![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
When I created the following SOR object in 3.6.1 it worked, but in 3.6.2
and the beta it no longer works. Why does it no longer work, and what
can I do to fix it?
#include "GSprites_Scene_settings.inc" // Source of the camera and
lighting code
#local Tiles_Width = 64;
#local Tube_Radius = Tiles_Width/2/cos(pi/4) * 5/4;
#local Wid = Tiles_Width/2;
#local Angle_Start = acos(Wid/Tube_Radius);
#local Angle_Incrm = 2/8 * Angle_Start;
sor
11,
cos(Angle_Start - 8 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 8 * Angle_Incrm) * Tube_Radius,
cos(Angle_Start - 7 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 7 * Angle_Incrm) * Tube_Radius,
cos(Angle_Start - 6 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 6 * Angle_Incrm) * Tube_Radius,
cos(Angle_Start - 5 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 5 * Angle_Incrm) * Tube_Radius,
cos(Angle_Start - 4 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 4 * Angle_Incrm) * Tube_Radius,
cos(Angle_Start - 3 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 3 * Angle_Incrm) * Tube_Radius,
cos(Angle_Start - 2 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 2 * Angle_Incrm) * Tube_Radius,
cos(Angle_Start - 1 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 1 * Angle_Incrm) * Tube_Radius,
cos(Angle_Start - 0 * Angle_Incrm) * Tube_Radius - Wid,
sin(Angle_Start - 0 * Angle_Incrm) * Tube_Radius,
pigment {rgb 1}
translate Wid
http://isometricland.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oops. Check this code instead.
sor
11,
pigment {rgb 1}
translate Wid
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 25.07.2010 04:30, schrieb SharkD:
> can I do to fix it?
Due to rounding errors, the first two and last two points in the SOR
happen to have a negative X coordinate. While 3.6.1 seems to have
accepted such values, 3.6.2 and 3.7 don't.
To fix it, you may explicitly set the offending points' X coordinates to
zero. Alternatively, enclose the X coordinates in a "max(0, ...)"
expression to force them into the non-negative domain.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The workaround was to clip the values at 0, like so:
sor
11,
max(0,cos(Angle_Start - 8 * Angle_Incrm) * Tube_Radius - Wid),
max(0,cos(Angle_Start - 7 * Angle_Incrm) * Tube_Radius - Wid),
max(0,cos(Angle_Start - 6 * Angle_Incrm) * Tube_Radius - Wid),
max(0,cos(Angle_Start - 5 * Angle_Incrm) * Tube_Radius - Wid),
max(0,cos(Angle_Start - 4 * Angle_Incrm) * Tube_Radius - Wid),
max(0,cos(Angle_Start - 3 * Angle_Incrm) * Tube_Radius - Wid),
max(0,cos(Angle_Start - 2 * Angle_Incrm) * Tube_Radius - Wid),
max(0,cos(Angle_Start - 1 * Angle_Incrm) * Tube_Radius - Wid),
max(0,cos(Angle_Start - 0 * Angle_Incrm) * Tube_Radius - Wid),
pigment {rgb 1}
translate Wid
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Heh. We posted at the same time!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
