POV-Ray : Newsgroups : povray.advanced-users : The Menger Sponge Conundrum Server Time
16 May 2026 22:44:00 EDT (-0400)
  The Menger Sponge Conundrum (Message 1 to 6 of 6)
Subject: The Menger Sponge Conundrum
Date: 9 Dec 2010 13:39:45
Message: <4d012271@news.povray.org>
Hello,
I'm trying to get the Menger Sponge working with my Kaleidoscopic IFS
setup, but the geometry is doubled along the Z-axis.
I'm replacing
KIFS_0(
  x*Scale-CX*(Scale-1),
  y*Scale-CY*(Scale-1),
  z*Scale-CZ*(Scale-1))
with
KIFS_0(
  select( -(z*Scale-.5*CZ*(Scale-1)), (z*Scale-CZ*(Scale-1)),
which should work the same as the "if" statement in the last example of
the first post in this thread:
http://www.fractalforums.com/3d-fractal-generation/kaleidoscopic-%28escape-time-ifs%29/?PHPSESSID=47d4a7c03e14fe8cb7b5e50f56dcb0dd
I have battled with translation issues during the entire creation
process. Doing things in POV-Ray is quite a bit different than other
methods, but am not complaining since other things are made easier. But
I'm pretty sure that is why it doesn't work as expected...
Any thoughts on this matter are appreciated!
Sam
Subject: Re: The Menger Sponge Conundrum
Date: 13 Dec 2010 17:16:19
Message: <4d069b33@news.povray.org>
On 12/9/2010 10:39 AM, stbenge wrote:
Perhaps my question is better asked elsewhere, or nowhere. I can't
possibly expect someone to look through my code base... but I was hoping
for a little insight. I've tried all the obvious things already :/
Date: 14 Dec 2010 15:36:12
Message: <4d07d53c@news.povray.org>
Are you sure you posted the entire select statement?
Unless the KIFS macro is even more advanced (or convoluted?)
than it appears, the commas and parantheses don't quite seem
to match up.
Under the assumption that
   y=scale*y-CY*(scale-1);
corresponds to
I'd expect
   z=scale*z;
   if(z>0.5*CZ*(scale-1)) z-=CZ*(scale-1);
to correspond to something like
   select(0.5*CZ*(Scale-1)-Scale*z,Scale*z-CZ*(Scale-1),Scale*z)
which seems indeed to be identical to what you posted
except for the excluded last Scale*z part. There is of
course also the possiblity that the OP accidentally
posted a wrong version of the source code.
well ... although you sometimes deprecate your own technical
knowledge you are actually one of the masters and I don't think
there are that many people here who can actually understand your
code without investing a significant amount of time to read up
on all the theory first (I played around with your code for a
while and am still not quite sure what it does, although I
allegedly should have a math degree lying around somewhere).
Date: 16 Dec 2010 18:25:55
Message: <4d0aa003@news.povray.org>
> to match up.
Convoluted, it wouldn't be the first time ;) I somehow managed to botch
the copy/paste; I meant to post something like this:
select(-(z*Scale-.5*CZ*(Scale-1)), z*Scale-CZ*(Scale-1), z*Scale)
...which is essentially the same as what you suggested, and has the same
effect as well: a doubled Menger Sponge. I'll have to go over all the
reasons of why my implementation is different from what other people
were doing. One of the big differences is that my reflections are called
in a different order. When I tried to directly copy the folding steps
from other sources, I got nothing but incorrect results every time.
Maybe I should be carrying over a second set of axis variables like
you'd do for the M-Set... but I'm converting the pure function to a
patterned function, so trying that out would not be a trivial task.
It's actually not that different from computing the Mandelbrot fractal
with functions. The initial function works as the basin (practically
irrelevant for KIFS, though it might be utilized as a coloring method),
the first part of the main select statement is used for the bailout, the
second for the actual work, and the third for the exterior
coloring/distance evaluation (intimately tied to bailout). When
experimenting with the M-Set, I was amazed at how quickly these elements
stratified into their respective parts.
At any rate, I thank you for your reply. I'll either figure it out, or I
won't :)
Sam
Date: 14 Jan 2011 13:20:00
Message: <web.4d30938be8b9e73cd70fe6f50@news.povray.org>
There is a Menger Sponge script in the POVray Object Collection. Maybe you can
take a look at that.
Date: 19 Jan 2011 14:25:16
Message: <4d373a9c$1@news.povray.org>
Thanks for the idea, but I know about Menger Sponges. The Kaleidoscopic
IFS version works on a different principle than recursive object calls.
I'll return to the problem again someday :/
Sam
