3136,    59.1000},
> {080.0,    08,    02,    00.3218,    00.3152,    59.1000},
> {082.5,    08,    02,    00.3236,    00.3169,    59.1000},
> {085.0,    08,    02,    00.3254,    00.3186,    59.1000},
> {087.5,    08,    02,    00.3277,    00.3211,    59.1000},
> {090.0,    08,    02,    00.3301,    00.3237,    59.1000},
> {092.5,    08,    02,    00.3334,    00.3276,    59.1000},
> {095.0,    08,    02,    00.3373,    00.3330,    59.1000},
> {097.5,    08,    02,    00.3395,    00.3379,    59.1000},
> {100.0,    08,    02,    00.3407,    00.3434,    59.1000},
> {002.5,    08,    04,    00.3684,    00.3751,    59.1000},
> {005.0,    08,    04,    00.3650,    00.3826,    59.1000},
> {007.5,    08,    04,    00.3622,    00.3861,    59.1000},
> {010.0,    08,    04,    00.3581,    00.3883,    59.1000},
> {012.5,    08,    04,    00.3504,    00.3887,    59.1000},
> {015.0,    08,    04,    00.3433,    00.3872,    59.1000},
> {017.5,    08,    04,    00.3266,    00.3809,    59.1000},
> {020.0,    08,    04,    00.3140,    00.3727,    59.1000},
> {022.5,    08,    04,    00.3009,    00.3614,    59.1000},
> {025.0,    08,    04,    00.2924,    00.3523,    59.1000},
> {027.5,    08,    04,    00.2874,    00.3464,    59.1000},
> {042.5,    08,    04,    00.2668,    00.3067,    59.1000},
> {045.0,    08,    04,    00.2671,    00.2998,    59.1000},
> {047.5,    08,    04,    00.2688,    00.2956,    59.1000},
> {050.0,    08,    04,    00.2718,    00.2911,    59.1000},
> {052.5,    08,    04,    00.2758,    00.2879,    59.1000},
> {062.5,    08,    04,    00.2962,    00.2850,    59.1000},
> {065.0,    08,    04,    00.3012,    00.2868,    59.1000},
> {067.5,    08,    04,    00.3114,    00.2915,    59.1000},
> {070.0,    08,    04,    00.3175,    00.2955,    59.1000},
> {072.5,    08,    04,    00.3239,    00.3000,    59.1000},
> {075.0,    08,    04,    00.3308,    00.3052,    59.1000},
> {077.5,    08,    04,    00.3360,    00.3092,    59.1000},
> {080.0,    08,    04,    00.3412,    00.3135,    59.1000},
> {082.5,    08,    04,    00.3460,    00.3177,    59.1000},
> {085.0,    08,    04,    00.3510,    00.3224,    59.1000},
> {087.5,    08,    04,    00.3564,    00.3279,    59.1000},
> {090.0,    08,    04,    00.3621,    00.3349,    59.1000},
> {092.5,    08,    04,    00.3667,    00.3429,    59.1000},
> {095.0,    08,    04,    00.3690,    00.3510,    59.1000},
> {097.5,    08,    04,    00.3699,    00.3586,    59.1000},
> {100.0,    08,    04,    00.3701,    00.3674,    59.1000},
> {002.5,    08,    06,    00.3969,    00.4009,    59.1000},
> {005.0,    08,    06,    00.3913,    00.4117,    59.1000},
> {007.5,    08,    06,    00.3862,    00.4175,    59.1000},
> {010.0,    08,    06,    00.3803,    00.4216,    59.1000},
> {012.5,    08,    06,    00.3690,    00.4230,    59.1000},
> {015.0,    08,    06,    00.3573,    00.4214,    59.1000},
> {017.5,    08,    06,    00.3339,    00.4129,    59.1000},
> {020.0,    08,    06,    00.3150,    00.4014,    59.1000},
> {022.5,    08,    06,    00.2952,    00.3851,    59.1000},
> {025.0,    08,    06,    00.2822,    00.3702,    59.1000},
> {072.5,    08,    06,    00.3327,    00.2898,    59.1000},
> {075.0,    08,    06,    00.3440,    00.2978,    59.1000},
> {077.5,    08,    06,    00.3521,    00.3042,    59.1000},
> {080.0,    08,    06,    00.3600,    00.3112,    59.1000},
> {082.5,    08,    06,    00.3671,    00.3175,    59.1000},
> {097.5,    08,    06,    00.4000,    00.3770,    59.1000},
> {100.0,    08,    06,    00.3994,    00.3896,    59.1000},
> {002.5,    08,    08,    00.4231,    00.4231,    59.1000},
> {005.0,    08,    08,    00.4158,    00.4378,    59.1000},
> {007.5,    08,    08,    00.4088,    00.4466,    59.1000},
> {010.0,    08,    08,    00.4008,    00.4520,    59.1000},
> {012.5,    08,    08,    00.3858,    00.4550,    59.1000},
> {015.0,    08,    08,    00.3696,    00.4542,    59.1000},
> {017.5,    08,    08,    00.3408,    00.4452,    59.1000},
> {005.0,    08,    10,    00.4376,    00.4601,    59.1000},
> {007.5,    08,    10,    00.4283,    00.4712,    59.1000},
> {005.0,    08,    12,    00.4562,    00.4788,    59.1000}
> #local Muns_gap_width = 1/16;
