POV-Ray : Newsgroups : povray.advanced-users : Stop rendering using a break statement Server Time
1 Jun 2026 02:06:59 EDT (-0400)
  Stop rendering using a break statement (Message 11 to 13 of 13)
Subject: Re: Stop rendering using a break statement
Date: 9 Feb 2015 15:01:23
Message: <54d91213$1@news.povray.org>
On 2/9/2015 3:23 AM, Le_Forgeron wrote:
> Le 09/02/2015 01:31, Mike Horvath a écrit :
>> No. For example I may want frames 1-3 and 5-6 parsed and rendered, but
>> not frame 4. Your suggestion doesn't work in this case.
> If frame 4 has already a output file, I wonder if the -C (or is it +C ?
> I know they are opposite of each other, but cannot remember which one
> would try to look if the output image already exist and is complete)
> option would not skip the render of it when detecting that it is already
> complete ?
If frame 4 exists most likely the others will as well. I tend to
accumulate renders and not delete them for years at a time.
Date: 9 Feb 2015 15:02:35
Message: <54d9125b$1@news.povray.org>
> Do you not want frame 4 rendered to save time, or because you physically
> don't want the file to be created?
> If you want to save time, but don't mind the file being there, then just
> let it render an empty scene with no objects for the frames you don't
> want, it will only add a fraction of a second.
> It should be easy if you could render another .pov file, and put
> something like this in it:
> #if(frame_number<>4) // or whatever condition
>   #include "mainPOVscene.pov"
> #end
I'm sure there's a workaround for every example I can come up with. A
break statement would just be a lot simpler and easier.
Date: 9 Feb 2015 22:12:45
Message: <54d9772d$1@news.povray.org>
Am 09.02.2015 um 21:02 schrieb Mike Horvath:
 From the user's point of view - yes, probably.
 From the developer's point of view - not so much. The current, grown
architecture doesn't lend itself to just skipping the parsing of a
frame, as all the set-up (most notably the deletion of an existing file
with the same name as the output file!) is done before invoking the
parser module.
