POV-Ray : Newsgroups : povray.advanced-users : Animations and memory Server Time
29 Apr 2024 06:00:48 EDT (-0400)
  Animations and memory (Message 1 to 4 of 4)
Subject: Animations and memory
Date: 15 Aug 2015 14:11:30
Message: <55cf80d2$1@news.povray.org>
If I create an animation where everything remains the same except for
the camera position, will I have to go through the whole parsing process
each time, or will the scene stay in memory and therefore be faster?
Mike
Subject: Re: Animations and memory
Date: 16 Aug 2015 03:40:07
Message: <55d03e57$1@news.povray.org>
Am 15.08.2015 um 20:11 schrieb Mike Horvath:
That depends.
If you use plain vanilla POV-Ray, then IIRC there's some highly
experimental mechanism originally designed just for this case, parsing a
scene once with multiple camera statements and then just iterating
through all the cameras defined, frame by frame, but I must confess I
have no idea how it works (or whether it even does currently).
If you use UberPOV, there's the "#persistent" statement, which you can
use instead of "#declare" to define variables that persist between
frames of an animation (and, in case of POV-Ray for Windows, even
between totally unrelated renders in the same session, so caveat there)
as long as you don't explicitly "#undef" them. You can put (almost)
anything in there - including complex CSG unions - and simply re-use it
in the next frame instead of parsing it all over again, for example like so:
     my_scene.pov:
       #if((frame_number = initial_frame) | !defined(MyHugeObject))
       #include "my_huge_object.inc"
       object { MyHugeObject }
       #if(frame_number = final_frame)
       #undef MyHugeObject
     my_huge_object.pov:
       #persistent MyHugeObject = union {
Date: 30 Aug 2015 01:20:02
Message: <55e29282$1@news.povray.org>
> That depends.
> so:
>      my_scene.pov:
>        #end
>        #undef MyHugeObject
>        #end
>      my_huge_object.pov:
How will this work for highly nested objects, like LDraw models? Do I
make each and every primitive persistent?
Mike
Date: 30 Aug 2015 13:03:01
Message: <55e33745$1@news.povray.org>
Am 30.08.2015 um 07:20 schrieb Mike Horvath:
>>      my_scene.pov:
>>        #end
>>        #undef MyHugeObject
>>        #end
>>      my_huge_object.pov:
Nope - that's the beauty of it: You just make the "root" object
persistent, and it remembers the whole hierarchy.