> #local Muns_gap_vector = y * Muns_gap_width;
> #local Muns_coo_count = 0;
> #while (Muns_coo_count < 956)
>      #local Muns_param_h = Muns_coo_table[Muns_coo_count][0];
>      #local Muns_param_V = Muns_coo_table[Muns_coo_count][1];
>      #local Muns_param_C = Muns_coo_table[Muns_coo_count][2];
>      #local Muns_param_x = Muns_coo_table[Muns_coo_count][3];
>      #local Muns_param_y = Muns_coo_table[Muns_coo_count][4];
>      #local Muns_param_Y = Muns_coo_table[Muns_coo_count][5]/100;
>      #local Muns_coo_xyY = <Muns_param_x,Muns_param_y,Muns_param_Y,>;
>      #local Muns_coo_RGB =
> MapGamut(xyz2RGB(ChromaMatchSource(xyY2xyz(Muns_coo_xyY))));
>      #local Muns_bound_object = cylinder {0,+y,Muns_param_C + 1};
>      intersection
>          plane {+x,-Muns_gap_width}
>          plane {-x,-Muns_gap_width rotate -y * 9}
>          difference
>              cylinder {Muns_gap_vector,+y - Muns_gap_vector,Muns_param_C
> - Muns_gap_width + 1}
>              cylinder {0,+y,Muns_param_C + Muns_gap_width}
>              bounded_by {Muns_bound_object}
>          pigment {color srgb Muns_coo_RGB}
>          finish {ambient 1}
>          translate    +y * (Muns_param_V - 5)
>          rotate        +y * Muns_param_h/100 * 360
>          scale        1/10
> //    #debug concat("#",str(Muns_coo_count,3,0)," =
> <",vstr(3,Muns_coo_RGB,",",0,-1),">\n");
>      #local Muns_coo_count = Muns_coo_count + 1;
> #end
Date: 23 Nov 2015 20:30:39
Message: <5653bdbf@news.povray.org>
I just noticed that there are sRGB values in a spreadsheet here:
http://www.rit.edu/cos/colorscience/rc_munsell_renotation.php
I may just use those instead. But are they copyrighted?
Mike
> shape?
> Mike
>> this:
>> #version 3.7
>> #include "math.inc"
>> global_settings
>>      assumed_gamma    1.0
>>      adc_bailout        0.005
>>      max_trace_level    50
>>      ambient_light    1
>>      radiosity
>>          pretrace_start    0.08
>>          pretrace_end    0.01
>>          count        50
>>          error_bound    0.1
>>          recursion_limit    1
>>          normal        on
>>          brightness    0.8
>>          always_sample    yes
>>          gray_threshold    0.8
>>          media        on
>> light_source
>>      <-1,+1,-1,> * 300
>>      color srgb    1
>>      parallel
>> camera
>>      orthographic
>>          #case (0)
>>              rotate        +y * 045
>> //            rotate        +y * 180
>>          #break
>>          #case (1)
>>              rotate        +x * 090
>>              rotate        +y * 045
>>              rotate        +y * 180
>>          #case (2)
>>              rotate        +y * 045
>>              rotate        +y * 180
>>          #break
>>      #end
>> objects
>> // h,    V,    C,    x,        y,        Y
>>      intersection
>>          difference
>>          finish {ambient 1}
>>          scale        1/10
>> #end
Date: 23 Nov 2015 21:50:11
Message: <5653d063$1@news.povray.org>
> shape?
That would help, wouldn't it?  But I haven't seen any Munsell data set
with any gray values.
Date: 23 Nov 2015 22:23:08
Message: <5653d81c$1@news.povray.org>
The 1943 renotation is an extrapolation of the 1929 data set, and is
thus far more comprehensive.  It would certainly be more useful than
what you have now.  However...
With a vengeance:  http://www.rit.edu/terms_of_use.html
Note "derivative works" in their language.  Also note the Copyright
Infringement link, which wields the DMCA.  These people sound serious.
I have rendered the 1943 data myself, but I dare not publish it. At
least the copyright on the 1929 data has expired.  If it makes you feel
better, most of the extra 1943 points are outside the sRGB gamut anyway.
(One copy on one computer?  Screw that!  I'm not screening these files
out from my regular backups.)
You can always contact RIT for permission to use their data in a
GNU-LGPL 2.1 project.  The worse they can do is say no.  Alternatively,
you can go straight to the source at:
   https://www.osapublishing.org/josa/abstract.cfm?uri=josa-33-7-385
but you will have to pay for it.  The OSA Web site is also copyrighted
(as are nearly all Web sites), but I don't know what rights are reserved
for the papers in their library.
