Mike Horvath <mik### [at] gmailcom> wrote:
> Also, does this mean that Lightsys is out of date?
No, Lightsys is fine, except for one place in CIE_Skylight.inc that uses ambient
where emission would be appropriate in POV-Ray 3.7. The srgb keyword is
orthogonal to Lightsys.
On 11/23/2015 5:12 PM, Cousin Ricky wrote:
> To Mike: If you wish to keep the module compatible to 3.6, you obviously cannot
> use emission. If you want the objects to glow and be compatible with both 3.6
> and 3.7, while keeping radiosity, you must put #version 3.6; at the head of the
> file, and stick with the high ambient. If you don't care about 3.6
> compatibility, then use emission instead of ambient, and definitely put #version
> 3.7 at the head of the file. However, with a higher diffuse value (which I
> recommend), you will have less need for emission.
That helps, thanks!
Mike
Am 23.11.2015 um 23:12 schrieb Cousin Ricky:
> When I try to render the data directly, the greens from G5 up look very cyan to
> me. Munsell is supposed to visually space out the hues evenly, but the swath
> from G5 to BP5 transitions very slowly to my eyes.
> What weirds me out is that Munsell uses the very purplish illuminant C instead
> of the normal D65 or D50. Whether it is used as the color system white point or
> the reference white point I have been unable to find out. (That information is
> probably available for purchase.) Worse, I have been unable to understand what
> "reference white point" even means, which certainly hampers my understanding of
> color.
In contrast to colour systems typically used in computer graphics (like
sRGB, CIE RGB, CIE XY etc.), which reference light colours, Munsell is a
system to reference pigment colours. Within the boundaries of such a
system, referencing an illuminant /per se/ doesn't make any sense.
Likewise, giving xyY coordinates for such a system doesn't make sense
either -- unless you also mention the lighting conditions under which
the pigments are viewed, i.e. the illuminant.
I would therefore conclude that the Munsell white point you dug up
refers to the illuminant that was used to measure the pigments' xyY
coordinates.
Thus -- assuming I got the colour physics right on this one -- for
proper representation of the actual Munsell pigments you'd need to
divide the pigment colours by the colour of illuminant C, in order to
undo the presumed white point bias. (Theoretically you'd need to to this
in continuous spectrum space; in practice, you should do this in either
XYZ or sRGB space, but whatever you choose it will be imprecise.)
You also need to make sure that the colour of all light emitters
(light_source, background, ambient_light and emission parameter) is
uniform, but as Munsell at its core only describes pigments, you can
choose any illuminant you like -- I'd recommend D65, i.e. <1,1,1>, to
make the image's overall hue harmonize with the surroundings the image
may be presented in, which will typically be web pages. (The W3C has
standardized sRGB as the colour space for the web, so any "pure" white
or grey on the web corresponds to D65).
As for the term "reference white point", this is the light colour that,
in any given context, corresponds to some "official" white. When talking
about colour systems, the term is synonymous to "system white point"
from all I know.
Am 23.11.2015 um 22:37 schrieb Mike Horvath:
> On 11/23/2015 4:10 PM, clipka wrote:
>> Am 23.11.2015 um 21:08 schrieb Mike Horvath:
>>> Okay, I just re-rendered the scene specifying #version 3.6 instead of
>>> #version 3.7. There is a huge difference! I cannot explain it however. I
>>> don't know why there is such a big difference.
>> Specifying "#version 3.6" will put POV-Ray in backward compatibility
>> mode; among other thins, this will re-activating the "ambient" mechanism
>> even when radiosity is used, which might explain the difference.
> So, radiosity automatically turns ambient off in 3.7?
Exactly.
Am 23.11.2015 um 22:10 schrieb clipka:
(Darn, I've written better English before...)
On 11/23/2015 6:08 PM, Mike Horvath wrote:
> That helps, thanks!
> Mike
I should clarify, the colors are now lighter, but they are still washed out.
Mike
I just noticed that the data I am using has no values where C (chroma)
is zero. Shouldn't there be a column of gray values up the middle of the
shape?
Mike
On 11/22/2015 2:55 PM, Mike Horvath wrote:
> I am trying to re-render the Munsell color cylinder scene from the
> object collection. However, the results look too drab. Compare it to this:
> https://commons.wikimedia.org/wiki/File:Munsell_1929_color_solid.png
> Does anyone have any tips to improve the render?
> // Title: Munsell 1929 color solid v1.1
> // Author: Michael Horvath, http://isometricland.net
> // Created: 2009-11-10
> // Updated: 2015-11-22
> // This file is licensed under the terms of the CC-LGPL.
//------------------------------------------------------------------------------Includes
> #version 3.7
> #include "functions.inc"
> #include "math.inc"
> #include "CIE.inc" //
> http://www.ignorancia.org/en/index.php?page=Lightsys
//------------------------------------------------------------------------------Scenery
> global_settings
> assumed_gamma 1.0
> adc_bailout 0.005
> max_trace_level 50
> ambient_light 1
> radiosity
> pretrace_start 0.08
> pretrace_end 0.01
> count 50
> error_bound 0.1
> recursion_limit 1
> normal on
> brightness 0.8
> always_sample yes
> gray_threshold 0.8
> media on
> background {color srgb 1}
> light_source
> <-1,+1,-1,> * 300
> color srgb 1
> parallel
> #local Muns_cam_view = 0;
> camera
> #local Muns_cam_distance = 20;
> #local Muns_cam_planesize = 3;
> #local Muns_cam_aspectratio = image_width/image_height;
> orthographic
> location -z * Muns_cam_distance
> direction +z// * Muns_cam_distance
> right +x * Muns_cam_planesize
> up +y * Muns_cam_planesize/Muns_cam_aspectratio
> #switch (Muns_cam_view)
> #case (0)
> rotate +x * asind(tand(30))
> rotate +y * 045
> // rotate +y * 180
> #break
> #case (1)
> rotate +x * 090
> rotate +y * 045
> rotate +y * 180
> #case (2)
> rotate +y * 045
> rotate +y * 180
> #break
> #end
> //------------------------------------------------------------------------------CSG
> objects
> // Munsell Renotation Data, http://www.cis.rit.edu/mcsl/online/munsell.php
> // h, V, C, x, y, Y
> #declare Muns_coo_table = array[956][6]
> {002.5, 02, 02, 00.3825, 00.3785, 03.1260},
> {005.0, 02, 02, 00.3757, 00.3839, 03.1260},
> {007.5, 02, 02, 00.3660, 00.3858, 03.1260},
> {010.0, 02, 02, 00.3556, 00.3848, 03.1260},
> {012.5, 02, 02, 00.3421, 00.3803, 03.1260},
> {015.0, 02, 02, 00.3309, 00.3743, 03.1260},
> {017.5, 02, 02, 00.3165, 00.3650, 03.1260},
> {020.0, 02, 02, 00.3069, 00.3580, 03.1260},
