POV-Ray : Newsgroups : povray.advanced-users : quantifying lighting in the scene in Lumens Server Time
29 Jun 2024 01:49:56 EDT (-0400)
  quantifying lighting in the scene in Lumens (Message 1 to 5 of 5)
Subject: quantifying lighting in the scene in Lumens
Date: 2 Jan 2013 13:55:00
Message: <web.50e4823a10965fe3d7ae32040@news.povray.org>
Hi everyone,
I am wondering if it possible to quantify the lighting in the POVRay scene in
lumens? Is there a variable in the scene I can access or is it just the average
Irradiance values observed at the pixels? Could someone send pointers to that
please?
Thanks,
Ankur.
Subject: Re: quantifying lighting in the scene in Lumens
Date: 2 Jan 2013 14:10:01
Message: <web.50e485ef7f8886a378ca74630@news.povray.org>
"handos" <han### [at] gmailcom> wrote:
> Hi everyone,
> please?
> Thanks,
> Ankur.
Take a look at Jaimes Lightsys-macros (http://www.ignorancia.org/en/) not easily
to comprehend, but may be an answer to your question.
Best regards,
Michael
Date: 2 Jan 2013 14:13:51
Message: <50e486ef@news.povray.org>
Le 02/01/2013 19:53, handos nous fit lire :
> Hi everyone,
> please?
You would want a gamma of 1.0; And probably diffuse 1, ambient 0 on your
target surface. (which might rules out any complex scene with reflection)
Notice that there is no notion of distance for one pov unit. (can be
meter, kilometer, millimeter, miles, yards or what ever).
You would need to adjust the light_source to have fade_distance &
fade_power.
Spherical light source are easy, as well as far far away sun... but
conical ones are more difficult. Also read in details:
> http://wiki.povray.org/content/Documentation:Light_Source
Date: 2 Jan 2013 16:07:50
Message: <50e4a1a6$1@news.povray.org>
>> Hi everyone,
>> please?
> fade_power.
Yeah, this is something that kind of makes things more annoying than
usual, on occasion. lol But, it should be calculable anyway, if someone
bothered, right? Say, you set a variable, using meters as the default,
Assumed_Unit = 0.01 (i.e., a centimeter), then your calculations are
going to be based on, "X is pure white, at Y units, when Assumed_Unit =
1 meter", and all you need to do is scale your lighting by the fact that
you are using a centimeter, instead of a meter.
The real trick being that you need to figure out what the correct
settings, for a light, to get that result, with a specific falloff
(which, I don't think changes much, other than with lumins, in the real
world, right?), then work out where the correct Y is, for your "default"
1 meter distance. After that, you just tweak the variables, including
falloff, to work out what the change is, over different scales.
Bound to be hard, but not impossible. It just means, when you need/want
to use that lighting model, you have to have a defined 1 unit = X
meters, to work from, during the entire process. And, frankly, we do
that anyway, when building, to get everything scaled properly (unless
your someone that just builds things, then scales them after, until they
look right, or something...)
Date: 3 Jan 2013 03:46:38
Message: <50e5456e$1@news.povray.org>
On 2-1-2013 22:08, Patrick Elliott wrote:
> [snip](unless
LOL I often just do that indeed  :-)
