POV-Ray : Newsgroups : povray.advanced-users : Loopable "smoke". Server Time
16 Aug 2025 11:50:34 EDT (-0400)
  Loopable "smoke". (Message 1 to 5 of 5)
Subject: Loopable "smoke".
Date: 21 Oct 2015 22:27:39
Message: <5628499b$1@news.povray.org>
Ok, I know its feasible to do this with some textures, if I remember
but.. Here is what I am trying to do:
1. Create glass for a display case.
2. Place runes on the case surface.
3. Alter the effective "visibility" of these runes, using a smoke like
effect, which follows a clear pattern of changes, and then loops back.
4. Use this to produce roughly 64 frames of animation.
optional: 5. Apply actual ior, reflection, etc. effects to the glass,
using a mockup of the virtual room I plan to use the result in.
This will have to later be copied, frame by frame, into a grid of
frames, so.. in principle, the resulting image would be 512x64, so that
it fits into a final image of 1024x1024 (i.e., 2 columns, by 32 rows).
Its the Step 3 that is driving me nuts. I tried something similar, but
backwards, just using pure Photoshop. Applying smoke to the runes, as a
mask, then applying another mask to this, which determined how much of
the runes where actually visible. The result was bloody ugly...
So, I thought - maybe raytracing the smoke would work better? Not sure
media would be the best thing here though, maybe.. a texture that mimic
the same result, applied to just the runes?
Seriously. As fascinated as I have always been with this program, to be
perfectly honest, I never made it much past the "how to build a chair"
tutorials in the book way back when one was published. lol Nearly
everything since has been mesh, imported to Second Life, or a few poorly
done attempts to convince POVRay to do things its not meant to, like..
using a spherical camera to try to "fake" a displacement map from a
complex object, and stuff...
I sort of have a vague idea what might work here, but.. :p
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
Subject: Re: Loopable "smoke".
Date: 21 Oct 2015 23:53:40
Message: <56285dc4@news.povray.org>
If you rotate any pattern, it will automaticaly repeat itself for every
full rotation.
The apparent speed depends on the distance of the pattern from the
reference axis: Far = fast, close = slow.
You need to play with the scalling of the whole scene or that of the
pigment to adjust the action buziness.
If you want an upward motion, then, I'd suggest a rotation around the X
or the Z axis with your container placed some distance in front of the
X-Y or the Z-Y plane.
Both transparent runes filled with some media or opaque ones may work.
Try both as the result should be very different.
For the media, you can use emissive edia against a dark background. No
need to have any light source in this case.
You may use absorming media against a white background to give you an
inverted contrast effect.
Finaly, a scattering media that may interact with some lighting can give
yopu interesting effect.
All 3 types of media can be present at the same time.
Simple sample of the concept:
box{<5,5,1><-5, -5, 2> pigment{agate rotate x*clock*360} finish{emission 1}}
camera{location<0,0,-10> look_at 0}
To be run as an animation of whatever length you want.
With another pattern and turbulence:
box{<5,5,1><-5, -5, 2> pigment{bumps warp{turbulence 1} rotate
Date: 23 Oct 2015 01:08:04
Message: <5629c0b4$1@news.povray.org>
> full rotation.
> 1}}
> Alain
Huh.. Hadn't thought of just rotating.. When thinking on things I
realized that a) it might not matter if it didn't loop, and b).. not
sure how you would make it do so. lol But, yeah, a texture, just rotated
though 360 degrees on the surface.. Yeah, that would work whether or not
I needed to actually loop or not.
Have to play with the texture though. I need it to be "wispy", which
those are not. lol But, it gives me a place to start. And, if nothing
else I can always do what I did before, but.. with better results - use
the mist one, or something like it, as a mask, or with "blend options,
and something that adds glow, and brightness to a straight texture.
Could almost do that with Photoshop itself, except that its "3D Render"
thing for clouds doesn't let you a) rotate or otherwise change the
result, b) is random, and c) doesn't let you alter the parameters of the
resulting clouds. In other words, a pain in the ass. ;)
Date: 24 Oct 2015 18:05:45
Message: <562c00b9@news.povray.org>
To have a "wispy" texture, I would be tempted to start with bumps or
bozo, add some custon colour_map, then add some turbulence.
To keep the turbulence consistent, I highly recommend using a wrap{}
block. That way, the turbulence can be applyed before the rotation and
any other transformation. Without the warp, all transformations are
applyed, then, the turbulence is applyed.
That way, it's possible to have multiple levels of turbulence at
different scale factors.
Date: 12 Nov 2015 22:00:00
Message: <web.564551cc608b5e175e7df57c0@news.povray.org>
Perhaps you can use a texture like granite and define a color map that has the
colors change in transparency with the clock variable.   Have your functions be
circular / continuous and it will loop smoothly.
You could even simultaneously do that with the runes themselves.
You could also "cheat" and find an existing animation of smoke with an alpha
channel, splay it out into separate frames, and have PovRay render those
overlaying your runes.
So many ways to skin this cat.