> {022.5, 02, 02, 00.2978, 00.3507, 03.1260},
> {025.0, 02, 02, 00.2918, 00.3450, 03.1260},
> {027.5, 02, 02, 00.2869, 00.3400, 03.1260},
> {030.0, 02, 02, 00.2820, 00.3341, 03.1260},
> {032.5, 02, 02, 00.2765, 00.3271, 03.1260},
> {035.0, 02, 02, 00.2697, 00.3175, 03.1260},
> {037.5, 02, 02, 00.2651, 00.3098, 03.1260},
> {040.0, 02, 02, 00.2606, 00.3010, 03.1260},
> {042.5, 02, 02, 00.2578, 00.2940, 03.1260},
> {045.0, 02, 02, 00.2559, 00.2874, 03.1260},
> {047.5, 02, 02, 00.2545, 00.2799, 03.1260},
> {050.0, 02, 02, 00.2558, 00.2725, 03.1260},
> {052.5, 02, 02, 00.2592, 00.2675, 03.1260},
> {055.0, 02, 02, 00.2638, 00.2624, 03.1260},
> {057.5, 02, 02, 00.2712, 00.2582, 03.1260},
> {060.0, 02, 02, 00.2803, 00.2567, 03.1260},
> {062.5, 02, 02, 00.2892, 00.2583, 03.1260},
> {065.0, 02, 02, 00.2984, 00.2612, 03.1260},
> {067.5, 02, 02, 00.3071, 00.2647, 03.1260},
> {070.0, 02, 02, 00.3161, 00.2691, 03.1260},
> {072.5, 02, 02, 00.3279, 00.2754, 03.1260},
> {075.0, 02, 02, 00.3383, 00.2829, 03.1260},
> {077.5, 02, 02, 00.3459, 00.2892, 03.1260},
> {080.0, 02, 02, 00.3532, 00.2957, 03.1260},
> {082.5, 02, 02, 00.3614, 00.3033, 03.1260},
> {085.0, 02, 02, 00.3692, 00.3111, 03.1260},
> {087.5, 02, 02, 00.3751, 00.3181, 03.1260},
> {090.0, 02, 02, 00.3811, 00.3274, 03.1260},
> {092.5, 02, 02, 00.3852, 00.3365, 03.1260},
> {095.0, 02, 02, 00.3880, 00.3476, 03.1260},
> {097.5, 02, 02, 00.3889, 00.3590, 03.1260},
> {100.0, 02, 02, 00.3872, 00.3688, 03.1260},
> {032.5, 02, 04, 00.2343, 00.3378, 03.1260},
> {035.0, 02, 04, 00.2234, 00.3150, 03.1260},
> {037.5, 02, 04, 00.2162, 00.2981, 03.1260},
> {047.5, 02, 04, 00.2063, 00.2400, 03.1260},
> {050.0, 02, 04, 00.2102, 00.2313, 03.1260},
> {052.5, 02, 04, 00.2175, 00.2245, 03.1260},
> {055.0, 02, 04, 00.2263, 00.2192, 03.1260},
> {057.5, 02, 04, 00.2420, 00.2148, 03.1260},
> {060.0, 02, 04, 00.2600, 00.2162, 03.1260},
> {062.5, 02, 04, 00.2758, 00.2208, 03.1260},
> {065.0, 02, 04, 00.2908, 00.2261, 03.1260},
> {067.5, 02, 04, 00.3048, 00.2321, 03.1260},
> {070.0, 02, 04, 00.3189, 00.2390, 03.1260},
> {072.5, 02, 04, 00.3382, 00.2496, 03.1260},
> {075.0, 02, 04, 00.3558, 00.2597, 03.1260},
> {077.5, 02, 04, 00.3702, 00.2683, 03.1260},
> {080.0, 02, 04, 00.3850, 00.2778, 03.1260},
> {082.5, 02, 04, 00.4021, 00.2900, 03.1260},
> {085.0, 02, 04, 00.4184, 00.3032, 03.1260},
> {087.5, 02, 04, 00.4335, 00.3169, 03.1260},
> {052.5, 02, 06, 00.1825, 00.1857, 03.1260},
> {055.0, 02, 06, 00.1942, 00.1811, 03.1260},
> {057.5, 02, 06, 00.2189, 00.1790, 03.1260},
> {060.0, 02, 06, 00.2440, 00.1840, 03.1260},
> {062.5, 02, 06, 00.2661, 00.1921, 03.1260},
> {065.0, 02, 06, 00.2850, 00.1992, 03.1260},
> {067.5, 02, 06, 00.3025, 00.2058, 03.1260},
> {070.0, 02, 06, 00.3207, 00.2132, 03.1260},
> {072.5, 02, 06, 00.3470, 00.2259, 03.1260},
> {075.0, 02, 06, 00.3708, 00.2380, 03.1260},
> {077.5, 02, 06, 00.3918, 00.2490, 03.1260},
> {080.0, 02, 06, 00.4139, 00.2608, 03.1260},
> {082.5, 02, 06, 00.4390, 00.2760, 03.1260},
> {085.0, 02, 06, 00.4642, 00.2934, 03.1260},
> {080.0, 02, 08, 00.4428, 00.2419, 03.1260},
> {002.5, 03, 02, 00.3703, 00.3700, 06.5550},
> {005.0, 03, 02, 00.3646, 00.3748, 06.5550},
> {007.5, 03, 02, 00.3589, 00.3778, 06.5550},
> {010.0, 03, 02, 00.3513, 00.3789, 06.5550},
> {012.5, 03, 02, 00.3412, 00.3768, 06.5550},
> {015.0, 03, 02, 00.3319, 00.3729, 06.5550},
> {017.5, 03, 02, 00.3180, 00.3644, 06.5550},
> {020.0, 03, 02, 00.3088, 00.3578, 06.5550},
> {022.5, 03, 02, 00.2999, 00.3500, 06.5550},
> {025.0, 03, 02, 00.2935, 00.3439, 06.5550},
> {027.5, 03, 02, 00.2890, 00.3391, 06.5550},
> {030.0, 03, 02, 00.2844, 00.3337, 06.5550},
> {032.5, 03, 02, 00.2799, 00.3271, 06.5550},
> {035.0, 03, 02, 00.2742, 00.3192, 06.5550},
> {037.5, 03, 02, 00.2699, 00.3120, 06.5550},
> {040.0, 03, 02, 00.2660, 00.3050, 06.5550},
> {042.5, 03, 02, 00.2636, 00.2983, 06.5550},
> {045.0, 03, 02, 00.2617, 00.2921, 06.5550},
> {047.5, 03, 02, 00.2616, 00.2857, 06.5550},
> {050.0, 03, 02, 00.2631, 00.2801, 06.5550},
> {052.5, 03, 02, 00.2663, 00.2756, 06.5550},
> {055.0, 03, 02, 00.2708, 00.2719, 06.5550},
> {057.5, 03, 02, 00.2777, 00.2687, 06.5550},
> {060.0, 03, 02, 00.2847, 00.2670, 06.5550},
> {062.5, 03, 02, 00.2922, 00.2680, 06.5550},
> {065.0, 03, 02, 00.2997, 00.2700, 06.5550},
> {067.5, 03, 02, 00.3088, 00.2740, 06.5550},
> {070.0, 03, 02, 00.3170, 00.2790, 06.5550},
> {072.5, 03, 02, 00.3272, 00.2861, 06.5550},
> {075.0, 03, 02, 00.3370, 00.2940, 06.5550},
> {077.5, 03, 02, 00.3450, 00.3001, 06.5550},
> {080.0, 03, 02, 00.3526, 00.3068, 06.5550},
> {082.5, 03, 02, 00.3591, 00.3130, 06.5550},
> {085.0, 03, 02, 00.3645, 00.3190, 06.5550},
> {087.5, 03, 02, 00.3690, 00.3248, 06.5550},
> {090.0, 03, 02, 00.3728, 00.3314, 06.5550},
> {092.5, 03, 02, 00.3757, 00.3391, 06.5550},
> {095.0, 03, 02, 00.3771, 00.3476, 06.5550},
> {097.5, 03, 02, 00.3771, 00.3549, 06.5550},
> {100.0, 03, 02, 00.3747, 00.3630, 06.5550},
> {002.5, 03, 04, 00.4277, 00.4166, 06.5550},
> {012.5, 03, 04, 00.3772, 00.4484, 06.5550},
> {015.0, 03, 04, 00.3554, 00.4429, 06.5550},
> {017.5, 03, 04, 00.3270, 00.4288, 06.5550},
> {020.0, 03, 04, 00.3053, 00.4123, 06.5550},
> {022.5, 03, 04, 00.2836, 00.3915, 06.5550},
> {025.0, 03, 04, 00.2711, 00.3780, 06.5550},
> {027.5, 03, 04, 00.2618, 00.3667, 06.5550},
> {030.0, 03, 04, 00.2525, 00.3537, 06.5550},
> {032.5, 03, 04, 00.2437, 00.3386, 06.5550},
> {035.0, 03, 04, 00.2343, 00.3200, 06.5550},
> {037.5, 03, 04, 00.2272, 00.3041, 06.5550},
> {040.0, 03, 04, 00.2221, 00.2886, 06.5550},
> {042.5, 03, 04, 00.2183, 00.2748, 06.5550},
> {045.0, 03, 04, 00.2176, 00.2632, 06.5550},
> {047.5, 03, 04, 00.2200, 00.2536, 06.5550},
> {050.0, 03, 04, 00.2246, 00.2467, 06.5550},
> {052.5, 03, 04, 00.2312, 00.2405, 06.5550},
> {055.0, 03, 04, 00.2393, 00.2361, 06.5550},
> {057.5, 03, 04, 00.2520, 00.2319, 06.5550},
> {060.0, 03, 04, 00.2660, 00.2319, 06.5550},
> {062.5, 03, 04, 00.2792, 00.2342, 06.5550},
> {065.0, 03, 04, 00.2928, 00.2386, 06.5550},
> {067.5, 03, 04, 00.3072, 00.2448, 06.5550},
> {070.0, 03, 04, 00.3214, 00.2517, 06.5550},
> {072.5, 03, 04, 00.3400, 00.2624, 06.5550},
> {075.0, 03, 04, 00.3586, 00.2742, 06.5550},
> {077.5, 03, 04, 00.3739, 00.2851, 06.5550},
> {080.0, 03, 04, 00.3889, 00.2969, 06.5550},
> {082.5, 03, 04, 00.4021, 00.3076, 06.5550},
> {085.0, 03, 04, 00.4148, 00.3190, 06.5550},
> {087.5, 03, 04, 00.4240, 00.3302, 06.5550},
> {090.0, 03, 04, 00.4308, 00.3412, 06.5550},
> {092.5, 03, 04, 00.4360, 00.3563, 06.5550},
> {095.0, 03, 04, 00.4376, 00.3715, 06.5550},
> {097.5, 03, 04, 00.4378, 00.3865, 06.5550},
> {100.0, 03, 04, 00.4341, 00.4018, 06.5550},
> {032.5, 03, 06, 00.2132, 00.3468, 06.5550},
> {035.0, 03, 06, 00.2020, 00.3188, 06.5550},
