POV-Ray : Newsgroups : povray.advanced-users : Random tree position, without duplicates? Server Time
28 Sep 2024 20:14:04 EDT (-0400)
  Random tree position, without duplicates? (Message 1 to 10 of 11)
Subject: Random tree position, without duplicates?
Date: 4 Jun 2010 15:45:56
Message: <4c0957f4$1@news.povray.org>
Is there a good way to, for instance, place a number of trees randomly
without having them overlap?
Currently, I use an array to store the positions and compare each new
tree to all the previous ones. This is however very slow.
I could also create a multi-dimensional B-tree array that divides the
world into a grid, thereby reducing the number of items to look up. I
wonder if that would speed things.
http://isometricland.com
Subject: Re: Random tree position, without duplicates?
Date: 4 Jun 2010 15:48:50
Message: <4c0958a2@news.povray.org>
On second thought I don't think this will work because array sizes must
be known beforehand, and with a B-tree sorting method there's no
guarantee how many items a node will hold.
Date: 4 Jun 2010 16:25:53
Message: <4c096151@news.povray.org>
one possible way is to iterate over a grid of possible positions and
then deciding randomly or based on a distribution function whether this
particular cell should contain a tree. The actual tree position can
then be varied within the cell to avoid an obvious grid spacing.
Date: 4 Jun 2010 16:57:32
Message: <4c0968bc$1@news.povray.org>
Thanks, that sounds like it would work.
Date: 4 Jun 2010 17:30:00
Message: <web.4c096fec295829f03694f4200@news.povray.org>
I'd start with a halton sequence (I find myself using them everywhere...) and
seeing if it does a better job of not overlapping the trees:
#macro halton( index, base )
 #local out = 0.0;
 #local fraction = 1.0 / base;
 #local i = index;
 #while( i > 0 )
  #local remainder = mod( i, base );
  #local out = out + (fraction * remainder);
  #local i = int(i / base);
  #local fraction = fraction / base;
 out
#macro halton2D( n )
 #local baseX = 2;
 #local baseY = 3;
 < halton( n, baseX ), halton( n, baseY ), halton( n, baseZ ) >
You additionally take the values returned by the halton2D() macro, and test them
against a pigment function to decide whether to place a tree - this would give
you non-overlapping randomness on the small scale, and some clumping of trees on
the larger scale. My guess is that that would look quite natural, but you'd have
to give it a try to find out.
Cheers,
Edouard.
Date: 4 Jun 2010 17:35:01
Message: <web.4c097093295829f03694f4200@news.povray.org>
"Edouard" <pov### [at] edouardinfo> wrote:
Opps - I mean:
 #local baseX = 2;
 #local baseY = 3;
 < halton( n, baseX ), halton( n, baseY ), 0 >
Date: 4 Jun 2010 18:55:59
Message: <4c09847f$1@news.povray.org>
On 6/4/2010 5:31 PM, Edouard wrote:
> "Edouard"<pov### [at] edouardinfo>  wrote:
> Opps - I mean:
>   #local baseX = 2;
>   #local baseY = 3;
>   <  halton( n, baseX ), halton( n, baseY ), 0>
> #end
Could you provide an example of how to use it? Thanks.
Date: 4 Jun 2010 20:10:00
Message: <web.4c0994e4295829f03694f4200@news.povray.org>
> > Opps - I mean:
> >   #local baseX = 2;
> >   #local baseY = 3;
> > #end
I'll try!
The halton macro returns a number from 0..1, and halton2D() returns a vector
where the X is 0..1, Y is 0..1 and the Z = 0.
You call halton2D() with an incrementing integer, so it works best in a loop.
If you had a macro called PlaceTree(), you could loop through values from
halton2D calling the tree macro like this:
#declare n = 1;
#while( n < number_of_trees_wanted )
  #declare position = halton2D( n );
  // position is <0..1, 0..1, 0> - scale the vector here
  // to the size you need for PlaceTree
  PlaceTree( position )
  #declare n = n + 1;
Does my explanation make sense?
Cheers,
Edouard.
Date: 5 Jun 2010 15:18:39
Message: <4c0aa30f$1@news.povray.org>
>>> Opps - I mean:
>>>   #local baseX = 2;
>>>   #local baseY = 3;
>>> #end
> I'll try!
> #declare n = 1;
>   #declare n = n + 1;
> #end
> Cheers,
> Edouard.
This is very useful! I see that the increasing integer eliminates the
overlap of points.  Is there a relationship between the size of the
object and the size of the increment that can be used to prevent
objects intersecting?
Date: 5 Jun 2010 17:10:01
Message: <web.4c0abcf0295829f0130d01f50@news.povray.org>
> >>> Opps - I mean:
> >>>   #local baseX = 2;
> >>>   #local baseY = 3;
> >>> #end
> > I'll try!
> > #declare n = 1;
> >   #declare n = n + 1;
> > #end
> > Cheers,
> > Edouard.
Unfortunately not - all it does is generate numbers that have a distribution
that looks random, but have the property that they don't clump together. As you
generate more numbers, each new item fills a position that was empty, and as you
generate more and more numbers in the sequence, space gets filled denser and
denser.
If your objects aren't too closely packed, a halton sequence is a very easy
replacement for rand(), and may work well. I posted it mainly because it should
be very easy to try out for the problem described.
Cheers,
Edouard.
