POV-Ray : Newsgroups : povray.advanced-users : HDR compositing? Server Time
28 Sep 2024 18:57:07 EDT (-0400)
  HDR compositing? (Message 1 to 5 of 5)
Subject: HDR compositing?
Date: 25 May 2014 08:00:46
Message: <5381db6e$1@news.povray.org>
Does anyone know how to do HDR compositing in POV-Ray, or something
giving similar results? I do not mean a hdr output, but something more
sophisticated than simple averaging of images.
Subject: Re: HDR compositing?
Date: 1 Jul 2014 16:37:47
Message: <53b31c1b$1@news.povray.org>
A bit late reply but I think you can do the following:
- Treat the different exposures as functions (split into R + G + B)
- Combine these into new functions using "select": use value
   from longer exposure by default, pull values from shorter exposure
   where longer exposure is above some threshold (e.g. 0.9). When using
   value of shorter exposure divide by appropriate factor (depending
   on difference in stops)
- Render combined function pigment with HDR output
Date: 2 Jul 2014 03:08:37
Message: <53b3aff5$1@news.povray.org>
Thanks Christian. In fact Clipka suggested what I should have known:
render in exr and post-process in Ive's IC.
Date: 13 Jul 2014 20:53:33
Message: <53c32a0d$1@news.povray.org>
ah then I misunderstood your question. I thought you wanted
to composite actual photos (taken with different exposure lengths)
as HDR in POV-Ray :)
Date: 14 Jul 2014 02:47:05
Message: <53c37ce9$1@news.povray.org>
Somehow I wanted to use POV-Ray images as equivalents of actual photos.
It certainly works but the final hdr quality using the Fusion F1 program
for instance is less than making an exr image in the first place.
However, it was an interesting experiment which I may use in other
occasions.