> {037.5, 03, 06, 00.1928, 00.2958, 06.5550},
> {040.0, 03, 06, 00.1861, 00.2722, 06.5550},
> {042.5, 03, 06, 00.1826, 00.2536, 06.5550},
> {045.0, 03, 06, 00.1835, 00.2375, 06.5550},
> {047.5, 03, 06, 00.1875, 00.2258, 06.5550},
> {050.0, 03, 06, 00.1933, 00.2173, 06.5550},
> {052.5, 03, 06, 00.2022, 00.2101, 06.5550},
> {055.0, 03, 06, 00.2122, 00.2052, 06.5550},
> {057.5, 03, 06, 00.2311, 00.2010, 06.5550},
> {060.0, 03, 06, 00.2511, 00.2031, 06.5550},
> {062.5, 03, 06, 00.2691, 00.2072, 06.5550},
> {065.0, 03, 06, 00.2870, 00.2135, 06.5550},
> {067.5, 03, 06, 00.3057, 00.2208, 06.5550},
> {070.0, 03, 06, 00.3243, 00.2293, 06.5550},
> {072.5, 03, 06, 00.3501, 00.2425, 06.5550},
> {075.0, 03, 06, 00.3765, 00.2569, 06.5550},
> {077.5, 03, 06, 00.3990, 00.2708, 06.5550},
> {080.0, 03, 06, 00.4218, 00.2864, 06.5550},
> {082.5, 03, 06, 00.4409, 00.3009, 06.5550},
> {085.0, 03, 06, 00.4592, 00.3168, 06.5550},
> {087.5, 03, 06, 00.4738, 00.3316, 06.5550},
> {090.0, 03, 06, 00.4854, 00.3467, 06.5550},
> {092.5, 03, 06, 00.4954, 00.3692, 06.5550},
> {047.5, 03, 08, 00.1583, 00.1987, 06.5550},
> {050.0, 03, 08, 00.1658, 00.1905, 06.5550},
> {052.5, 03, 08, 00.1780, 00.1833, 06.5550},
> {055.0, 03, 08, 00.1908, 00.1799, 06.5550},
> {057.5, 03, 08, 00.2149, 00.1761, 06.5550},
> {060.0, 03, 08, 00.2387, 00.1786, 06.5550},
> {062.5, 03, 08, 00.2615, 00.1845, 06.5550},
> {065.0, 03, 08, 00.2819, 00.1910, 06.5550},
> {067.5, 03, 08, 00.3037, 00.1981, 06.5550},
> {070.0, 03, 08, 00.3269, 00.2075, 06.5550},
> {072.5, 03, 08, 00.3598, 00.2233, 06.5550},
> {075.0, 03, 08, 00.3930, 00.2395, 06.5550},
> {077.5, 03, 08, 00.4234, 00.2556, 06.5550},
> {080.0, 03, 08, 00.4552, 00.2741, 06.5550},
> {082.5, 03, 08, 00.4821, 00.2918, 06.5550},
> {085.0, 03, 08, 00.5064, 00.3114, 06.5550},
> {087.5, 03, 08, 00.5251, 00.3297, 06.5550},
> {052.5, 03, 10, 00.1576, 00.1600, 06.5550},
> {055.0, 03, 10, 00.1718, 00.1562, 06.5550},
> {057.5, 03, 10, 00.2005, 00.1536, 06.5550},
> {060.0, 03, 10, 00.2278, 00.1565, 06.5550},
> {062.5, 03, 10, 00.2548, 00.1638, 06.5550},
> {065.0, 03, 10, 00.2772, 00.1707, 06.5550},
> {067.5, 03, 10, 00.3020, 00.1794, 06.5550},
> {070.0, 03, 10, 00.3286, 00.1889, 06.5550},
> {072.5, 03, 10, 00.3681, 00.2054, 06.5550},
> {075.0, 03, 10, 00.4073, 00.2235, 06.5550},
> {077.5, 03, 10, 00.4445, 00.2419, 06.5550},
> {080.0, 03, 10, 00.4851, 00.2618, 06.5550},
> {082.5, 03, 10, 00.5191, 00.2811, 06.5550},
> {085.0, 03, 10, 00.5500, 00.3024, 06.5550},
> {055.0, 03, 12, 00.1557, 00.1356, 06.5550},
> {002.5, 04, 02, 00.3633, 00.3654, 12.0000},
> {005.0, 04, 02, 00.3590, 00.3701, 12.0000},
> {007.5, 04, 02, 00.3542, 00.3727, 12.0000},
> {010.0, 04, 02, 00.3436, 00.3732, 12.0000},
> {012.5, 04, 02, 00.3382, 00.3706, 12.0000},
> {015.0, 04, 02, 00.3312, 00.3678, 12.0000},
> {017.5, 04, 02, 00.3185, 00.3604, 12.0000},
> {020.0, 04, 02, 00.3109, 00.3550, 12.0000},
> {022.5, 04, 02, 00.3012, 00.3470, 12.0000},
> {025.0, 04, 02, 00.2959, 00.3417, 12.0000},
> {027.5, 04, 02, 00.2919, 00.3371, 12.0000},
> {030.0, 04, 02, 00.2880, 00.3327, 12.0000},
> {032.5, 04, 02, 00.2840, 00.3270, 12.0000},
> {035.0, 04, 02, 00.2799, 00.3208, 12.0000},
> {037.5, 04, 02, 00.2764, 00.3148, 12.0000},
> {040.0, 04, 02, 00.2740, 00.3091, 12.0000},
> {042.5, 04, 02, 00.2727, 00.3038, 12.0000},
> {045.0, 04, 02, 00.2723, 00.2992, 12.0000},
> {047.5, 04, 02, 00.2733, 00.2947, 12.0000},
> {050.0, 04, 02, 00.2753, 00.2910, 12.0000},
> {052.5, 04, 02, 00.2782, 00.2876, 12.0000},
> {055.0, 04, 02, 00.2816, 00.2842, 12.0000},
> {057.5, 04, 02, 00.2861, 00.2819, 12.0000},
> {060.0, 04, 02, 00.2911, 00.2804, 12.0000},
> {062.5, 04, 02, 00.2962, 00.2807, 12.0000},
> {065.0, 04, 02, 00.3022, 00.2825, 12.0000},
> {067.5, 04, 02, 00.3093, 00.2859, 12.0000},
> {070.0, 04, 02, 00.3162, 00.2902, 12.0000},
> {072.5, 04, 02, 00.3231, 00.2951, 12.0000},
> {075.0, 04, 02, 00.3310, 00.3010, 12.0000},
> {077.5, 04, 02, 00.3371, 00.3061, 12.0000},
> {080.0, 04, 02, 00.3417, 00.3106, 12.0000},
> {082.5, 04, 02, 00.3461, 00.3150, 12.0000},
> {085.0, 04, 02, 00.3508, 00.3200, 12.0000},
> {087.5, 04, 02, 00.3538, 00.3236, 12.0000},
> {090.0, 04, 02, 00.3582, 00.3294, 12.0000},
> {092.5, 04, 02, 00.3624, 00.3367, 12.0000},
> {095.0, 04, 02, 00.3651, 00.3442, 12.0000},
> {097.5, 04, 02, 00.3662, 00.3504, 12.0000},
> {100.0, 04, 02, 00.3660, 00.3590, 12.0000},
> {002.5, 04, 04, 00.4138, 00.4076, 12.0000},
> {005.0, 04, 04, 00.4069, 00.4188, 12.0000},
> {007.5, 04, 04, 00.3982, 00.4272, 12.0000},
> {010.0, 04, 04, 00.3871, 00.4321, 12.0000},
> {012.5, 04, 04, 00.3708, 00.4329, 12.0000},
> {015.0, 04, 04, 00.3538, 00.4284, 12.0000},
> {017.5, 04, 04, 00.3281, 00.4157, 12.0000},
> {020.0, 04, 04, 00.3100, 00.4018, 12.0000},
> {022.5, 04, 04, 00.2891, 00.3821, 12.0000},
> {025.0, 04, 04, 00.2781, 00.3704, 12.0000},
> {027.5, 04, 04, 00.2702, 00.3602, 12.0000},
> {030.0, 04, 04, 00.2628, 00.3498, 12.0000},
> {032.5, 04, 04, 00.2552, 00.3375, 12.0000},
> {035.0, 04, 04, 00.2480, 00.3232, 12.0000},
> {037.5, 04, 04, 00.2429, 00.3108, 12.0000},
> {040.0, 04, 04, 00.2384, 00.2984, 12.0000},
> {042.5, 04, 04, 00.2360, 00.2872, 12.0000},
> {045.0, 04, 04, 00.2363, 00.2782, 12.0000},
> {047.5, 04, 04, 00.2388, 00.2704, 12.0000},
> {050.0, 04, 04, 00.2429, 00.2648, 12.0000},
> {052.5, 04, 04, 00.2487, 00.2597, 12.0000},
> {055.0, 04, 04, 00.2562, 00.2560, 12.0000},
> {057.5, 04, 04, 00.2657, 00.2528, 12.0000},
> {060.0, 04, 04, 00.2759, 00.2522, 12.0000},
> {062.5, 04, 04, 00.2855, 00.2531, 12.0000},
> {065.0, 04, 04, 00.2958, 00.2565, 12.0000},
> {067.5, 04, 04, 00.3084, 00.2622, 12.0000},
> {070.0, 04, 04, 00.3210, 00.2686, 12.0000},
> {072.5, 04, 04, 00.3340, 00.2770, 12.0000},
> {075.0, 04, 04, 00.3491, 00.2872, 12.0000},
> {077.5, 04, 04, 00.3612, 00.2963, 12.0000},
> {080.0, 04, 04, 00.3715, 00.3042, 12.0000},
> {082.5, 04, 04, 00.3806, 00.3125, 12.0000},
> {085.0, 04, 04, 00.3916, 00.3223, 12.0000},
> {087.5, 04, 04, 00.3990, 00.3300, 12.0000},
> {090.0, 04, 04, 00.4078, 00.3412, 12.0000},
> {092.5, 04, 04, 00.4141, 00.3539, 12.0000},
> {095.0, 04, 04, 00.4187, 00.3679, 12.0000},
> {097.5, 04, 04, 00.4208, 00.3809, 12.0000},
> {100.0, 04, 04, 00.4189, 00.3948, 12.0000},
> {002.5, 04, 06, 00.4542, 00.4391, 12.0000},
> {012.5, 04, 06, 00.3968, 00.4857, 12.0000},
> {015.0, 04, 06, 00.3718, 00.4852, 12.0000},
> {017.5, 04, 06, 00.3355, 00.4739, 12.0000},
> {020.0, 04, 06, 00.3069, 00.4550, 12.0000},
> {022.5, 04, 06, 00.2735, 00.4215, 12.0000},
> {032.5, 04, 06, 00.2278, 00.3463, 12.0000},
> {035.0, 04, 06, 00.2182, 00.3240, 12.0000},
> {037.5, 04, 06, 00.2113, 00.3052, 12.0000},
> {040.0, 04, 06, 00.2065, 00.2863, 12.0000},
> {042.5, 04, 06, 00.2048, 00.2708, 12.0000},
