POV-Ray : Newsgroups : povray.advanced-users : Write to image metadata Server Time
9 Jan 2025 08:52:35 EST (-0500)
  Write to image metadata (Message 1 to 5 of 5)
Subject: Write to image metadata
Date: 8 Feb 2015 13:27:04
Message: <54d7aa78$1@news.povray.org>
I think this was asked already a while ago, but are there any plans on
letting people write to image metadata from within POVray?
Thanks!
Subject: Re: Write to image metadata
Date: 8 Feb 2015 14:15:36
Message: <54d7b5d8$1@news.povray.org>
> Thanks!
Available room in metadata (including number of bytes and encoding)
varies a lot from one format to another.
So far, povray writes to metadata, its own choice of data, as something
like 4 lines, up each to 80 characters (no line feed, no tab). (that's
kind of least common form for all formats that support metadata)
First two lines are used for platform & compiler, but the last 2 lines
are kind of opened, if you compile with METADATA_COMMENT_3 and
METADATA_COMMENT_4 to be either a constant string or (more interesting)
what ever string-returning-function(s) that you want.
That is for the comment part.
Other metadata such as software, date and render time might get inside
the part written, but sometime there is no such place for such info.
So, you're just one custom compilation away from something you might
want. Or you want to be more precise about your metadata.
(All above only for 3.7 and onwards)
Date: 8 Feb 2015 14:23:53
Message: <54d7b7c9$1@news.povray.org>
>> Thanks!
OK, thanks. Yes, I meant the comment part. I just checked a Windows 7
PNG file and don't see anything besides besides color depth, format,
dimensions, etc.. XnView doesn't show the comment either.
Date: 9 Feb 2015 02:44:19
Message: <54d86553$1@news.povray.org>
>>> Thanks!
Now testing the windows binary of povray 3.7: the comments are there, at
least gimp shows them in Image/Property/Comments :
Render Date: 2015-02-09 07:36:43Z
Platform: i686-pc-win-sse2
Compiler: msvc 10
Within XnView, I can "Edit"/"Edit comment" and see that it is there too
(but on 2 lines instead of 3...or rather a single line: in fact
line-feed are not displayed correctly, the small-rectangle glyph is
displayed instead)
Just because nobody complains does not mean all parachutes are perfect.
Date: 9 Feb 2015 14:59:45
Message: <54d911b1$1@news.povray.org>
> Compiler: msvc 10
> displayed instead)
I checked another file and the comment was present in that one.
