If I create an animation where everything remains the same except for
the camera position, will I have to go through the whole parsing process
each time, or will the scene stay in memory and therefore be faster?
Mike
Am 15.08.2015 um 20:11 schrieb Mike Horvath:
That depends.
If you use plain vanilla POV-Ray, then IIRC there's some highly
experimental mechanism originally designed just for this case, parsing a
scene once with multiple camera statements and then just iterating
through all the cameras defined, frame by frame, but I must confess I
have no idea how it works (or whether it even does currently).
If you use UberPOV, there's the "#persistent" statement, which you can
use instead of "#declare" to define variables that persist between
frames of an animation (and, in case of POV-Ray for Windows, even
between totally unrelated renders in the same session, so caveat there)
as long as you don't explicitly "#undef" them. You can put (almost)
anything in there - including complex CSG unions - and simply re-use it
in the next frame instead of parsing it all over again, for example like so:
my_scene.pov:
#if((frame_number = initial_frame) | !defined(MyHugeObject))
#include "my_huge_object.inc"
object { MyHugeObject }
#if(frame_number = final_frame)
#undef MyHugeObject
my_huge_object.pov:
#persistent MyHugeObject = union {
> That depends.
> so:
> my_scene.pov:
> #end
> #undef MyHugeObject
> #end
> my_huge_object.pov:
How will this work for highly nested objects, like LDraw models? Do I
make each and every primitive persistent?
Mike
Am 30.08.2015 um 07:20 schrieb Mike Horvath:
>> my_scene.pov:
>> #end
>> #undef MyHugeObject
>> #end
>> my_huge_object.pov:
Nope - that's the beauty of it: You just make the "root" object
persistent, and it remembers the whole hierarchy.