> {045.0, 04, 06, 00.2060, 00.2572, 12.0000},
> {047.5, 04, 06, 00.2102, 00.2470, 12.0000},
> {050.0, 04, 06, 00.2157, 00.2407, 12.0000},
> {052.5, 04, 06, 00.2235, 00.2343, 12.0000},
> {055.0, 04, 06, 00.2325, 00.2300, 12.0000},
> {057.5, 04, 06, 00.2471, 00.2266, 12.0000},
> {060.0, 04, 06, 00.2618, 00.2263, 12.0000},
> {062.5, 04, 06, 00.2763, 00.2300, 12.0000},
> {065.0, 04, 06, 00.2903, 00.2347, 12.0000},
> {067.5, 04, 06, 00.3076, 00.2416, 12.0000},
> {070.0, 04, 06, 00.3248, 00.2493, 12.0000},
> {072.5, 04, 06, 00.3442, 00.2595, 12.0000},
> {075.0, 04, 06, 00.3671, 00.2733, 12.0000},
> {077.5, 04, 06, 00.3850, 00.2859, 12.0000},
> {080.0, 04, 06, 00.3999, 00.2972, 12.0000},
> {082.5, 04, 06, 00.4141, 00.3085, 12.0000},
> {085.0, 04, 06, 00.4299, 00.3226, 12.0000},
> {087.5, 04, 06, 00.4415, 00.3340, 12.0000},
> {090.0, 04, 06, 00.4535, 00.3500, 12.0000},
> {092.5, 04, 06, 00.4612, 00.3674, 12.0000},
> {095.0, 04, 06, 00.4651, 00.3859, 12.0000},
> {097.5, 04, 06, 00.4655, 00.4029, 12.0000},
> {100.0, 04, 06, 00.4618, 00.4213, 12.0000},
> {042.5, 04, 08, 00.1737, 00.2524, 12.0000},
> {045.0, 04, 08, 00.1759, 00.2345, 12.0000},
> {047.5, 04, 08, 00.1821, 00.2232, 12.0000},
> {050.0, 04, 08, 00.1893, 00.2160, 12.0000},
> {052.5, 04, 08, 00.1995, 00.2094, 12.0000},
> {055.0, 04, 08, 00.2103, 00.2050, 12.0000},
> {057.5, 04, 08, 00.2304, 00.2023, 12.0000},
> {060.0, 04, 08, 00.2497, 00.2038, 12.0000},
> {062.5, 04, 08, 00.2685, 00.2089, 12.0000},
> {065.0, 04, 08, 00.2855, 00.2150, 12.0000},
> {067.5, 04, 08, 00.3066, 00.2228, 12.0000},
> {070.0, 04, 08, 00.3280, 00.2318, 12.0000},
> {072.5, 04, 08, 00.3533, 00.2438, 12.0000},
> {075.0, 04, 08, 00.3833, 00.2600, 12.0000},
> {077.5, 04, 08, 00.4072, 00.2750, 12.0000},
> {080.0, 04, 08, 00.4282, 00.2890, 12.0000},
> {082.5, 04, 08, 00.4472, 00.3031, 12.0000},
> {085.0, 04, 08, 00.4690, 00.3209, 12.0000},
> {087.5, 04, 08, 00.4850, 00.3359, 12.0000},
> {090.0, 04, 08, 00.4995, 00.3557, 12.0000},
> {092.5, 04, 08, 00.5071, 00.3777, 12.0000},
> {095.0, 04, 08, 00.5070, 00.3994, 12.0000},
> {097.5, 04, 08, 00.5038, 00.4204, 12.0000},
> {052.5, 04, 10, 00.1805, 00.1888, 12.0000},
> {055.0, 04, 10, 00.1925, 00.1843, 12.0000},
> {057.5, 04, 10, 00.2158, 00.1811, 12.0000},
> {060.0, 04, 10, 00.2388, 00.1837, 12.0000},
> {062.5, 04, 10, 00.2619, 00.1903, 12.0000},
> {065.0, 04, 10, 00.2814, 00.1967, 12.0000},
> {067.5, 04, 10, 00.3056, 00.2060, 12.0000},
> {070.0, 04, 10, 00.3306, 00.2162, 12.0000},
> {072.5, 04, 10, 00.3608, 00.2301, 12.0000},
> {075.0, 04, 10, 00.3960, 00.2489, 12.0000},
> {077.5, 04, 10, 00.4259, 00.2651, 12.0000},
> {080.0, 04, 10, 00.4528, 00.2811, 12.0000},
> {082.5, 04, 10, 00.4774, 00.2969, 12.0000},
> {085.0, 04, 10, 00.5043, 00.3176, 12.0000},
> {087.5, 04, 10, 00.5235, 00.3351, 12.0000},
> {090.0, 04, 10, 00.5418, 00.3580, 12.0000},
> {092.5, 04, 10, 00.5475, 00.3856, 12.0000},
> {062.5, 04, 12, 00.2559, 00.1730, 12.0000},
> {065.0, 04, 12, 00.2778, 00.1808, 12.0000},
> {067.5, 04, 12, 00.3045, 00.1905, 12.0000},
> {072.5, 04, 12, 00.3683, 00.2162, 12.0000},
> {075.0, 04, 12, 00.4104, 00.2361, 12.0000},
> {077.5, 04, 12, 00.4450, 00.2541, 12.0000},
> {082.5, 04, 12, 00.5072, 00.2897, 12.0000},
> {085.0, 04, 12, 00.5385, 00.3129, 12.0000},
> {087.5, 04, 12, 00.5603, 00.3321, 12.0000},
> {085.0, 04, 14, 00.5734, 00.3057, 12.0000},
> {002.5, 05, 02, 00.3534, 00.3570, 19.7700},
> {005.0, 05, 02, 00.3500, 00.3620, 19.7700},
> {007.5, 05, 02, 00.3470, 00.3640, 19.7700},
> {010.0, 05, 02, 00.3422, 00.3648, 19.7700},
> {012.5, 05, 02, 00.3352, 00.3636, 19.7700},
> {015.0, 05, 02, 00.3289, 00.3612, 19.7700},
> {017.5, 05, 02, 00.3188, 00.3560, 19.7700},
> {020.0, 05, 02, 00.3110, 00.3508, 19.7700},
> {022.5, 05, 02, 00.3030, 00.3445, 19.7700},
> {025.0, 05, 02, 00.2978, 00.3392, 19.7700},
> {027.5, 05, 02, 00.2945, 00.3355, 19.7700},
> {030.0, 05, 02, 00.2910, 00.3310, 19.7700},
> {032.5, 05, 02, 00.2880, 00.3270, 19.7700},
> {035.0, 05, 02, 00.2841, 00.3210, 19.7700},
> {037.5, 05, 02, 00.2812, 00.3161, 19.7700},
> {040.0, 05, 02, 00.2796, 00.3111, 19.7700},
> {042.5, 05, 02, 00.2791, 00.3071, 19.7700},
> {045.0, 05, 02, 00.2794, 00.3032, 19.7700},
> {047.5, 05, 02, 00.2803, 00.3000, 19.7700},
> {050.0, 05, 02, 00.2821, 00.2966, 19.7700},
> {052.5, 05, 02, 00.2847, 00.2942, 19.7700},
> {055.0, 05, 02, 00.2882, 00.2923, 19.7700},
> {057.5, 05, 02, 00.2918, 00.2908, 19.7700},
> {060.0, 05, 02, 00.2959, 00.2905, 19.7700},
> {062.5, 05, 02, 00.3000, 00.2912, 19.7700},
> {065.0, 05, 02, 00.3045, 00.2928, 19.7700},
> {067.5, 05, 02, 00.3103, 00.2959, 19.7700},
> {070.0, 05, 02, 00.3148, 00.2986, 19.7700},
> {072.5, 05, 02, 00.3199, 00.3019, 19.7700},
> {075.0, 05, 02, 00.3256, 00.3065, 19.7700},
> {077.5, 05, 02, 00.3296, 00.3098, 19.7700},
> {080.0, 05, 02, 00.3332, 00.3131, 19.7700},
> {082.5, 05, 02, 00.3360, 00.3158, 19.7700},
> {085.0, 05, 02, 00.3392, 00.3192, 19.7700},
> {087.5, 05, 02, 00.3425, 00.3229, 19.7700},
> {090.0, 05, 02, 00.3465, 00.3278, 19.7700},
> {092.5, 05, 02, 00.3506, 00.3337, 19.7700},
> {095.0, 05, 02, 00.3530, 00.3395, 19.7700},
> {097.5, 05, 02, 00.3540, 00.3445, 19.7700},
> {100.0, 05, 02, 00.3546, 00.3514, 19.7700},
> {002.5, 05, 04, 00.3968, 00.3954, 19.7700},
> {005.0, 05, 04, 00.3915, 00.4057, 19.7700},
> {007.5, 05, 04, 00.3850, 00.4120, 19.7700},
> {010.0, 05, 04, 00.3762, 00.4158, 19.7700},
> {012.5, 05, 04, 00.3621, 00.4143, 19.7700},
> {015.0, 05, 04, 00.3482, 00.4097, 19.7700},
> {017.5, 05, 04, 00.3274, 00.3994, 19.7700},
> {020.0, 05, 04, 00.3111, 00.3881, 19.7700},
> {022.5, 05, 04, 00.2943, 00.3735, 19.7700},
> {025.0, 05, 04, 00.2841, 00.3628, 19.7700},
> {027.5, 05, 04, 00.2775, 00.3545, 19.7700},
> {030.0, 05, 04, 00.2711, 00.3455, 19.7700},
> {032.5, 05, 04, 00.2659, 00.3369, 19.7700},
> {035.0, 05, 04, 00.2591, 00.3246, 19.7700},
> {037.5, 05, 04, 00.2550, 00.3150, 19.7700},
> {040.0, 05, 04, 00.2512, 00.3040, 19.7700},
> {042.5, 05, 04, 00.2492, 00.2954, 19.7700},
> {045.0, 05, 04, 00.2493, 00.2879, 19.7700},
> {047.5, 05, 04, 00.2511, 00.2808, 19.7700},
> {050.0, 05, 04, 00.2547, 00.2757, 19.7700},
> {052.5, 05, 04, 00.2600, 00.2720, 19.7700},
> {055.0, 05, 04, 00.2662, 00.2687, 19.7700},
> {057.5, 05, 04, 00.2739, 00.2666, 19.7700},
> {060.0, 05, 04, 00.2821, 00.2659, 19.7700},
> {062.5, 05, 04, 00.2898, 00.2667, 19.7700},
> {065.0, 05, 04, 00.2986, 00.2699, 19.7700},
> {067.5, 05, 04, 00.3100, 00.2750, 19.7700},
> {070.0, 05, 04, 00.3198, 00.2807, 19.7700},
> {072.5, 05, 04, 00.3298, 00.2869, 19.7700},
> {075.0, 05, 04, 00.3421, 00.2954, 19.7700},
> {077.5, 05, 04, 00.3515, 00.3024, 19.7700},
> {080.0, 05, 04, 00.3594, 00.3090, 19.7700},
> {082.5, 05, 04, 00.3660, 00.3148, 19.7700},
