POV-Ray : Newsgroups : povray.advanced-users : Random placement of objects Server Time
28 Jun 2024 23:35:12 EDT (-0400)
  Random placement of objects (Message 1 to 9 of 9)
Subject: Random placement of objects
Date: 29 Aug 2013 08:15:00
Message: <web.521f3ad329e33e34dd2ebc560@news.povray.org>
I'd like to place some objects semi-randomly in a scene.
Semi, because they should not intersect or overlap other stationary objects.
It seems to me that this ought to be a classic issue in video games, and one
that's been long solved, and I will research it further.
I do however have limited time, and if someone can nudge me over to a quick
resolution of the problem, that would be great.
Basically I want to take some short strings and have them fade in and out of the
"open areas" in the visible area of the scene.
I could also use a primer and straightening out of my understanding of how the
pseudo-random streams work, since when I run my little test scene with a box and
a string, the string is always in the same place.  What's the solution /
workaround?
#declare Message = text { ttf "arial.ttf" Attributes [2] 0.1, 0 pigment {White}
scale 1 translate < rand(FlashX), rand(FlashY), rand(FlashZ) > * 4}
#declare MinM = min_extent(Message);
#declare MaxM = max_extent(Message);
object {Avoid}
object {Message}
#if (MaxM.x > MinA.x | MinM.x < MaxA.x)
text { ttf "arial.ttf" "X Overlap" 0.01, 0 pigment {Red} translate y*1}
#if (MaxM.y > MinA.y | MinM.y < MaxA.y)
text { ttf "arial.ttf" "Y Overlap" 0.01, 0 pigment {Red} translate y*0}
#if (MaxM.z > MinA.z | MinM.z < MaxA.z)
text { ttf "arial.ttf" "Z Overlap" 0.01, 0 pigment {Red} translate -y*1}
Subject: Re: Random placement of objects
Date: 29 Aug 2013 10:55:02
Message: <web.521f60299c870026dd2ebc560@news.povray.org>
I see that the pseudorandom stream is dependent upon the seed value.
I guess what I need is a _different_, if not truly random value to pass to the
seed() generation command.
Are the noise generators "truly" random (enough) for this purpose?
I see clipka tried to access the system date/time way back when, which IIRC is
how we used to do it when I was a kid, when we used to build mechanical
computers out of dinosaur bones shaped with flint tools... :O
Is there _any_ outside, changing system value that POV-Ray SDL can access?
Date: 29 Aug 2013 11:06:16
Message: <521f6368$1@news.povray.org>
It's typical to seed the random number generator based on the system
time. I'm not sure if POV offers this option, but if not you can hack
something together using the "datetime" command:
#declare mySeed = seed(val(datetime(now,"%H%M%S")));
Date: 29 Aug 2013 11:30:00
Message: <web.521f67fc9c8700262507f0530@news.povray.org>
I would be careful with that, since you can never reproduce a picture using
system time as seed. Better try hand coded seeds until you have the placement as
you like it. The last one you keep. A given seed will ever produce the same
"random" sequence.
Collision detection is not implemented in POV as all I know. If you are content
to use spheres surrounding your objects you can test the distance of their
centers againt the sum of their radii. But you can not come closer with this
approximation.
Best regards,
Michael
Date: 29 Aug 2013 11:39:01
Message: <521f6b15$1@news.povray.org>
Le 29/08/2013 17:06, scott nous fit lire :
>> pass to the
You are doing it the long way.
#declare mySeed = seed(now); /* only in 3.7 */
You might want to multiply now by some constant, as the unit(1) is the day.
Date: 29 Aug 2013 11:46:08
Message: <521f6cc0$1@news.povray.org>
Ah, much better!
Date: 29 Aug 2013 11:50:01
Message: <web.521f6d1d9c870026dd2ebc560@news.povray.org>
This must be a 3.7 feature.  I'll update to that when I can.
Indeed.  Though sometimes I'd like to have things be different every time if I
really want them to be.  Predictably pseudorandom is obviously trivial.
Unpredictably more pseudorandomer is tricksier, My Precious.  Oh yes, very
tricksy indeed.
> "random" sequence.
This is indeed getting clearer.  Useful to know.
> approximation.
Clever and simple.  Likely FAST, too.
Thank you ever so much for that little trick.
After a moment of reflection, I believe that better/simpler would be to limit my
placement and testing to 2D with circles, to avoid sorting out the potential
random "spheres" that would be hidden behind the stationary "spheres".  _Then_
I'll translate the circle that pops out the end of the loop along z by a random
amount.
Eventually I'll work out something with bounding boxes and vector functions...
Date: 29 Aug 2013 13:55:00
Message: <web.521f89a39c8700268507740b0@news.povray.org>
I just played around a bit, since collision detection would be a nice thing. It
seems that intersections of solid objects gives a finite bounding box if there
is an intersection and an infinity one
box { <-10000000000,10000000000> }
if there is no intersection. May be one of the more experienced users here knows
the answer. It seems to work with spheres and boxes.
But one has to store all objects in an Array since one has to test every new one
against all existing. In special cases there are optimisations. May be you would
like to study the code of Jonathan Hunts "pebbles". You find the link within the
POV Hall of Fame.
Best regards,
Michael
Date: 30 Aug 2013 17:15:34
Message: <52210b76$1@news.povray.org>
> POV Hall of Fame.
> Best regards,
> Michael
A simple one is to put all base objects in a single union. Those are
your environment.
Test the randomly placed objects against that union.
If you have many objects to place, after about 100, make an union with
those. Now, you only test for the static objects and that union. That
test will be much faster than testing every individual objects.
You can also use the trace function in some cases.