> {085.0, 05, 04, 00.3740, 00.3220, 19.7700},
> {087.5, 05, 04, 00.3806, 00.3294, 19.7700},
> {090.0, 05, 04, 00.3879, 00.3398, 19.7700},
> {092.5, 05, 04, 00.3925, 00.3494, 19.7700},
> {095.0, 05, 04, 00.3968, 00.3614, 19.7700},
> {097.5, 05, 04, 00.3991, 00.3714, 19.7700},
> {100.0, 05, 04, 00.3995, 00.3840, 19.7700},
> {002.5, 05, 06, 00.4380, 00.4292, 19.7700},
> {005.0, 05, 06, 00.4302, 00.4435, 19.7700},
> {007.5, 05, 06, 00.4199, 00.4551, 19.7700},
> {010.0, 05, 06, 00.4072, 00.4621, 19.7700},
> {012.5, 05, 06, 00.3879, 00.4646, 19.7700},
> {015.0, 05, 06, 00.3663, 00.4614, 19.7700},
> {017.5, 05, 06, 00.3354, 00.4483, 19.7700},
> {020.0, 05, 06, 00.3108, 00.4301, 19.7700},
> {022.5, 05, 06, 00.2841, 00.4045, 19.7700},
> {025.0, 05, 06, 00.2690, 00.3860, 19.7700},
> {027.5, 05, 06, 00.2598, 00.3724, 19.7700},
> {030.0, 05, 06, 00.2519, 00.3587, 19.7700},
> {032.5, 05, 06, 00.2448, 00.3452, 19.7700},
> {035.0, 05, 06, 00.2360, 00.3270, 19.7700},
> {037.5, 05, 06, 00.2292, 00.3125, 19.7700},
> {040.0, 05, 06, 00.2234, 00.2952, 19.7700},
> {042.5, 05, 06, 00.2210, 00.2823, 19.7700},
> {045.0, 05, 06, 00.2215, 00.2701, 19.7700},
> {047.5, 05, 06, 00.2248, 00.2612, 19.7700},
> {050.0, 05, 06, 00.2299, 00.2548, 19.7700},
> {052.5, 05, 06, 00.2365, 00.2488, 19.7700},
> {055.0, 05, 06, 00.2447, 00.2449, 19.7700},
> {057.5, 05, 06, 00.2563, 00.2417, 19.7700},
> {060.0, 05, 06, 00.2686, 00.2412, 19.7700},
> {062.5, 05, 06, 00.2806, 00.2444, 19.7700},
> {065.0, 05, 06, 00.2932, 00.2487, 19.7700},
> {067.5, 05, 06, 00.3093, 00.2555, 19.7700},
> {070.0, 05, 06, 00.3243, 00.2630, 19.7700},
> {072.5, 05, 06, 00.3396, 00.2718, 19.7700},
> {075.0, 05, 06, 00.3585, 00.2842, 19.7700},
> {077.5, 05, 06, 00.3726, 00.2941, 19.7700},
> {080.0, 05, 06, 00.3851, 00.3039, 19.7700},
> {082.5, 05, 06, 00.3960, 00.3130, 19.7700},
> {085.0, 05, 06, 00.4078, 00.3238, 19.7700},
> {087.5, 05, 06, 00.4180, 00.3348, 19.7700},
> {090.0, 05, 06, 00.4299, 00.3499, 19.7700},
> {092.5, 05, 06, 00.4365, 00.3640, 19.7700},
> {095.0, 05, 06, 00.4420, 00.3808, 19.7700},
> {097.5, 05, 06, 00.4440, 00.3954, 19.7700},
> {100.0, 05, 06, 00.4428, 00.4128, 19.7700},
> {002.5, 05, 08, 00.4685, 00.4524, 19.7700},
> {012.5, 05, 08, 00.4088, 00.5068, 19.7700},
> {015.0, 05, 08, 00.3815, 00.5093, 19.7700},
> {017.5, 05, 08, 00.3412, 00.4976, 19.7700},
> {020.0, 05, 08, 00.3080, 00.4759, 19.7700},
> {022.5, 05, 08, 00.2710, 00.4380, 19.7700},
> {025.0, 05, 08, 00.2511, 00.4107, 19.7700},
> {027.5, 05, 08, 00.2395, 00.3915, 19.7700},
> {052.5, 05, 08, 00.2157, 00.2278, 19.7700},
> {055.0, 05, 08, 00.2255, 00.2239, 19.7700},
> {057.5, 05, 08, 00.2417, 00.2204, 19.7700},
> {060.0, 05, 08, 00.2572, 00.2211, 19.7700},
> {062.5, 05, 08, 00.2728, 00.2240, 19.7700},
> {065.0, 05, 08, 00.2885, 00.2296, 19.7700},
> {067.5, 05, 08, 00.3087, 00.2375, 19.7700},
> {070.0, 05, 08, 00.3280, 00.2464, 19.7700},
> {072.5, 05, 08, 00.3490, 00.2570, 19.7700},
> {075.0, 05, 08, 00.3748, 00.2729, 19.7700},
> {077.5, 05, 08, 00.3932, 00.2852, 19.7700},
> {080.0, 05, 08, 00.4105, 00.2980, 19.7700},
> {082.5, 05, 08, 00.4252, 00.3101, 19.7700},
> {085.0, 05, 08, 00.4413, 00.3240, 19.7700},
> {087.5, 05, 08, 00.4563, 00.3387, 19.7700},
> {090.0, 05, 08, 00.4713, 00.3575, 19.7700},
> {092.5, 05, 08, 00.4795, 00.3758, 19.7700},
> {095.0, 05, 08, 00.4830, 00.3960, 19.7700},
> {097.5, 05, 08, 00.4820, 00.4141, 19.7700},
> {100.0, 05, 08, 00.4770, 00.4338, 19.7700},
> {055.0, 05, 10, 00.2080, 00.2041, 19.7700},
> {057.5, 05, 10, 00.2285, 00.2020, 19.7700},
> {060.0, 05, 10, 00.2478, 00.2030, 19.7700},
> {062.5, 05, 10, 00.2665, 00.2075, 19.7700},
> {065.0, 05, 10, 00.2845, 00.2137, 19.7700},
> {067.5, 05, 10, 00.3080, 00.2230, 19.7700},
> {070.0, 05, 10, 00.3308, 00.2328, 19.7700},
> {072.5, 05, 10, 00.3560, 00.2452, 19.7700},
> {075.0, 05, 10, 00.3880, 00.2630, 19.7700},
> {077.5, 05, 10, 00.4108, 00.2773, 19.7700},
> {080.0, 05, 10, 00.4332, 00.2918, 19.7700},
> {082.5, 05, 10, 00.4533, 00.3058, 19.7700},
> {085.0, 05, 10, 00.4747, 00.3227, 19.7700},
> {087.5, 05, 10, 00.4927, 00.3399, 19.7700},
> {090.0, 05, 10, 00.5113, 00.3630, 19.7700},
> {092.5, 05, 10, 00.5175, 00.3844, 19.7700},
> {095.0, 05, 10, 00.5161, 00.4064, 19.7700},
> {097.5, 05, 10, 00.5108, 00.4276, 19.7700},
> {082.5, 05, 12, 00.4820, 00.3002, 19.7700},
> {085.0, 05, 12, 00.5071, 00.3194, 19.7700},
> {087.5, 05, 12, 00.5280, 00.3389, 19.7700},
> {002.5, 06, 02, 00.3480, 00.3540, 30.0500},
> {005.0, 06, 02, 00.3457, 00.3580, 30.0500},
> {007.5, 06, 02, 00.3431, 00.3601, 30.0500},
> {010.0, 06, 02, 00.3398, 00.3611, 30.0500},
> {012.5, 06, 02, 00.3342, 00.3607, 30.0500},
> {015.0, 06, 02, 00.3288, 00.3592, 30.0500},
> {017.5, 06, 02, 00.3193, 00.3550, 30.0500},
> {020.0, 06, 02, 00.3112, 00.3496, 30.0500},
> {022.5, 06, 02, 00.3039, 00.3437, 30.0500},
> {025.0, 06, 02, 00.2988, 00.3382, 30.0500},
> {027.5, 06, 02, 00.2958, 00.3344, 30.0500},
> {030.0, 06, 02, 00.2929, 00.3303, 30.0500},
> {032.5, 06, 02, 00.2902, 00.3268, 30.0500},
> {035.0, 06, 02, 00.2872, 00.3219, 30.0500},
> {037.5, 06, 02, 00.2849, 00.3172, 30.0500},
> {040.0, 06, 02, 00.2837, 00.3132, 30.0500},
> {042.5, 06, 02, 00.2835, 00.3097, 30.0500},
> {045.0, 06, 02, 00.2842, 00.3063, 30.0500},
> {047.5, 06, 02, 00.2854, 00.3037, 30.0500},
> {050.0, 06, 02, 00.2871, 00.3012, 30.0500},
> {052.5, 06, 02, 00.2897, 00.2991, 30.0500},
> {055.0, 06, 02, 00.2923, 00.2978, 30.0500},
> {057.5, 06, 02, 00.2955, 00.2963, 30.0500},
> {060.0, 06, 02, 00.2988, 00.2961, 30.0500},
> {062.5, 06, 02, 00.3016, 00.2960, 30.0500},
> {065.0, 06, 02, 00.3050, 00.2967, 30.0500},
> {067.5, 06, 02, 00.3107, 00.2993, 30.0500},
> {070.0, 06, 02, 00.3146, 00.3018, 30.0500},
> {072.5, 06, 02, 00.3188, 00.3048, 30.0500},
> {075.0, 06, 02, 00.3232, 00.3085, 30.0500},
> {077.5, 06, 02, 00.3261, 00.3113, 30.0500},
> {080.0, 06, 02, 00.3292, 00.3141, 30.0500},
> {082.5, 06, 02, 00.3318, 00.3166, 30.0500},
> {085.0, 06, 02, 00.3343, 00.3190, 30.0500},
> {087.5, 06, 02, 00.3381, 00.3228, 30.0500},
> {090.0, 06, 02, 00.3417, 00.3268, 30.0500},
> {092.5, 06, 02, 00.3453, 00.3321, 30.0500},
> {095.0, 06, 02, 00.3474, 00.3373, 30.0500},
> {097.5, 06, 02, 00.3487, 00.3421, 30.0500},
> {100.0, 06, 02, 00.3491, 00.3483, 30.0500},
> {002.5, 06, 04, 00.3840, 00.3867, 30.0500},
> {005.0, 06, 04, 00.3794, 00.3955, 30.0500},
> {007.5, 06, 04, 00.3745, 00.4004, 30.0500},
> {010.0, 06, 04, 00.3679, 00.4033, 30.0500},
> {012.5, 06, 04, 00.3572, 00.4038, 30.0500},
> {015.0, 06, 04, 00.3461, 00.4008, 30.0500},
> {017.5, 06, 04, 00.3275, 00.3922, 30.0500},
> {020.0, 06, 04, 00.3124, 00.3822, 30.0500},
> {022.5, 06, 04, 00.2967, 00.3695, 30.0500},
> {025.0, 06, 04, 00.2868, 00.3595, 30.0500},
> {027.5, 06, 04, 00.2807, 00.3522, 30.0500},
> {030.0, 06, 04, 00.2749, 00.3443, 30.0500},
> {032.5, 06, 04, 00.2702, 00.3369, 30.0500},
> {035.0, 06, 04, 00.2648, 00.3262, 30.0500},
> {037.5, 06, 04, 00.2604, 00.3169, 30.0500},
> {040.0, 06, 04, 00.2578, 00.3078, 30.0500},
> {042.5, 06, 04, 00.2571, 00.3008, 30.0500},
> {045.0, 06, 04, 00.2579, 00.2938, 30.0500},
> {047.5, 06, 04, 00.2602, 00.2881, 30.0500},
> {050.0, 06, 04, 00.2637, 00.2840, 30.0500},
> {052.5, 06, 04, 00.2684, 00.2804, 30.0500},
> {055.0, 06, 04, 00.2734, 00.2778, 30.0500},
> {057.5, 06, 04, 00.2798, 00.2752, 30.0500},
> {060.0, 06, 04, 00.2863, 00.2747, 30.0500},
> {062.5, 06, 04, 00.2932, 00.2759, 30.0500},
> {065.0, 06, 04, 00.3001, 00.2778, 30.0500},
> {067.5, 06, 04, 00.3107, 00.2831, 30.0500},
> {070.0, 06, 04, 00.3181, 00.2871, 30.0500},
> {072.5, 06, 04, 00.3272, 00.2929, 30.0500},
> {075.0, 06, 04, 00.3371, 00.3001, 30.0500},
> {077.5, 06, 04, 00.3439, 00.3056, 30.0500},
> {080.0, 06, 04, 00.3508, 00.3112, 30.0500},
> {082.5, 06, 04, 00.3566, 00.3163, 30.0500},
> {085.0, 06, 04, 00.3628, 00.3221, 30.0500},
> {087.5, 06, 04, 00.3692, 00.3291, 30.0500},
> {090.0, 06, 04, 00.3768, 00.3381, 30.0500},
> {092.5, 06, 04, 00.3806, 00.3467, 30.0500},
> {095.0, 06, 04, 00.3840, 00.3564, 30.0500},
> {097.5, 06, 04, 00.3860, 00.3652, 30.0500},
> {100.0, 06, 04, 00.3861, 00.3767, 30.0500},
> {002.5, 06, 06, 00.4203, 00.4176, 30.0500},
> {005.0, 06, 06, 00.4140, 00.4305, 30.0500},
> {007.5, 06, 06, 00.4060, 00.4400, 30.0500},
> {010.0, 06, 06, 00.3960, 00.4452, 30.0500},
> {012.5, 06, 06, 00.3799, 00.4470, 30.0500},
> {015.0, 06, 06, 00.3622, 00.4438, 30.0500},
> {017.5, 06, 06, 00.3351, 00.4321, 30.0500},
> {020.0, 06, 06, 00.3128, 00.4175, 30.0500},
> {022.5, 06, 06, 00.2892, 00.3963, 30.0500},
> {025.0, 06, 06, 00.2748, 00.3795, 30.0500},
> {027.5, 06, 06, 00.2662, 00.3672, 30.0500},
> {030.0, 06, 06, 00.2591, 00.3558, 30.0500},
> {032.5, 06, 06, 00.2526, 00.3448, 30.0500},
> {035.0, 06, 06, 00.2441, 00.3290, 30.0500},
> {037.5, 06, 06, 00.2384, 00.3155, 30.0500},
> {040.0, 06, 06, 00.2335, 00.3015, 30.0500},
> {042.5, 06, 06, 00.2312, 00.2899, 30.0500},
> {045.0, 06, 06, 00.2320, 00.2789, 30.0500},
> {047.5, 06, 06, 00.2352, 00.2708, 30.0500},
> {050.0, 06, 06, 00.2399, 00.2650, 30.0500},
> {052.5, 06, 06, 00.2465, 00.2599, 30.0500},
> {055.0, 06, 06, 00.2533, 00.2558, 30.0500},
> {057.5, 06, 06, 00.2638, 00.2531, 30.0500},
> {060.0, 06, 06, 00.2740, 00.2533, 30.0500},
> {062.5, 06, 06, 00.2842, 00.2550, 30.0500},
> {065.0, 06, 06, 00.2950, 00.2585, 30.0500},
> {067.5, 06, 06, 00.3101, 00.2650, 30.0500},
> {070.0, 06, 06, 00.3226, 00.2716, 30.0500},
> {072.5, 06, 06, 00.3362, 00.2799, 30.0500},
> {075.0, 06, 06, 00.3520, 00.2904, 30.0500},
> {077.5, 06, 06, 00.3635, 00.2987, 30.0500},
> {080.0, 06, 06, 00.3740, 00.3074, 30.0500},
> {082.5, 06, 06, 00.3832, 00.3158, 30.0500},
> {085.0, 06, 06, 00.3921, 00.3244, 30.0500},
> {087.5, 06, 06, 00.4000, 00.3340, 30.0500},
> {090.0, 06, 06, 00.4103, 00.3473, 30.0500},
> {092.5, 06, 06, 00.4180, 00.3600, 30.0500},
> {095.0, 06, 06, 00.4229, 00.3750, 30.0500},
> {097.5, 06, 06, 00.4242, 00.3876, 30.0500},
> {100.0, 06, 06, 00.4240, 00.4030, 30.0500},
> {002.5, 06, 08, 00.4517, 00.4421, 30.0500},
> {005.0, 06, 08, 00.4426, 00.4588, 30.0500},
> {007.5, 06, 08, 00.4321, 00.4719, 30.0500},
> {012.5, 06, 08, 00.4006, 00.4885, 30.0500},
> {015.0, 06, 08, 00.3772, 00.4880, 30.0500},
> {017.5, 06, 08, 00.3418, 00.4768, 30.0500},
> {020.0, 06, 08, 00.3116, 00.4563, 30.0500},
> {022.5, 06, 08, 00.2799, 00.4239, 30.0500},
> {052.5, 06, 08, 00.2274, 00.2406, 30.0500},
> {055.0, 06, 08, 00.2360, 00.2365, 30.0500},
> {057.5, 06, 08, 00.2505, 00.2347, 30.0500},
> {060.0, 06, 08, 00.2637, 00.2352, 30.0500},
> {062.5, 06, 08, 00.2770, 00.2372, 30.0500},
> {065.0, 06, 08, 00.2905, 00.2421, 30.0500},
> {067.5, 06, 08, 00.3099, 00.2502, 30.0500},
> {070.0, 06, 08, 00.3259, 00.2584, 30.0500},
> {072.5, 06, 08, 00.3437, 00.2688, 30.0500},
> {075.0, 06, 08, 00.3648, 00.2820, 30.0500},
> {077.5, 06, 08, 00.3791, 00.2929, 30.0500},
> {080.0, 06, 08, 00.3930, 00.3038, 30.0500},
> {082.5, 06, 08, 00.4065, 00.3144, 30.0500},
> {085.0, 06, 08, 00.4187, 00.3251, 30.0500},
> {087.5, 06, 08, 00.4318, 00.3383, 30.0500},
> {090.0, 06, 08, 00.4449, 00.3550, 30.0500},
> {092.5, 06, 08, 00.4533, 00.3708, 30.0500},
> {095.0, 06, 08, 00.4592, 00.3900, 30.0500},
> {097.5, 06, 08, 00.4596, 00.4064, 30.0500},
> {100.0, 06, 08, 00.4570, 00.4249, 30.0500},
> {002.5, 06, 10, 00.4760, 00.4607, 30.0500},
> {017.5, 06, 10, 00.3463, 00.5196, 30.0500},
> {020.0, 06, 10, 00.3086, 00.4949, 30.0500},
> {072.5, 06, 10, 00.3509, 00.2578, 30.0500},
> {075.0, 06, 10, 00.3769, 00.2738, 30.0500},
> {077.5, 06, 10, 00.3960, 00.2860, 30.0500},
> {080.0, 06, 10, 00.4150, 00.2989, 30.0500},
> {082.5, 06, 10, 00.4320, 00.3118, 30.0500},
> {085.0, 06, 10, 00.4480, 00.3250, 30.0500},
> {087.5, 06, 10, 00.4655, 00.3412, 30.0500},
> {090.0, 06, 10, 00.4812, 00.3619, 30.0500},
> {092.5, 06, 10, 00.4891, 00.3806, 30.0500},
> {095.0, 06, 10, 00.4921, 00.4022, 30.0500},
> {097.5, 06, 10, 00.4904, 00.4220, 30.0500},
> {100.0, 06, 10, 00.4843, 00.4416, 30.0500},
> {092.5, 06, 12, 00.5215, 00.3887, 30.0500},
> {095.0, 06, 12, 00.5199, 00.4119, 30.0500},
> {097.5, 06, 12, 00.5145, 00.4331, 30.0500},
> {002.5, 07, 02, 00.3436, 00.3507, 43.0600},
> {005.0, 07, 02, 00.3419, 00.3540, 43.0600},
> {007.5, 07, 02, 00.3396, 00.3558, 43.0600},
> {010.0, 07, 02, 00.3369, 00.3569, 43.0600},
> {012.5, 07, 02, 00.3328, 00.3569, 43.0600},
> {015.0, 07, 02, 00.3284, 00.3559, 43.0600},
> {017.5, 07, 02, 00.3190, 00.3516, 43.0600},
> {020.0, 07, 02, 00.3117, 00.3469, 43.0600},
> {022.5, 07, 02, 00.3047, 00.3413, 43.0600},
> {025.0, 07, 02, 00.3001, 00.3366, 43.0600},
> {027.5, 07, 02, 00.2972, 00.3333, 43.0600},
> {030.0, 07, 02, 00.2945, 00.3297, 43.0600},
> {032.5, 07, 02, 00.2927, 00.3269, 43.0600},
> {035.0, 07, 02, 00.2898, 00.3225, 43.0600},
> {037.5, 07, 02, 00.2878, 00.3182, 43.0600},
> {040.0, 07, 02, 00.2869, 00.3143, 43.0600},
> {042.5, 07, 02, 00.2867, 00.3110, 43.0600},
> {045.0, 07, 02, 00.2875, 00.3078, 43.0600},
> {047.5, 07, 02, 00.2888, 00.3058, 43.0600},
> {050.0, 07, 02, 00.2908, 00.3039, 43.0600},
> {052.5, 07, 02, 00.2932, 00.3025, 43.0600},
> {055.0, 07, 02, 00.2952, 00.3011, 43.0600},
> {057.5, 07, 02, 00.2982, 00.3003, 43.0600},
> {060.0, 07, 02, 00.3005, 00.3000, 43.0600},
> {062.5, 07, 02, 00.3031, 00.3000, 43.0600},
> {065.0, 07, 02, 00.3059, 00.3010, 43.0600},
> {067.5, 07, 02, 00.3109, 00.3037, 43.0600},
> {070.0, 07, 02, 00.3138, 00.3054, 43.0600},
> {072.5, 07, 02, 00.3170, 00.3076, 43.0600},
> {075.0, 07, 02, 00.3206, 00.3104, 43.0600},
> {077.5, 07, 02, 00.3232, 00.3125, 43.0600},
> {080.0, 07, 02, 00.3258, 00.3148, 43.0600},
> {082.5, 07, 02, 00.3284, 00.3170, 43.0600},
> {085.0, 07, 02, 00.3306, 00.3190, 43.0600},
> {087.5, 07, 02, 00.3335, 00.3220, 43.0600},
> {090.0, 07, 02, 00.3360, 00.3253, 43.0600},
> {092.5, 07, 02, 00.3392, 00.3298, 43.0600},
> {095.0, 07, 02, 00.3421, 00.3349, 43.0600},
> {097.5, 07, 02, 00.3437, 00.3397, 43.0600},
> {100.0, 07, 02, 00.3443, 00.3454, 43.0600},
> {002.5, 07, 04, 00.3761, 00.3800, 43.0600},
> {005.0, 07, 04, 00.3718, 00.3885, 43.0600},
> {007.5, 07, 04, 00.3677, 00.3925, 43.0600},
> {010.0, 07, 04, 00.3624, 00.3951, 43.0600},
> {012.5, 07, 04, 00.3534, 00.3953, 43.0600},
> {015.0, 07, 04, 00.3437, 00.3929, 43.0600},
> {017.5, 07, 04, 00.3267, 00.3848, 43.0600},
> {020.0, 07, 04, 00.3133, 00.3764, 43.0600},
> {022.5, 07, 04, 00.2992, 00.3644, 43.0600},
> {025.0, 07, 04, 00.2902, 00.3548, 43.0600},
> {027.5, 07, 04, 00.2850, 00.3482, 43.0600},
> {030.0, 07, 04, 00.2803, 00.3415, 43.0600},
> {032.5, 07, 04, 00.2764, 00.3354, 43.0600},
> {035.0, 07, 04, 00.2712, 00.3269, 43.0600},
> {037.5, 07, 04, 00.2671, 00.3189, 43.0600},
> {040.0, 07, 04, 00.2642, 00.3109, 43.0600},
> {042.5, 07, 04, 00.2629, 00.3038, 43.0600},
> {045.0, 07, 04, 00.2633, 00.2972, 43.0600},
> {047.5, 07, 04, 00.2651, 00.2927, 43.0600},
> {050.0, 07, 04, 00.2685, 00.2886, 43.0600},
> {052.5, 07, 04, 00.2729, 00.2848, 43.0600},
> {055.0, 07, 04, 00.2773, 00.2828, 43.0600},
> {057.5, 07, 04, 00.2833, 00.2809, 43.0600},
> {060.0, 07, 04, 00.2886, 00.2801, 43.0600},
> {062.5, 07, 04, 00.2950, 00.2810, 43.0600},
> {065.0, 07, 04, 00.3009, 00.2831, 43.0600},
> {067.5, 07, 04, 00.3111, 00.2880, 43.0600},
> {070.0, 07, 04, 00.3181, 00.2920, 43.0600},
> {072.5, 07, 04, 00.3254, 00.2971, 43.0600},
> {075.0, 07, 04, 00.3332, 00.3032, 43.0600},
> {077.5, 07, 04, 00.3389, 00.3079, 43.0600},
> {080.0, 07, 04, 00.3446, 00.3125, 43.0600},
> {082.5, 07, 04, 00.3499, 00.3171, 43.0600},
> {085.0, 07, 04, 00.3552, 00.3222, 43.0600},
> {087.5, 07, 04, 00.3611, 00.3282, 43.0600},
> {090.0, 07, 04, 00.3671, 00.3360, 43.0600},
> {092.5, 07, 04, 00.3715, 00.3439, 43.0600},
> {095.0, 07, 04, 00.3750, 00.3530, 43.0600},
> {097.5, 07, 04, 00.3772, 00.3613, 43.0600},
> {100.0, 07, 04, 00.3778, 00.3719, 43.0600},
> {002.5, 07, 06, 00.4073, 00.4073, 43.0600},
> {005.0, 07, 06, 00.4009, 00.4198, 43.0600},
> {007.5, 07, 06, 00.3943, 00.4264, 43.0600},
> {010.0, 07, 06, 00.3864, 00.4305, 43.0600},
> {012.5, 07, 06, 00.3728, 00.4316, 43.0600},
> {015.0, 07, 06, 00.3581, 00.4291, 43.0600},
> {017.5, 07, 06, 00.3341, 00.4191, 43.0600},
> {020.0, 07, 06, 00.3142, 00.4058, 43.0600},
> {022.5, 07, 06, 00.2933, 00.3873, 43.0600},
> {025.0, 07, 06, 00.2801, 00.3721, 43.0600},
> {027.5, 07, 06, 00.2728, 00.3622, 43.0600},
> {042.5, 07, 06, 00.2418, 00.2960, 43.0600},
> {045.0, 07, 06, 00.2410, 00.2854, 43.0600},
> {047.5, 07, 06, 00.2436, 00.2787, 43.0600},
> {050.0, 07, 06, 00.2478, 00.2728, 43.0600},
> {052.5, 07, 06, 00.2538, 00.2677, 43.0600},
> {055.0, 07, 06, 00.2596, 00.2643, 43.0600},
> {057.5, 07, 06, 00.2687, 00.2612, 43.0600},
> {060.0, 07, 06, 00.2776, 00.2612, 43.0600},
> {062.5, 07, 06, 00.2873, 00.2633, 43.0600},
> {065.0, 07, 06, 00.2961, 00.2663, 43.0600},
> {067.5, 07, 06, 00.3111, 00.2730, 43.0600},
> {070.0, 07, 06, 00.3221, 00.2786, 43.0600},
> {072.5, 07, 06, 00.3338, 00.2854, 43.0600},
> {075.0, 07, 06, 00.3470, 00.2949, 43.0600},
> {077.5, 07, 06, 00.3562, 00.3022, 43.0600},
> {080.0, 07, 06, 00.3648, 00.3098, 43.0600},
> {082.5, 07, 06, 00.3728, 00.3170, 43.0600},
> {085.0, 07, 06, 00.3805, 00.3244, 43.0600},
> {087.5, 07, 06, 00.3888, 00.3336, 43.0600},
> {090.0, 07, 06, 00.3984, 00.3452, 43.0600},
> {092.5, 07, 06, 00.4053, 00.3570, 43.0600},
> {095.0, 07, 06, 00.4091, 00.3701, 43.0600},
> {097.5, 07, 06, 00.4107, 00.3820, 43.0600},
> {100.0, 07, 06, 00.4102, 00.3960, 43.0600},
> {002.5, 07, 08, 00.4353, 00.4312, 43.0600},
> {005.0, 07, 08, 00.4271, 00.4462, 43.0600},
> {007.5, 07, 08, 00.4184, 00.4568, 43.0600},
> {010.0, 07, 08, 00.4090, 00.4641, 43.0600},
> {012.5, 07, 08, 00.3919, 00.4684, 43.0600},
> {015.0, 07, 08, 00.3722, 00.4669, 43.0600},
> {017.5, 07, 08, 00.3406, 00.4558, 43.0600},
> {020.0, 07, 08, 00.3140, 00.4387, 43.0600},
> {022.5, 07, 08, 00.2861, 00.4129, 43.0600},
> {067.5, 07, 08, 00.3109, 00.2584, 43.0600},
> {070.0, 07, 08, 00.3256, 00.2654, 43.0600},
> {072.5, 07, 08, 00.3417, 00.2745, 43.0600},
> {075.0, 07, 08, 00.3603, 00.2869, 43.0600},
> {077.5, 07, 08, 00.3722, 00.2963, 43.0600},
> {080.0, 07, 08, 00.3851, 00.3067, 43.0600},
> {082.5, 07, 08, 00.3961, 00.3160, 43.0600},
> {085.0, 07, 08, 00.4067, 00.3256, 43.0600},
> {087.5, 07, 08, 00.4196, 00.3382, 43.0600},
> {090.0, 07, 08, 00.4308, 00.3533, 43.0600},
> {092.5, 07, 08, 00.4371, 00.3679, 43.0600},
> {095.0, 07, 08, 00.4402, 00.3842, 43.0600},
> {097.5, 07, 08, 00.4415, 00.3996, 43.0600},
> {100.0, 07, 08, 00.4399, 00.4164, 43.0600},
> {002.5, 07, 10, 00.4606, 00.4516, 43.0600},
> {005.0, 07, 10, 00.4509, 00.4696, 43.0600},
> {007.5, 07, 10, 00.4400, 00.4830, 43.0600},
> {012.5, 07, 10, 00.4091, 00.5030, 43.0600},
> {015.0, 07, 10, 00.3852, 00.5051, 43.0600},
> {017.5, 07, 10, 00.3461, 00.4950, 43.0600},
> {090.0, 07, 10, 00.4600, 00.3596, 43.0600},
> {092.5, 07, 10, 00.4671, 00.3768, 43.0600},
> {095.0, 07, 10, 00.4711, 00.3972, 43.0600},
> {097.5, 07, 10, 00.4704, 00.4151, 43.0600},
> {100.0, 07, 10, 00.4667, 00.4335, 43.0600},
> {002.5, 08, 02, 00.3406, 00.3484, 59.1000},
> {005.0, 08, 02, 00.3394, 00.3518, 59.1000},
> {007.5, 08, 02, 00.3379, 00.3540, 59.1000},
> {010.0, 08, 02, 00.3359, 00.3552, 59.1000},
> {012.5, 08, 02, 00.3327, 00.3555, 59.1000},
> {015.0, 08, 02, 00.3284, 00.3542, 59.1000},
> {017.5, 08, 02, 00.3194, 00.3502, 59.1000},
> {020.0, 08, 02, 00.3121, 00.3459, 59.1000},
> {022.5, 08, 02, 00.3053, 00.3404, 59.1000},
> {025.0, 08, 02, 00.3009, 00.3359, 59.1000},
> {027.5, 08, 02, 00.2981, 00.3326, 59.1000},
> {030.0, 08, 02, 00.2957, 00.3293, 59.1000},
> {032.5, 08, 02, 00.2940, 00.3268, 59.1000},
> {035.0, 08, 02, 00.2919, 00.3228, 59.1000},
> {037.5, 08, 02, 00.2900, 00.3183, 59.1000},
> {040.0, 08, 02, 00.2894, 00.3152, 59.1000},
> {042.5, 08, 02, 00.2897, 00.3124, 59.1000},
> {045.0, 08, 02, 00.2908, 00.3096, 59.1000},
> {047.5, 08, 02, 00.2922, 00.3077, 59.1000},
> {050.0, 08, 02, 00.2935, 00.3062, 59.1000},
> {052.5, 08, 02, 00.2957, 00.3047, 59.1000},
> {055.0, 08, 02, 00.2974, 00.3039, 59.1000},
> {057.5, 08, 02, 00.3003, 00.3034, 59.1000},
> {060.0, 08, 02, 00.3027, 00.3035, 59.1000},
> {062.5, 08, 02, 00.3048, 00.3040, 59.1000},
> {065.0, 08, 02, 00.3065, 00.3047, 59.1000},
> {067.5, 08, 02, 00.3107, 00.3070, 59.1000},
> {070.0, 08, 02, 00.3131, 00.3084, 59.1000},
> {072.5, 08, 02, 00.3154, 00.3100, 59.1000},
> {075.0, 08, 02, 00.3180, 00.3120, 59.1000},
> {077.5, 08, 02, 00.3200, 00.3136, 59.1000},
> {080.0, 08, 02, 00.3218, 00.3152, 59.1000},
> {082.5, 08, 02, 00.3236, 00.3169, 59.1000},
> {085.0, 08, 02, 00.3254, 00.3186, 59.1000},
> {087.5, 08, 02, 00.3277, 00.3211, 59.1000},
> {090.0, 08, 02, 00.3301, 00.3237, 59.1000},
> {092.5, 08, 02, 00.3334, 00.3276, 59.1000},
> {095.0, 08, 02, 00.3373, 00.3330, 59.1000},
> {097.5, 08, 02, 00.3395, 00.3379, 59.1000},
> {100.0, 08, 02, 00.3407, 00.3434, 59.1000},
> {002.5, 08, 04, 00.3684, 00.3751, 59.1000},
> {005.0, 08, 04, 00.3650, 00.3826, 59.1000},
> {007.5, 08, 04, 00.3622, 00.3861, 59.1000},
> {010.0, 08, 04, 00.3581, 00.3883, 59.1000},
> {012.5, 08, 04, 00.3504, 00.3887, 59.1000},
> {015.0, 08, 04, 00.3433, 00.3872, 59.1000},
> {017.5, 08, 04, 00.3266, 00.3809, 59.1000},
> {020.0, 08, 04, 00.3140, 00.3727, 59.1000},
> {022.5, 08, 04, 00.3009, 00.3614, 59.1000},
> {025.0, 08, 04, 00.2924, 00.3523, 59.1000},
> {027.5, 08, 04, 00.2874, 00.3464, 59.1000},
> {042.5, 08, 04, 00.2668, 00.3067, 59.1000},
> {045.0, 08, 04, 00.2671, 00.2998, 59.1000},
> {047.5, 08, 04, 00.2688, 00.2956, 59.1000},
> {050.0, 08, 04, 00.2718, 00.2911, 59.1000},
> {052.5, 08, 04, 00.2758, 00.2879, 59.1000},
> {062.5, 08, 04, 00.2962, 00.2850, 59.1000},
> {065.0, 08, 04, 00.3012, 00.2868, 59.1000},
> {067.5, 08, 04, 00.3114, 00.2915, 59.1000},
> {070.0, 08, 04, 00.3175, 00.2955, 59.1000},
> {072.5, 08, 04, 00.3239, 00.3000, 59.1000},
> {075.0, 08, 04, 00.3308, 00.3052, 59.1000},
> {077.5, 08, 04, 00.3360, 00.3092, 59.1000},
> {080.0, 08, 04, 00.3412, 00.3135, 59.1000},
> {082.5, 08, 04, 00.3460, 00.3177, 59.1000},
> {085.0, 08, 04, 00.3510, 00.3224, 59.1000},
> {087.5, 08, 04, 00.3564, 00.3279, 59.1000},
> {090.0, 08, 04, 00.3621, 00.3349, 59.1000},
> {092.5, 08, 04, 00.3667, 00.3429, 59.1000},
> {095.0, 08, 04, 00.3690, 00.3510, 59.1000},
> {097.5, 08, 04, 00.3699, 00.3586, 59.1000},
> {100.0, 08, 04, 00.3701, 00.3674, 59.1000},
> {002.5, 08, 06, 00.3969, 00.4009, 59.1000},
> {005.0, 08, 06, 00.3913, 00.4117, 59.1000},
> {007.5, 08, 06, 00.3862, 00.4175, 59.1000},
> {010.0, 08, 06, 00.3803, 00.4216, 59.1000},
> {012.5, 08, 06, 00.3690, 00.4230, 59.1000},
> {015.0, 08, 06, 00.3573, 00.4214, 59.1000},
> {017.5, 08, 06, 00.3339, 00.4129, 59.1000},
> {020.0, 08, 06, 00.3150, 00.4014, 59.1000},
> {022.5, 08, 06, 00.2952, 00.3851, 59.1000},
> {025.0, 08, 06, 00.2822, 00.3702, 59.1000},
> {072.5, 08, 06, 00.3327, 00.2898, 59.1000},
> {075.0, 08, 06, 00.3440, 00.2978, 59.1000},
> {077.5, 08, 06, 00.3521, 00.3042, 59.1000},
> {080.0, 08, 06, 00.3600, 00.3112, 59.1000},
> {082.5, 08, 06, 00.3671, 00.3175, 59.1000},
> {097.5, 08, 06, 00.4000, 00.3770, 59.1000},
> {100.0, 08, 06, 00.3994, 00.3896, 59.1000},
> {002.5, 08, 08, 00.4231, 00.4231, 59.1000},
> {005.0, 08, 08, 00.4158, 00.4378, 59.1000},
> {007.5, 08, 08, 00.4088, 00.4466, 59.1000},
> {010.0, 08, 08, 00.4008, 00.4520, 59.1000},
> {012.5, 08, 08, 00.3858, 00.4550, 59.1000},
> {015.0, 08, 08, 00.3696, 00.4542, 59.1000},
> {017.5, 08, 08, 00.3408, 00.4452, 59.1000},
> {005.0, 08, 10, 00.4376, 00.4601, 59.1000},
> {007.5, 08, 10, 00.4283, 00.4712, 59.1000},
> {005.0, 08, 12, 00.4562, 00.4788, 59.1000}
> #local Muns_gap_width = 1/16;
> #local Muns_gap_vector = y * Muns_gap_width;
> #local Muns_coo_count = 0;
> #while (Muns_coo_count < 956)
> #local Muns_param_h = Muns_coo_table[Muns_coo_count][0];
> #local Muns_param_V = Muns_coo_table[Muns_coo_count][1];
> #local Muns_param_C = Muns_coo_table[Muns_coo_count][2];
> #local Muns_param_x = Muns_coo_table[Muns_coo_count][3];
> #local Muns_param_y = Muns_coo_table[Muns_coo_count][4];
> #local Muns_param_Y = Muns_coo_table[Muns_coo_count][5]/100;
> #local Muns_coo_xyY = <Muns_param_x,Muns_param_y,Muns_param_Y,>;
> #local Muns_coo_RGB =
> MapGamut(xyz2RGB(ChromaMatchSource(xyY2xyz(Muns_coo_xyY))));
> #local Muns_bound_object = cylinder {0,+y,Muns_param_C + 1};
> intersection
> plane {+x,-Muns_gap_width}
> plane {-x,-Muns_gap_width rotate -y * 9}
> difference
> cylinder {Muns_gap_vector,+y - Muns_gap_vector,Muns_param_C
> - Muns_gap_width + 1}
> cylinder {0,+y,Muns_param_C + Muns_gap_width}
> bounded_by {Muns_bound_object}
> pigment {color srgb Muns_coo_RGB}
> finish {ambient 1}
> translate +y * (Muns_param_V - 5)
> rotate +y * Muns_param_h/100 * 360
> scale 1/10
> // #debug concat("#",str(Muns_coo_count,3,0)," =
> <",vstr(3,Muns_coo_RGB,",",0,-1),">\n");
> #local Muns_coo_count = Muns_coo_count + 1;
> #end
I just noticed that there are sRGB values in a spreadsheet here:
http://www.rit.edu/cos/colorscience/rc_munsell_renotation.php
I may just use those instead. But are they copyrighted?
Mike
> shape?
> Mike
>> this:
>> #version 3.7
>> #include "math.inc"
>> global_settings
>> assumed_gamma 1.0
>> adc_bailout 0.005
>> max_trace_level 50
>> ambient_light 1
>> radiosity
>> pretrace_start 0.08
>> pretrace_end 0.01
>> count 50
>> error_bound 0.1
>> recursion_limit 1
>> normal on
>> brightness 0.8
>> always_sample yes
>> gray_threshold 0.8
>> media on
>> light_source
>> <-1,+1,-1,> * 300
>> color srgb 1
>> parallel
>> camera
>> orthographic
>> #case (0)
>> rotate +y * 045
>> // rotate +y * 180
>> #break
>> #case (1)
>> rotate +x * 090
>> rotate +y * 045
>> rotate +y * 180
>> #case (2)
>> rotate +y * 045
>> rotate +y * 180
>> #break
>> #end
>> objects
>> // h, V, C, x, y, Y
>> intersection
>> difference
>> finish {ambient 1}
>> scale 1/10
>> #end
> shape?
That would help, wouldn't it? But I haven't seen any Munsell data set
with any gray values.
The 1943 renotation is an extrapolation of the 1929 data set, and is
thus far more comprehensive. It would certainly be more useful than
what you have now. However...
With a vengeance: http://www.rit.edu/terms_of_use.html
Note "derivative works" in their language. Also note the Copyright
Infringement link, which wields the DMCA. These people sound serious.
I have rendered the 1943 data myself, but I dare not publish it. At
least the copyright on the 1929 data has expired. If it makes you feel
better, most of the extra 1943 points are outside the sRGB gamut anyway.
(One copy on one computer? Screw that! I'm not screening these files
out from my regular backups.)
You can always contact RIT for permission to use their data in a
GNU-LGPL 2.1 project. The worse they can do is say no. Alternatively,
you can go straight to the source at:
https://www.osapublishing.org/josa/abstract.cfm?uri=josa-33-7-385
but you will have to pay for it. The OSA Web site is also copyrighted
(as are nearly all Web sites), but I don't know what rights are reserved
for the papers in their library.
